Question about OEM Systems Dell Inspiron N5010 N7010 Xps 15 Blu-ray Optical Drive Dvd-rw Bd-rom Ct30n
HL-DT-ST-DVDRWBD CT30N That is the CD-ROM of my labtob,not work properly.So I hope to fix or change with a new one.
Posted by tarek on
Brian Sullivan
  • OEM Systems Master
  • 27,725 Answers
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem
"you only need to do the following"
if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it
Posted on Oct 11, 2012
  • Gaurav Gawade Mar 10, 2013
    Mr. Brian Sullivan, Thaks a lot, this solution has immensely helped me. :)
  • Brian Sullivan
    Brian Sullivan Mar 10, 2013
    No problems hope its all good for you now
Fix DVD/CD ROM to work Acer M1610, Computer not detecting DVD/CD ROM. No drive is seen how to fix this, what are my options. OS is Vista
Hi rossclark3,
Try to check the jumper settings of your DVD/CD ROM if it is properly assigned as Master or Slave.
Afterwards, also check the cable connecting the DVD/CD ROM to the motherboard.
Finally, restart your PC and check the BIOS Setup if it can already detect your DVD/CD ROM.
Hope this helps you a lot.
Thank you for using FixYa!
Oct 29, 2011 | Computers & Internet
Dvd player not reading the files
There could be a lot of reasons why your drive is not working properly. It could be that there is a service from your burning software that is not running properly thus affecting the CD-ROM. If you have any of these software, try un-installing them.
You can also try this for an automated fix from microsoft.
heres the link: http://support.microsoft.com/gp/cd_dvd_drive_problems
Read and follow the instructions.
Hope this helps.
Jul 02, 2011 | Compaq (120192-B21) CD-ROM Drive
Hai sir i want to reinstall win xp in asus k8v-mx sata hdd system but it cant found the cd drive what i do?
For checking:
1.cd rom/dvd rom is functinal/ working properly
2. sata cable is ok.
3. cd window xp is clean and clear.
if all that okay, try again reinstall.
if 1 and 2 is okay, you should see the cd rom in [my computer]
so, what you need now is try to clean your cd/disk with suitable cleaner. if you dont have it, you can try with perfume with have alcoholic. clean using soft tissue and make sure no dirt at that disc.
You say, you cant found cd drive?
in [my computer] or during setup?
if your pc still can log on. try log on window, open my computer to see and check your cd drive have no problem.
try ..and request again. im here until 5 pm..hope can help you
May 14, 2011 | ASUS K8V-MX Motherboard
My dvdw/r is not working properly,led is blinking continously
Actually u have to buy for a new and better cd rom, but if ur in tight situation the only solution is FiX it urself! I always do this, going at the junkyard and pick some cd rom.!
Open ur cd rom, u will see the lens, in the side of the LENS assembly there are 2 fine tuning resistor adjuster, use a precision screw driver(wutever that can fit on it), mark the adjusters before turning it back and forth. Just like ur cleaning up the contact point.After that return the adjusters to the original position!
Thats it! It will work fine now!
Hope that helps u out!
Now RATE ME!
Nov 20, 2010 | LG DVD-ROM Drives, DVD Readers:...
This drive reads a dvd but not cds. do you have
may be it's only a DVD ROM drive not a combo,
you will need a combo to read both DVD and CD
if it was reading CDs earlier then the CDs might have scratch in them, try with new CD.
did u make changes to the cables inside, if you did check if the cabels are connected properly to the drive
Dec 06, 2009 | Sony DDU1613 16X DVD-ROM Drive, Black...
System reboot
Depending on what bios it has it may not show the cd drive. All you can do is set it to auto or if it has the option to cd or atapi. Then set the boot order so that the cd is looked at before the hard drive and you should then boot off of the cd.
Oct 24, 2009 | Acer Aspire 3610 Notebook
My cd/dvd (sh-s182d )rom read cd only but it wont response
CD/DVD ROM drives like yours employs two lasers to work properly, one for CD read function and the other for DVD read function.
It seems that your laser for DVD reading is either dirty or damaged.
Try an optical drive cleaner, if that does not fix it, you are going to have to replace the drive. If you have warranty then replace it or have it fixed. However, if your warranty has expired then the best thing to do is to buy a new one. They are not expensive these days so the price difference between fixing it and buying new should not be huge.
A lens cleaner disk should be available from most computer shops.
I assume you have proper software for DVD video playback like PowerDVD, VLC media player etc.
Oct 08, 2009 | ASUS Computers & Internet
Ununtu wont boot from cd
Here are two things you can try:
Easiest First,
While booting tap the F12 key to force boot from cd-rom
Boot to bios and change boot order to cd-rom first
this can be done by tapping F1 while booting
May 13, 2009 | Toshiba Satellite A105-S4164 Notebook
Cd/dvd dosen work pleace geimy a solution
i cant get you. cd/dvd is not working or cd/dvd rom drive is not working ? To work cd/dvd rom drive properly, Make sure the Jumper settings of the drive is set to slave or else remove all the jumpers from the cd/dvd rom drive, it automatically sets to slave. Check the power cable and the FRC(flat ribbon cable) of the cd/dvd rom drive. Hopefully it should work. Thank you.
Sep 11, 2008 | Computers & Internet
Recovery
this is a READ error known as a CYCLIC REDUNDANCY READ ERROR.
If the CD ROM is not able to read from the disc .. it gives u this error
This can come due to many reasons
1. OLD CD ROM - not able to read data properly
2. CD with lot of scratches
3. CD not written properly: Data not burn properly on CD at the time of its make.
Solution: Try to insert a new CD in it and then check whether it works or not
or get a CD LENS CLEANER DISC which will remove any kind of small debris on the lens on the CD ROM and then it will work.
This would surely help
Feb 19, 2008 | Computers & Internet
OEM Systems Dell Inspiron N5010 N7010 Xps 15 Blu-ray Optical Drive Dvd-rw Bd-rom Ct30n Logo
2,024 people viewed this question
Top OEM Systems Computers & Internet Experts
Lucky
Bill Boyd
Dayton Computer
Dayton Computer
Are you an OEM Systems Computer and Internet Expert? Answer questions, earn points and help others
