Question about Lexmark X3650 Printer
Lexmark x3650 Does not want to except a refilled cartridge
The printer notified me of low ink levels so I refilled the cartridge, over a period of time it said empty cartidge I took it out and reinstalled it now it say's right cartridge is incorrect. This is the color cartridge but the black is starting to get low to. Help!
Mike.
Posted by moodycruze on
  • maryj442008 Jan 02, 2009
    I am having the same problem too.I have been awake for hours trying to figure it out. Maybe these are not refillable cartridges. :(
  • JZILLA788 Jan 20, 2009
    THE SAME ERROR
  • Lexmark Master
  • 18,904 Answers
Try the reset procedure listed here: http://www.noahsnet.com/how-to-reset-a-lexmark-x3650/
Posted on Oct 20, 2017
5 Related Answers
Anonymous
  • 29 Answers
SOURCE: Lexmark x5470 all in one printer-low ink level
Fiend your solution direct from Lexmark. Here is your solution
http://www.lexmark.com/printer/prob676ijt65/solution
921
Posted on Mar 03, 2009
ussick
  • 52 Answers
SOURCE: refilling lexmark cartridges x2500
There are a couple ways to trick it into accepting the cartridge. You can put a different one in, take it out and then put the filled one in. Or you can find a refill kit with instructions on what contacts to cover with tape and you have to do it 2 or 3 times to get the printer to reset. Sometimes you can shut off the computer and printer for 20 min and start it up again. Or you can get the sledge hammer and smash the stupid printer before it sucks up your life savings and vow never to buy from a company that profits from causing problems that they tell you can only be solved by using more of their overpriced solutions.
Posted on May 05, 2009
jdthefixer
  • 747 Answers
SOURCE: refilling cartridges
Joe,
You should have received control program software with your printer. If installed, the icon should be on your desktop or it may be in your programs list. You can also get the software from the Lexmark web site.
Anyway, you probably need to reset the cartridge using the control program. It's not difficult. Just follow the prompts.
Posted on May 16, 2009
Roop1980
Roopesh S
  • 228 Answers
SOURCE: still getting message empty cartidge lexmark x2650
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Posted on May 26, 2009
Anonymous
  • 16 Answers
For that printer: there are 4 color and 4 black cartridges BESIDES the #31 photo cartridge. Lexmark has made it so you MUST either, throw away or send to them, the 36 and 37, the 36XL and 37XL. The printer will never again recognize them after they are removed from the printer...
However, the 36XLA and 37XLA AND the 36A and 37A as well as the 31 Photo may be removed from the printer, refilled, and reinstalled.
I have seen some forums that say you can but a piece of BLACK tape, across the bottom row of contacts on the non-refillable cartridges....I believe there are 4 to 7 contacts across the bottom row only.....and the printer will still give you a message that it needs ink.....but it WILL print. I have not tested this theory yet though. I have just gotten the first message saying my black ink is very low.
Hope this helps and I think Lexmark Corporation Sucks for tricking people like this. (This printer comes with the NON refillable cartridges as default, but I did NOT see in the documentation that it couldn't be refilled. Nasty people........:(
Good Luck~~! [email protected]
Posted on Jul 07, 2009
After refilling my cartridge it shows ink level low for one cartridge and gives two error messages for every printing but prints. But for another cartridge it does not print and give message to buy a new...
Original Printer manufacturers do not recommend refilling in cartridges.
Different inks used in different cartridges differ in density, color, acidity etc. Usually refilling ink is made as universal ink. i.e. They produce the ink for 'any printer'.
The differences in the original and refiling inks might lead to the printer not recognizing the ink level.
Either buy a new cartridge or just ignore the messages.
Hi I have refilled my Lexmark X5630 , BUT IT STILL SHOWS THAT THE CARTRAGE NEEDS TO BE FILLED ;PLEASE ADVICE
Lexmark does not recommend the use of refilled/remanufactured cartridges. They tend to degrade print quality and printer/cartridge performance.
Note that once a cartridge is refilled, it can no longer register its ink level.
2helpful
2answers
Lexmark X3650 all-in-one Printer, have refilled colour cartridge with inkjet refill kit but still indicates low-ink level, and will not function. Do I need a resetter?
Go to all in one program
at the top left click on Maintain\Troubleshoot
Right window click on Device Status And Ink Levels
that will open a new window
Click on The button that looks like 4 different colored ink drops
Click on Install a new print cartridge
Click on Next
Now you should be in Select The cartridge installed
Open lower drop down window and click on No its new
Follow the prompts from there or click OK
This should fix the problem.
Refill on lexmark x3650
Not positive, but I read in a forum recently that this will NOT work with this cartridge.....if u find out, let me know. I need ink too....:(
4helpful
Refilling cartridges
Black Ink has been re-filled, canon MP240 says its empty )=
i thnk you need to replace the cartridge maybe the ciruit has been destroy in the event of refilling the cartridge..so that the computer cannot read the ink level ..
I hope it help.
thanks for using FIXYA.
2helpful
Joe,
X5470 Lexmark printer
Lexmark and Dell use a sensor in the cartridge to sense a low ink level. Once the sensor has been activated, you cannot reset it. The printer should work fine except for the fact that you'll have to override the "low ink" message on your computer.
Manufacurers don't make money on printer hardware. All the money is made from ink replacement, so they make it as difficult as possible to use anything other than the stuff you buy from them. Some (HP) put in chips for an "expiration" of the ink/toner. Go beyond the expiration date, the thing won't work.
3helpful
2answers
To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
Lexmark X3650 Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Ekse
Randy Prevost
Randy Prevost
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
