Question about GE Washing Machines
Ge hydrowave hums when i hit start - GE Washing Machines
Posted by m_slack_1 on
Sidharth
    New Friend:
  • 41 Answers
Make sure there is water in it, its hydro sensor may not be working
Posted on Oct 10, 2012
GE Hydrowave top loading washer is leaking around the top side and back of unit when filling.
check for the water outlet from the water solenoid control valve
it may be displaced or broken and not directing water to the bowl
Sep 29, 2016 | GE GTWN4250MWS 27" Top-Load Washer, 3.7...
How do i find the error codes for a wpre6150k2wt?
Hello, Here is the website for repair manual with error codes to download you are looking for: HydroWave GE Washer Repair Guide
May 25, 2014 | GE Washing Machines
My Ge Top load washer will not power up start button?,no lights.
Their is a fuse in the harness red wire that runs down from the control to the motor on the hydrowave washer. Hydrowave washer manual
Of course if yours isn't a hydrowave maybe you oughta post a model number. GE has several different styles.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 09, 2013 | Washing Machines
Error code 4 on a ge hydrowave
There should be a double digit error code.
Oct 15, 2012 | GE WCCD2050JWC Top Load Washers
GE microwave JE1660WB001 does not heat makes humming sound
The magnetron has gone and is the heart of the microwave oven, this part is the most expensive to replace, cheaper to buy new in the long run.
Apr 19, 2012 | GE JE1660 Microwave Oven
My Ge Hydrowave doesn't know what cycle it's in. It agitates when in spin cycle and doesn't spin at all.
That problem with your washer sounds like its the mode shifter solonoid,To check it use a multimeter set to ohms and measure for appx. 98 ohms on that solonoid coil.
What you can try first though is to reset the motor control baord and that remedies so many troubles with the Hydrowave washer. This tip i wrote will tell ya how to reset the motor board.
http://www1.fixya.com/support/r10292912-will_ge_hotpiont_top_load_washer_not
GENE
Sep 21, 2011 | Washing Machines
I have a ge hydrowave top load washer. it wont drain...any suggestions?
Check the filter on the drain pipe and clear any muck accumulated there and also check that the drain valve is working or not. A thorough cleaning should solve the problem...............................sodeep
Jul 31, 2009 | GE Washing Machines
No agitation in ge hydrowave rinse cycles
you must unplug the washer for just 1 minute open and close the lid 10 times and plug it back in and put it on a light load cycle and let it wash with empty load. shoul work fine after that
Dec 01, 2007 | Washing Machines
Washing Machines Logo
42 people viewed this question
Top GE Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Mike
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
