Question about Karcher 2500 PSI Pressure Washer
I have a wood splitter that has a honda GCV160 5HP engine, when I choke it to start, it does find, but when I push the choke in, the engine will not run smoothly, it acts like it's not gettingg en
Posted by Ronald Uyeno on
Steve
    New Friend:
  • 11 Answers
Sounds like debris in the carburettor. The carbs on these are relatively simple things which come apart easily. Check for debris or water in the float-bowl, and ensure both your idle and main jets are clear and you can see daylight through them.
Posted on Oct 10, 2012
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: Karcher pressure washer with Honda GC160 engine only runs on chok
You need to remove the carb bowl, then with a small flat screwdriver remove the jet. ( on the side, at the bottom of stem.) take a small wire or toothpick and clean the gunk out of the jet, reassemble and open fuel valve, start, and pat yourself on your back.
Posted on Aug 04, 2009
Martin Grech
  • 94 Answers
SOURCE: Karcher 2600 (Honda engine) has lost pressure.
Dear Modad,
First one must see if the problem is in the Honda engine or in the pump. So you must try the Honda with no load. You can remove the gun from the pump, but leave the water supply going into the pump. In this way you still have some cooling effect from the water. Now with no load you try the Honda engine. If it is possible tune and set the Honda engine to work correctly. Now if the Honda runs smoothly,...then the problem is in the pump. Regarding the pump try the system by attaching the gun with no NOZZLE/ or LANCE. Open and close the gun to see reaction of Honda Engine. If in this case the Honda runs OK....then attach a NOZZLE so that you have pressure and load. If the Honda starts to die down, this could be that the Honda needs servicing. This like having a car and uphill it will stall and dies down. Here the engine needs servicing. One small thing to look for. I came across Honda driven pumps which have a cable coming from the Honda's carbureter to the head of the pump. When the gun is released the cable is pulled from the head of the pump by means of a piston type valve and this in turn will reduce the speed of the Honda. As you see it is difficult for me to pinpoint the real cause when I do not know the model number and type of pump you have. But if you go by these guide lines you shuld find the fault. Remember...ALWAYS try HONDA ENGINE without load first. I also wish to add that the Honda could be working OK...but then the pump has some problem that it is stopping the Honda. So the pump could also for some reason be jammed and this needs the pump to be serviced. Another hint is very simple. If the Honda is not getting to its maximum power and revs...then the pump will drop pressure.
I gave you various hints to tackle the problem by simple elimination. But you must be able to know how to service the Honda or Pump yourself. To repeat and remind you...check the honda and service the Honda with NO LOAD!! Thyen tackle the PUMP.
Regards,
Fulltech.
Posted on May 24, 2009
Anonymous
SOURCE: Katcher pressure washer w/ 5hp Honda Engine
pour a bottle of carburettor or fuel injector cleaner in the fuel tank, replace the spark plug and set the spark pluglug gap at 0.7mm. Replace the air filter element. Also change engine oil if necessary (mobil 10w30 synthetic.
Posted on Feb 03, 2009
kel1guy2002
Kelly
  • 3740 Answers
SOURCE: Honda motor only runs with choke fully on.
Lets back up and regroup on the carb cleaning.
Before you start.... if you have a digital camera take "close up" PICTURES of the linkages and springs attaching to the carb. If this is your first time you will be so glad you did. You can always delete them later if you don't need them. :)
Here is what you need to do:
1. Fuel selector off
2. Remove float bowl mounting screws and nut
3. Remove the BRASS Jet / Orifice in the very bottom of the venturi tube inside the pickup tube. (Flat blade screwdriver) Hold the Orifice up to the light. You should see a pinhole. If it is not clear clean the orifice but do not force anything through the hole.
4. Underneath the Orifice there is yet another BRASS tube that you need to remove. (Flat blade screwdriver) Make sure all of the holes in the tube are clear. The tube will be over 2 inches long. Clean it and reinstall it.
5. Reinstall the Orifice.
6. Using a catch fuel container turn on the fuel selector. Fuel should flow at a good rate. GENTLY lift the float assy level and make sure fuel flow shuts off. When you drop the float again fuel should flow.
If you do not have fuel flow at this point the needle and seat will need to be inspected. Fuel selector OFF.
(The following procedure is to be done only if there is no fuel flow with fuel selector on.)
a. Remove the silver float pivot pin retaining screw
b. Drop the Float down (The needle will come off with the float. NOTE the position)
c. Inspect the tapered rubber of the needle If should be pointed. If it is not pointed then the rubber tip is stuck inside the seat.
d. Clean the seat hole ONLY if obstructed. (Easily damaged)
e. FUEL Selector on then off fuel should rapidly flow through the needle seat.
f. Renistall Float and needle making sure to get the pivot / hinge pin installed correctly and reinstall the silver retaining screw.
g. Fuel selector ON. Raise and lower float checking for free movement with fuel flow when lowered and stopped when the float is raised level.
NOTE if fuel does NOT stop when float is level you will need to bend the float tab (tab up if level is too high or tab down if level is too low) where the needle attaches to the float assy until it does.
7. If there still is no fuel flow at this point remove the fuel hose from the carb and check fuel flow. If no flow check that gas tank exit hole, fuel filter (if installed) and the selector valve assy for obstructions.
Reassemble connections.
FUEL FLOW IS GOOD
Step 8 is VERY important"
8. BEFORE you install the float bowl inspect the bowl nut. There are 2 holes in the side of the nut where it screws in to the bottom of the carb that must be clear.
9. Install Float bowl mounting screws and nut. Check for leaks.
10. Test engine.
That should do it.
Thanks for using FixYa.
