I have this scanner which always worked fine with Go Figure software. Curves developed new operating software + I'm wondering if this scanner can be configured? Curves OS is not supporting this scanner but said to check with you.
SOURCE: Stopped scanning
I seldom do this ...but I will comment on the Zebex scanner. This is ...errr ... not the best choice for future scanner needs. I will never forget commercial Zebex experience. They should have stuck to anti freeze (just kidding).
However if it did work and now doesn't there is one problem that is so obvious no one thinks of it ... check the clear plastic protector on teh front and see if it need cleaned. Greasy environments usually fog it over time.
I have the Zebex default codes somewhere in the shop ... but you can replace that scanner with a nice PSC, Mot, or Intermec for about 120.00 why not do that?
SOURCE: Alpha 70 Series is not working after disconnecting PC and recnctg
Hello Suzanne. The problem you are going to find here is that Zebex doesn't make this model anymore and haven't for some time. If the unit has power and emits a beam, I have the Zebex generic Programming Card and Programming Guide available on my company's website. Have a look at the sections that include the "reset default" barcodes. Print out that page and try scanning them with your scanner. Resetting the scanner to it's default programming may get everything ironed out. If the scanner doesn't have power or emit a beam, then unfortunately you will be looking at getting a replacement scanner. I can recommend several different scanners what would work fantastically and be quite cheap. If you still need help, please feel free send a message or email me. I hope this helps. Good luck!
