Cars & Trucks Logo
Joseph Johnson Posted on Oct 10, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I got a radio out of a 2005 cad.w/ cd/cassette,what i need to do to put it in a 97 cad without acd player
ivan whisker
Level 3:
Genius:
  • Cars & Trucks Master 1,164 Answers
  • Posted on Oct 10, 2012
ivan whisker
Level 3:
Genius:
Answers
1164
Questions
9
Helped
302261
Points
2628
Not sure on model but you should be able to put it straight in any car as long as the gap for cd player is big enough
you will have to do a little experementation with the wires sorting out the speaker wires earth and live once you have done this conect them to the cd player wires and bobs your uncle some times you can buy proper wire harnesses that go onto existing wires and the new harness plugs straight in but when fitting the live put an inline fuse onto it saves burning out the one in fuse box or the cd player but should be straight foward hope this helps ivan
Marvin
Level 3:
Top Expert:
  • Cars & Trucks Master 85,242 Answers
Marvin
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29025006
Points
266281
You can try to get this info from this company www.crutchfield.com
5 Related Answers
Anonymous
  • 1010 Answers
  • Posted on Jun 26, 2008
SOURCE: CD stuck in CD player. Cassette and radio works good. But CD stuck.
This symptom is often a sign the player is nearing its end of useful life. But, sometimes it is merely due to a collection of dust, dirt or a foreign object lodged in the mechanism. Sometimes it is a logic error inside the electronic memories.
So, there are a number of possibilities.
Here is what I would do:
ONE: Do NOT force it or use tools to pull the disc out.
TWO: If you can find the wires that supply the 12 volts to the unit, pull that wire so there is no power to the unit whatsoever for at least 30 seconds. That will reset the electronics inside the player.
THREE: IF you cannot find the wires, or if they are too hard to get to, you can pull the plus cable off the battery; raise the hood and with a wrench loosen the bolt holding the plus cable onto the battery terminal. Pull it off for at least 30 seconds or longer, then put it back on. This will perform a hard reset as in TWO.
FOUR: If still no removal try this technique:
http://www.wikihow.com/Remove-a-Stuck-CD-from-a-Car-CD-Player
If it is not an expensive unit you may find it a superior investment to purchase a new player rather than pay a tech to repair it. (In the worst case the unit must be pulled, cover removed and disc manually removed; then you may find out there are damages or defective circuits awaiting further repairs; probably looking at a charge of $75 or more if you go to a service shop).
Let's hope the ideas above kick it out and it returns to normal useage.
Anonymous
  • 1861 Answers
  • Posted on Sep 08, 2008
SOURCE: CD Player and Cassette player not working, radio still does
If you are using a "burnt" CD, expect this to happen. This is common.
Anonymous
  • 1990 Answers
  • Posted on Jan 21, 2009
SOURCE: Does an Audi concert cd/radio number 8E0035186 fit a 2002 A6
It should fit with no Modifications.
alicantecoli
Colin Stickland
  • 22516 Answers
  • Posted on Jan 31, 2009
SOURCE: 2004 Volkswagen Beetle Radio/CD player
new one with a usb connector and sd card reader is better and cheaper
Anonymous
  • 2004 Answers
  • Posted on Mar 17, 2009
SOURCE: Need Toyota radio security code
In my country Nigeria it is not an issue at all. But you can make do contacting Toyota with your Vin No. and proof of ownership. http://www.toyota.com
2answers
I have a 1996 Nissan Maxima with a factory Bose CD player / cassette and radio and it will not turn on what's the solution
Maxima Bose Radio ' eBay
www.ebay.com/bhp/maxima-bose-radio
eBay1995 1996 1999 Nissan Maxima Pathfinder Infiniti J30 Radio BOSE CD tape Player ...Will fit and work in these with BOSE audio package only:1995 - 1999 NISSAN .... 2006Nissan Maxima OEM Bose Cassette & 6 Disc CD Player Radio CR13B ...DESCRIPTION Unit is missing some bottons, 3 of them, this item has NOT ...
Nissan Maxima Bose Stereo ' eBay
www.ebay.com/bhp/nissan-maxima-bose-stereo
eBayWill fit and work in these with BOSE audio package only:1995 - 1999 ... 1996 - 2000 NISSAN Pathfinder. 2004 2005 2006 NISSAN MAXIMA FACTORY BOSE STEREO 6 DISC ... Factory NISSAN INFINITI BOSE Radio, Tape, and CD Player. ... 6 Disc AM FM Stereo Cassette Radio Bose OEM LKQ (Fits: Nissan Maxima).
Nissan Maxima Car Stereo Removal and Repair - YouTube
? 8:52
https://www.youtube.com/watch?v=RT-SZEfeA4Q
Sep 16, 2012 - Uploaded by Factory Car Stereo Repair
Factory Car Stereo Repair .... I have nissan maximal 05..the CD part turns on but the cd won't eject...should ... I have a 2005maxima non-bose radio system. ... my speakers is super in my 05 maxima but my cd player keeps on ...
Nissan - Factory Car Stereo Repair
Disc will not load into subaru forester cd changer
This also happened to my 2002 WRX. I took the CD player out of the console and found a tiny spring (which I could not find) was not in its location, which would actuate the "play CD" switch inside. After a few hours I decided to reassemble the player and use it as a non-CD unit. The radio and cassette player still work, so I purchased a cassette MP3 player adapter so I can plug in my cell phone and play songlists.
1helpful
The CD player no longer works in my 2005 KIA Sportage
Have you tried different cd's?I f so then the loading tray may be at fault.If you don't want to fix it here is a solution.Buy a cassette adapter with a 3.5 mm connector and use a mp3 player you can transfer your cd collection to your mp3 player via you computer
How do i replace radio cassette player with a cd player mazda 6 2002
Don't replace it. Go to Walmart and buy an adapter. It is usally at the check out somewhere and It cost about $5.00. It has a cassette that goes into the cassette player. Then you plug your ipod or whatever into the attached wire. Doesn't look cool but it works and it is inexpensive. The adapters with the cd player attached skip (we had one 20 years ago) so just buy the new kind of adapter for less and play all your up to date gadgets. Put your cd songs on your ipod or iphone. Our son uses one in his truck with his little ipod shuffle. No cd player needed.
I purchased a 1997 Honda accord Se for my 16 year old daughter but the radio/cassette doesn't work. I want to put in a cd player without paying a fortune, what is my best option?
i would recommend purchase an aftermarket cd player. you can also purchase a cd player is dash kit. that will come with the wire harness connector and the brackets to hold it in place.
Will the wireing from a 2005 chev radio cassette
It will work as long as it's for a GM cd radio but as mentioned it will have to be re-programmed by the dealer.
If it's an aftermarket cd player, you'll require a separate module harness with a relay circuit for the airbags and tach information to function. Or you can purchase a re-location kit which allows you to locate your factory radio into your trunk to hold those funtions. The re-location kit is a fair bit cheaper than the module. It's stupid that GM would design a system like that but that's what you'd need.
97 Jeep GC CD player plug
The plug behind the dash is the same.
3helpful
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