Kelly
Final note... if it does NOT start after this there are other problems we can discuss. i.e compression and spark "how to."
Posted on Apr 23, 2010
Tim Venetis
  • 260 Answers
SOURCE: Karcher 2500 with Honda GVC160
Make sure the governor linkage is clean and works freely. A lot of times when you put a load on the machine, use it it stopps the fluttering.
Posted on Mar 19, 2011
Testimonial: "It is lopng pretty bad and will stop if let alone. This machine is about 2 years old and as I recal it started running rough in the middle of washing "
My wood splitter won't push through the wood
There is usually a hydraulic pump on those units. Check and see if it is low on oil. Check and see if there is a shear pin that has broken on the shaft that goes to the pump.
Nov 16, 2017 | Electric Garden
Can u send me the Honda gcv 160 cc and 21 lawnmower engine start video step by step in my mail id
1 - make sure ignition switch is on
2 - make sure that gas switch to motor is in "on" position
3 - Set choke to start position
4 - fill with gas
5 - Pull on starter till starts then push choke back in.
Jun 10, 2017 | Honda Garden
Engine kicks back when pull starting why?
not pulling the cord hard enough or the ignition timing is out.
Sep 29, 2016 | Honda Cars & Trucks
Start OK but if after warm up I push the choke to run, the engine stops, I used 4 time before and idled OK
Push choke to run???then not use on a all ready warm engine you mean you push the GAS lever ? remember a choke can work as a throttle for the engine. it can have a double function if your electric start contact is damaged you can use it to stop the running engine also.
How long you are owner of the machine , read the manual about it !
If before it worked good on this kind of proceedings as described ? then if you mean you push the gaslever to run Try it to do it again without the airfilter. I THINK YOU HAVE An AIR problem by carburator if its so clean the airfilter if its not to old. or replace
You can use for short time the choke in most cases minimize use of the choke short not more then 2 times max you pull.or electric start.
AND very important control in any case allways for THE RIGHT OIL level !!
If the engine is warm(hot) do not use the choke forget it it has no use. control your spark plug electrode i think you will find the cause.
Oct 12, 2015 | Ryobi Gas Pressure Washer: 3100 psi 2.5...
Wood splitter is pushing hydrolic fluid out fill tube on the return stroke
make sure that the ram is in the fully retracted position
empty oil reservoir until the oil level is at the required position normally about 1/4 inch below filler plug
if oil is added with the ram at any extension then the extra oil will be pushed back into the reservoir and over flow out
Jun 19, 2015 | Swisher 28 Ton 11.5 HP Log Splitter -...
I just bought a 1999 Honda Aero and it did not come with an owner manual. Where is the choke on this bike. Is there any free down loads with "getting started" on the Honda Aero/shadow of this...
The choke is on your left hand handle bar, it is the black slide down lever. 1. Push the lever inward to choke the bike 2. give the throttle two turns and start the bike. ( do this so you don't drain your battery, even with a new battery you need give the bike the gas to start or you will have to recharge the battery) You will hear the engine change pitch when it warms up, push the choke upwards and the bike should idle on its own.
Mar 05, 2011 | 1999 Honda VT 1100 C3 Shadow Aero
Hi, I bought a used motorcycle (hero honda splendor+), I dont know anything about choke lever. Please tell me what is the use of it ? Advantages & disadvantages of it? And finally which position...
How to use your choke correctly. The choke is only to be used for starting a cold engine. If it is a lever, usually you pull it up for on , and push it down for off. look for some type off arrow, or up & down. To start your cold engine, turn on fuel tap, give full choke, turn key on and press starter or kick start, it is very important that you do not use the throttle while starting with the choke, just turn the key on, and press the starter with full ckoke, and no throttle. Once the bike fires and starts, turn down the choke a little and find a idle, after a few minits, you can turn off the choke and ride off. The use off the choke is only for starting a cold engine.
Aug 02, 2010 | Hero Honda Splendor Motorcycles
How do i adjust the choke on a 2005 honda shadow
http://www.bikebandit.com/houseofmotorcycles/2005-honda-motorcycle-vt750dca-shadow-spirit-carburetor-component-parts/o/m2904sch406961
Not to sure about this one, ok, if the choke wont stay out, then try to trace the choke cable to the carby, have a close look and see which parts move on the carby when you activate the choke, some thing just needs to be tightened up, so that the choke stays on. Also, you say the bike stalls and runs rough, is this with the choke on? If yes, then that is just a sign that you dont need so much choke on. Just try half choke. Do you live in a warm climate? if so, then you dont need much choke . So there is no adjustment really, only by the amount of choke you apply. Also remember, never use the choke if the engine is already warm. And, only use the choke for the first start of the day, when the engine is stone cold. The correct way to to start a cold bike engine is, pull the choke on fully, crank over engine, but DO NOT give it throttle, (this defeats the purpose of using the choke), when engine fires up and starts, slowly push the choke in till a smooth, high idle is acheived. You should be able to ride off slowly, and push the choke off after about a mile.
May 23, 2010 | 2005 Honda VT 750 DC Shadow Spirit
Having trouble starting the Honda HG 110 tiller. \r\n When it does start, when I push the choke lever back in the upward position, the engine stops. Is it necessary to "give" it gas when attempting to...
When starting open gas feed a little (enough to start but not flood) . Do not set choke in extreme top position rather rev engine adjusting slightly to where it holds revs. the best as the choke adjusts air flow to burn the fuel.
Dec 10, 2017 | Honda Garden
Karcher 2500 PSI Pressure Washer Logo
823 people viewed this question
Top Karcher Garden Experts
Martin Grech
John Trevino
Bruce Robin
Are you a Karcher Garden Expert? Answer questions, earn points and help others
