Question about Arris DCT6200 DTV Receiver
Motorola dct 6412 wont turn off
Wont power down manually by pressing front panel on/off switch
Posted by colin blakeley on
toadrules
    Novelist:
    Scholar:
  • 192 Answers
Pull the power at the back of the box or the wall, which ever is more convient. then wait for all the power to bleed out of the capacitors takes a minute or two (we call this a power cycle) hopefully it comes back up. might be time to put it to pasture.
Posted on Nov 14, 2013
5 Related Answers
Lashawn Robinson
  • 1153 Answers
SOURCE: problem with displaying functions on motorola dct 6412
If you experience any of these please contact our customer care representatives via the On-Line Contact Form or call 253-2222 (Greater Portland) or 1-800-833-2253 (outside Greater Portland)..
Posted on Aug 20, 2007
Anonymous
SOURCE: motorola 6412
There are no code modules on the box. The box is searching for the appropriate code to download and is not finding anything suitable. Time to call your cable company.
Posted on Apr 04, 2008
Anonymous
SOURCE: Reset Motorola dct 6200 without dvr
turn it off, push the front panel menu button… an onscreen menu will appear that you can navigate with the remote… the last item is reset to defaults.
Posted on Jul 27, 2008
polrob164
  • 53 Answers
SOURCE: i want to hook my pc to my motorola 6412 so i can tv as a monitor
in order to do this you will need to have a pci slot available on your motherboard and purchase a video capture card also known as a tv-tuner card, these cost approximately $50 but you could get one cheaper used (which i recommend), you can then configure the device using windows media center. In addition, in order to connect your PC to your television you will need a graphics card that is capable of providing this functionality.
Posted on Oct 29, 2009
Scott Eckhardt
  • 50 Answers
SOURCE: I need a manual for the interactive program guide
http://broadband.motorola.com/dvr/downloads/URMD2.pdf
Hope this helps.
Posted on Feb 02, 2010
I have a remote control sharp model: RRMCG1240AJSA I want to find the instruction manual to do the code of my decoder Motorola DCT-6412 ?
If you wish to get more details visit the site linked here. Setup procedure and set up codes for many popular brand devices are given. http://electrohelponline.blogspot.com/
Jan 30, 2017 | Sharp Televison & Video
My DTC 6200 converter/decoder was working fine. A few weeks ago I have disconnected it, pull the power cord out of the AC outlet, put the decoder in a safe place. Then when I finish painting, I hook...
Hello
Check out these with your Motorola converter
[1] Verify that the AC power cord is connected to the DCT*
and an AC outlet.
[2] If the DCT* is connected to a switched outlet on another
unit, verify that that unit is powered on.
[3] Press the POWER button on the DCT* front panel instead
of the remote control. The batteries in the remote control
may be depleted
[4] The DCT* may have received a software update and
may not power on while the new software is being
installed. Try again in a few minutes.
OK.
Oct 21, 2011 | Arris DCT6200 DTV Receiver
I keep gettting 'no CC info available' when I I hit the CC button on Proscan(26LB30QD) remote while watching cable. Cable box (DVR) is a Motorola DCX3400 and is provided by Comcast. I can do it from the...
You will not be able to get closed captioning by pressing the cc button on your television remote control. You must turn off the motorola cable box. Yes I did say turn off the motorola cable box. You should be standing in front of the cable box when you turn it off because as soon as it is turned off you must press the menu button on the cable box (not on the remote but on the cable box) right away. If you press menu soon enough after turning it off you will get a hidden menu. You will be able to scroll down to Closed Captioning and choose enable with the left or right arrow. Then just turn the cable box back on and you should have captions.
Dec 30, 2010 | Proscan 26LB30QD 26 in. LCD HDTV
Can't get my hannspree remote to work with comcast
10030 for the comcast dvr remote. Code is from NEC
Oct 02, 2009 | Hannspree HT09 28 in. LCD TV
I press the power switch on my Acer Aspire RC900 and PC shows up on the screen on the harddrive, however the computer won't boot. When I press the power button to turn it off, it won't switch off.
if it wont continue on the booting operation it may be a problem in your memory module.. try cleaning it first... and when you can switch the power on but cant turn it of you should look in the function panel (the pins on yuor mobo where your front panel is connected ) and check if the front panel connection is correct, if its correct your mobo is more likely to be grounded on the casing.
Jul 10, 2009 | Computers & Internet
Vertical stripes on screen.
well, change ur screen their is failure in your screen line & row moudle
Sep 29, 2008 | Televison & Video
Mar 28, 2008 | Arris DCT6200 DTV Receiver
Motorola 6412
Dec 09, 2007 | Arris DCT6200 DTV Receiver
Samsung TV Mode not supported message
check to see if the output is set to 480i. HDMI does not support 480i - http://samsungplasmatvfaq.com/index.php/Display_settings
Oct 08, 2007 | Samsung LN-S2651D 26 in. LCD Television
Problem with displaying functions on motorola dct 6412
Jul 04, 2007 | Arris DCT6200 DTV Receiver
Arris DCT6200 DTV Receiver Logo
93 people viewed this question
Top Arris Televison & Video Experts
Marvin
Marvin
Are you an Arris Televison and Video Expert? Answer questions, earn points and help others
