Question about Dell PowerEdge 1600SC Server
Checking SCSI Devices SpinUp : 100%
Frozen
1 Related Answer
paul_gall539
paul_gall539
SOURCE: Can not access bois
My Dell 1600sc hung at bios screen. Progress bar qas about 10% . Problemed turned out to be a corrupted memory module - reved 3 out of 4 and tried to run worked and then process of elimination
Posted on Sep 22, 2012
Trying to find the jumper settings for a Seagate 36G 80PINS SCSI 15K RPM HDD Hard Drive with an apparent part number 8E036JO (all my Google searches say it's a Maxtor), but the one I have is Seagate....
SCSI hard drives and devices have a jumper setting to configure the SCSI ID.
Each SCSI device must have a different ID.
The jumper/s are set for the following positions across 3 pairs of pins
: : : = SCSI ID = 0 no jumpers - usually for the boot hard drive
: : I = SCSI ID = 1
: I : = SCSI ID = 2
: I I = SCSI ID = 3
I : : = SCSI ID = 4
I : I = SCSI ID = 5
I I : = SCSI ID = 6
I I I = SCSI ID = 7
This gives a total of 8 possible SCSI devices on one SCSI controller.
Aug 25, 2011 | Maxtor 8E036JO 36G 80PINS SCSI 15K RPM HDD...
Hi.. please help... After installing scsci card im getting message as bios not installed. It says that scsi bios not installed and that in device manager both scsci card and tape drive are installed...
Hi when you start the pc and goes to the scsi utilities and scans for device its not finding the device attached to it sioit gives you this message you can see if the terminator connect to the device is properly connected and its in its place ,also press CTRL+A to get into the adapter setting and in the scsi utilities section scan the devices if it finds it then check the id of the device how much its set to it should not be the same of the scsi card id .by default scsi card id is 7 but be sure.
Dec 10, 2010 | Adaptec APD-29160 MAC 64 BIT PCI SCSI...
What does SCSI mean?
SCSI- Small Computer System Interface
It is a set of standards for physically connecting and transferring data between computers and peripheral devices.
May 29, 2010 | Microsoft Windows XP Professional
Is Termination Necessary?
Usually, SCSI devices come with the termination built into the device. Older devices actually had two or three terminating resistor packs plugged into the card or drive circuit board. More modern ones have DIP switches to turn the termination on or off.
Essentially, on a SCSI daisy chain ribbon cable with multiple connectors, only the first and last physical device needs to be terminated. Usually SCSI devices come from the factory already terminated. If you have only one device to connect check and see if there is a DIP switch to change. I would go ahead and connect it. If it works, it's probably already set properly.
That said, I have worked with daisy chains of SCSI devices where a particular device would only work if it were terminated even if it was in the middle of the chain. s
Jul 10, 2009 | Adaptec Ultra160 Scsi 29160N (1835200)...
Umax Mirage II Flatbed scanner,3 flashing lights
Could be a SCSI termination issue. Try changing the SCSI address number on the scanner to a different one and make sure the chain is terminated properly. If there are multiple SCSI devices in the chain, disconnect all the others until you are sure the scanner is working then slowly add the other devices to the chain making sure everything works as each device is added. SCSI voodoo!
Jun 26, 2009 | Office Equipment & Supplies
SCSI Devices not detected when posting ML530 Server.....
To get to the BIOS for your server, press F10 at start-up. This should get you there to verify if settings are detecting SCSI devices. If they are there, you may have to reinstall the SCSI controller drivers. Good Luck.
Jan 30, 2009 | HP Compaq ProLiant ML530 Server
Rathwynn
Hey there
The most common cause is that setup does not have the driver for a SCSI device or is detecting storage devices in the wrong order, such as that CD-ROM drive first.
Press F6 when setup first starts and provide a driver for the mass storage device that will hold the operating system files.
Check to make sure all adapters and controllers are working properly.
Check power to all devices. Reseat adapters and controllers.
For SCSI devices ensure:
1. The SCSI cabling is properly installed.
2. SCSI devices are terminated.
3. SCSI devices are correctly addressed. And
4. The BIOS correctly recognizes all SCSI adapters.
Also, be sure the SCSI boot drive is addressed as 0.
Check the manufacturer's recommedation for configuring SCSI adapter and Hard Disk Drives. Try replacing the adapter before replcing the drive(s).
For EIDE Drives:
1. Check the controller.
2. Ensure file I/O and disk access are set to standard. And
3. Ensure that the system drive is the first device recognized by the controller.
For IDE and ESDI drives:
1.Check the cabliing and controller.
2. Check the Drive setup in the BIOS for master/slave relationships. And
3. Ensure the drive is properly recognized in the BIOS.
Gimme acknowledge by rating me.
thanx
Romy
Aug 05, 2008 | Intel Motherboard
External HDD continuously beeping
The beeeeep beeeeep long twerps is the hard drive trying to spinup. drive don't beep unless they have died.
Mar 22, 2008 | Seagate (ST9100801U2-RK) (9W3638556) 100...
Can not access bois
It hangs there probably becuase one or more of the drives are dead or are almost there. Check and see the lights on the drives are falshing funny or too long or are yellow. If you find one of them that are that way, pull it out and then reboot.
See if that helps.
Nov 07, 2007 | Dell PowerEdge 1600SC Server
Dell PowerEdge 1600SC Server Logo
133 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
