Question about Kenwood KDC-C715 10 Disc CD Changer
No power to the disc changer, how do I manually eject the magazine
How do I manually eject the cd magazine from my kdc-c715 10 disc cd changer.
Posted by Brian Ahrent on
Larry Spears
  • 625 Answers
There is a manual eject slot on the side of the CD changer. You will need a small flat head screwdriver or a pry tool to insert into the slot.
Posted on Oct 11, 2012
5 Related Answers
Anonymous
SOURCE: Can't eject cd magazine - E-99 error message
I had the same problem. I opened up the unit and found out that there is a plastic gear that moves the loader. When worn the loader can not load tha magazines nor change cd's. I replaced the gear and the cd autochanger worked fine.
Gerald,
Kenya.
Posted on Aug 25, 2009
Anonymous
  • 22 Answers
SOURCE: magazine don't eject
check out if there is any small hole on the surface of cd changer..
Then take one safety Pin and insert it inside the hole..
after than press slightly inside the hole ...
then u will be able to take out cds
Regards Renai
Posted on Nov 17, 2007
d0wnl0ad
  • 20 Answers
SOURCE: Error Message
another problem i have found is that if the changer gets to hot sometime it wont play and by removing the disks it lets it cool just enough to make it work. sometimes by making sure to have enough ventilation in it might help too.
Posted on Jul 07, 2009
Anonymous
  • 27 Answers
SOURCE: I purchased a used 99' Jeep Cherokee in which the
you need to purchase the correct bus cable
Posted on Jan 29, 2010
kenw392
kenw392
  • 2226 Answers
SOURCE: i have a kenwood kdc-c469 6 disc cd changer
try pacparts.com. they should be able to get you a price on a magazine.
Posted on Feb 17, 2010
Kenwood 6 disc cd changer
screw needs to be replaced and making sure the bracket it not bent... thus , not allowing the cartridge to come out,,,
May 12, 2014 | Kenwood KDC-C465 6-Disc CD Changer
Kdc-c517fm. shows 99E and will not release disc holder
From the Kenwood manual:
Something is wrong with the disc magazine. Or the unit is malfunctioning for some reason. 99 E: Check the disc magazine. And then, press the reset button on the unit. If the "99E" code does not disappear, consult your nearest service center.
I hope the rest works for you.
Feb 28, 2011 | Kenwood KDC-C517FM 10-Disc CD Changer
Can not get the magazine to eject have a fuse but everytime i reset the fuse i get a little juice but then nothing, What fuse should be used on this unit and where is the manual eject/
you have to open the cd changer and you will notice that 2 or 3 disc move to the right side under the tray or on top
pusch them back into the cd magazine but don't force the unit and don't move the disc on the tray
now power it again and press eject
good luck
Nov 18, 2010 | Alpine CHM-S630 6-Disc CD Changer
I have a kenwood kdc-c469 6 disc cd changer
Feb 16, 2010 | Kenwood KDC-C469 6-Disc CD Changer
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
CD ERROR DISPLAYS
CD Changers
E01:
E02:
E04:
upside down
WAIT:
Jun 14, 2009 | iLO CA3000V CD Player
I put a small pin in the reset button a few times and that then got the catridge to eject.
Apr 14, 2009 | Car Audio & Video
Gerald,
Kenya.
Dec 01, 2008 | Kenwood KDC-C717 10-Disc CD Changer
CD Changer Not Working
sum have a small reset button where the mag is
Nov 26, 2007 | Kenwood KDC-MP3035 CD Player
Kenwood KDC-C715 10 Disc CD Changer Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
