Question about NRS Rock'em Sock'em Robots
I need to remove one of the arms of one of my vintage Marx Rock 'em Sock 'em Robots because it was attached in an incorrect position. It punches up instead of straight out. It's attached
My Rock 'em Sock 'em Robot cannot knock his opponents block off because his punch is too high. It's just one gear slot off but I cannot figure out how to remove the arm without damaging it. Please help. Thanks!
Posted by Doug Phillips on
I have a vintage RCA Victor turntable from the 50's or 60's. I need to replace the needle housing, but cannot find a model or serial number to look for parts.
Turnatables then used ceramic or crystal cartridges. All you need to do is look for one of them plus something that will fit in the space in the arm. You will probably not find the original cartridge.
Feb 17, 2013 | Audio Players & Recorders
How do i take off the armrests from the bucket seats
  • On most vehicles the arm rest are attached the same way, here is something you can try...Put the armrest in the upright position. Look along the bottom and sides of the armrest where it connects to the body of the seat. There should be small circles like tabs if the armrest is made of plastic, and there should be a seam that you can look through if the arms are made of cloth.
  • Pop out the tab or peel back the fabric to reveal the holding mechanism. If the chair is screwed in then you'll need a screwdriver, and if there's a nut or a bolt then you're going to need a socket wrench.
  • Hold the armrest up and make sure it doesn't move. Unscrew or unbolt the arm from the bucket seat. Pull the arm outwards once the hardware is removed.
  • Nov 13, 2012 | 2007 Dodge Grand Caravan SXT Minivan
    My Dual CS 1264 Does not work. The arm swings out over the record, drops slightly and then returns to its resting position on its base
    It seems that the special grease is old. There is a wheel moving the toneam. Remove any old grease from it and try again. If you need further instructions or a way to get new grease please refer to www. dual-board.de This is the worlds largest knowledge base for vintage Dual turntables. It is in german, but feel free to post in english, most people here in germany speak english, too.
    Mar 24, 2012 | Dual Audio Players & Recorders
    Left windshield wiper stopped working, what could be the problem?
    At the base of the wiper arm there is likely a plastic cover or cap. When you remove that cap or cover there will be a nut that holds the wiper arm to the post. Align the arm back to it's proper position and tighten the nut. Typically they are aeither a 15 mm or 13 mm nut.
    I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
    Jun 24, 2011 | 2001 Isuzu Rodeo
    How do you change the wiper motor on a 1994 Jeep Cherokee
    Not a terrible job. Remove the wiper arms from the studs (held on by swing out stainless retainers at bottom of the arm on the stud) Then remove the cowl (six or so screws and it lifts off). remove the screws that hold each stud in place and the brackets that hold the motor in. The entire assembly then comes out. You need to twist it into exactly the right position. Not difficult but annoying.
    You then can separate the motor from the linkage (transmission) and replace it. On some models you can do that in the car but taking everything out has always been the easiest way for me.
    Installation is the reverse of removal. careful not to pinch squirter hoses. Whle it's out inspect the transmission linkage arms for cracking as many stress and break.Run the motor without the arms attached then turn them off so they park. You can then position the arms correctly.
    May 21, 2011 | Jeep Cherokee Cars & Trucks
    How do you take apart the ring for the Rock -em Sock-em Roabot game? I want to be able to put it back in the box so I can donate the game. Thank you!
    There is a little slit on the back part of the foot plate where the feel go in. If you put a small flat screwdriver in there and pry just a little it pops right off. then the trigger apparatus can slide out
    Apr 30, 2011 | NRS Rock'em Sock'em Robots
    I was cleaning the dust out of the feed dog area and somehow disconnected the feed dog from the lever in the back that raises it and lowers it. How can I reattache them?
    A feed system for a sewing machine having a frame, a horizontal arm shaft journalled in said frame, a vertical arm shaft extending downwardly from adjacent said horizontal arm shaft, means rotatably connecting said horizontal arm shaft to said vertical arm shaft, said feed system comprising a cam fixed to said horizontal arm shaft, a sheet metal feed fork having parallel bent over portions at one end thereof embracing said cam and in driving engagement therewith, a feed rock shaft supported in said frame and having an arm connected to the other end of said feed fork, feed regulating means carried by said frame and connected to said feed fork for converting motion induced by said feed cam to oscillations of said rock shaft, said rock shaft being formed with a pair of upright rock arms on the other end thereof, a horizontally disposed U-shaped sheet metal feed dog carrier having each end thereof connected to one of said upright rock arms, said feed dog carrier having a horizontal shelf extending from the base of the U between the ends thereof, said shelf supporting thereon a feed dog, means for attaching said feed dog to said shelf, a stud affixed to said base of said feed dog carrier beneath said shelf, a sheet metal lift lever pivotally supported on a horizontal axis in said frame substantially parallel to said rock shaft, said lift lever having a slotted end for engagement with said stud extending from said feed dog carrier, said lift lever having the other end thereof supporting a cam follower adjacent said vertical cam shaft, and a lift cam removably affixed to said vertical cam shaft and in engagement with said cam follower on said lift lever.
