NEED SCHEMATIC THROUGH THE LIMIT CONTROL
Okay, I've got an answer for you.
If you get a Fan Control Relay that is DPDT, I think you can wire the Low Speed of a two-speed motor to the first N.O. contact, for Heat.
When the Relay trips, the N.O. contact will close, and the fan will run on low.
If it's a two-speed fan, these fans have two windings, the first for low, the second for medium, and both for High.
Wire both windings to the N.C. contact on the second half of the relay.
That way when the temperature drops below your setpoint, both fan windings will be energized and the fan will go nuts.
Of course, this means the fan will NEVER shut off.
And I still don't know why you need high speed in the Cool setting, when your thermostat isn't kicking the Relay.
That's really an interesting question. I'm taking Mechatronics and I could ask my instructor tomorrow. But why do you need high speed on Cool? If it was a Geothermal heating and A/C unit I'd understand, but this is an oil furnace, correct? I ran across your question because I'm thinking of adding a second fan to our wood furnace and was pondering whether to simply wire in the second fan or go with the DPDT.
