I want to repair this item but no good without circuit diagram does not boot up but power supply ok
SOURCE: Boot Problem in TASCAM 2488
Turning the power off with out going through the shut-down process will sometimes trash the hard drive making it un readable. To force format of hard drive hold down the shut down, send, shift and quick routing keys at the same time then turn power on. This will format the HD. When finished the display will show "Factory initalize complete" "please power off" NOTE you will lose every thing on the HD including the demo song.
SOURCE: Making Midi Files for Importing to Tascam 2488
You should always work in wav format if possible because there is a loss of quality with mp3 which is a compression format in which bits are lost in order to compress the file size.
There are a number of wav editors available which will allow you to load a stereo wav and then save it as a mono wav. The free one I use is called Audacity.
When working with FL or Reason I will sometimes import files to the Tascam, or I will take the outputs from my PCs sound card and line them into the tacams inputs and record them live. I only tend to do this with programs (like synths) where I am using an external midi keyboard and can play live what I want to record.
With basic drum pattern tracks I'll usually create them on the PC, save as wav, convert to mono, and then import to a track on the Tascam.
hope this helps.
bd.
nothing received
Hey Brian...Did you ever find those schematics. I have a problem with my unit..Replaced the tach switches for the stop and rewind buttons and now the display does not work..it lights up but no information....
to anybody out there.....any help greatly appreciated!!!!!