    Take care.
    Oct 20, 2010 | Kenmore 19110 Computerized Sewing Machine
    Where is the cam sensor on a 2005 dodge neon sxt 2.0
    Camshaft Position Sensor-On top of engine Operation The Engine Management System (EMS) uses the camshaft position sensor to manage sequential fuel injection and as part of misfire diagnosis. The EMS constantly monitors the number of pulses on the signal circuit. The EMS compares the number of camshaft sensor reference pulses and the number of crankshaft position sensor reference pulses received. If the EMS receives an incorrect number of pulses, Diagnostic Trouble Codes (DTCs) should be stored in the EMS. Some engine management systems will then default to multi-port or "gang-fire" injector operation. The camshaft position sensor signal is required to sequence the injector operation to the proper cylinder timing. If the camshaft position sensor or circuit is faulty, most engines will start. However, the EMS misfire diagnostic will likely be affected.
    The following symptoms can be caused by an intermittent wiring connections or faulty signal to the EMS.
    Related Symptoms
    • Extended crank time with a cold engine
    • Intermittent rough running
    • Unstable idle
    • Bucking
    • Hesitation
    • Stumble
    • Chuggle
    • Poor fuel economy
    • Stalling on acceleration
    Aug 05, 2010 | 2005 Dodge Neon
    Windshield shutters while in delayed mode, it
    Excessive grease in wiper motor. Motor needs to be removed and the grease cleaned out. Regrease only the areas needing to be greased.
    There is also a recall for this vehicle for the wiper module. Call the dealer with your vin # to see if it has been done. I will post the instructions for motor removal and install.
    1. Turn the key to the OFF position.
    2. Open the hood.
    3. Remove the three push-in retainers that attach the air inlet grille (leaf screen) to the plenum sheet metal.
    4 . Lower the hood to the secondary latch.
    5. Using a suitable marker or masking tape, mark the location on both wiper blades on the windshield.
    6. Remove the covers from the nuts that attach the wiper arms.
    7. Remove the nuts from the wiper arms.
    Important
    If the rocking action in the next step fails to loosen the wiper arm, it may be necessary to use a standard top-post battery cable terminal puller to remove the wiper arm.
    8. Rock the wiper arms back and forth to loosen and remove them from the wiper transmission shaft.
    9. Remove the antenna mast.
    10. Remove the 10 mm hex head nut that attaches the left and right ends of the air inlet grille to the plenum sheet metal.
    11. Remove the air inlet grille and reposition it up to the windshield. It is not necessary to disconnect the washer hose.
    12. Remove the two 10 mm hex head bolts that attach the wiper module to the plenum sheet metal.
    13. Disconnect the electrical connector.
    14. Position the new wiper module to the vehicle and connect the electrical connector.
    15. Install the wiper module in the plenum sheet metal.
    16. Install the two 10 mm hex head bolts that attach the module to the plenum sheet metal. Tighten nuts to 30 N·m (22 lb ft).
    17.Turn the ignition switch to the ON position, turn the wiper switch ON, and visually verify that the wiper transmissions operate. After visually verifying operation, turn the wiper switch to the OFF position and allow the wiper transmissions to stop moving before turning the ignition switch to the OFF position. The wiper motor will now be in the PARK position.
    18. Using the marks or masking tape that were placed on the windshield, align and position the wiper arms on the wiper transmission shafts.
    19. Install the nuts on the wiper transmission shafts. Tighten the nuts to 30 N·m (22 lb ft).
    20. Install the covers on the wiper arm nuts.
    21. Remove the marks or masking tape from the windshield.
    22. Open the hood.
    23. Install the three push-in retainers that attach the air inlet grille to the plenum sheet metal.
    24. Close the hood.
    25. Verify that all functions of the wiper system (low, high, delay, etc.) operate properly.
    Apr 02, 2010 | 2002 Chevrolet TrailBlazer
    Pontiac montana wiper reterned in up right after
    While wipers off in parked position, remove wiper arm and re-position arm to correct stowed position.
    Re-tighten any wiper arm attachment nuts/screws etc.
    Check wiper attachment arm for damage or cracks at the spigot mount. Replace if damaged.
    Jan 21, 2010 | 2002 Pontiac Montana
    NRS Rock'em Sock'em Robots Logo
    51 people viewed this question
    Top NRS Toys Experts
    Marvin
    Marvin
    Tom Chichester
    ray gallant
    Are you a NRS Toy Expert? Answer questions, earn points and help others
