Question about LG LDF7932ST Dishwasher
Dishwasher Leaks Dishwasher has worked fine for 15 months and started leaking from the bottom left of the door panel. I had a repairman come out and he said it was the door gasket. I didn't agree since the door itself doesn't leak, only the bottom left vent. But I replaced the door gasket and it still leaks. I called him out again and he removed the door panel. Now he says it is the steam vent assembly. He also mentioned wax seal. Which part do I need to replace and is it covered by the 2-year parts warranty? Is this a chronic problem with LG dishwashers or was there a recall? There are several comments about this same type of leak.
  • Debbie Landry Oct 11, 2012
    The suggested solutions are for a washing machine. My problem is the DISHwasher. The repairman said I need to replace the steam vent assembly because the stopper is opening during the wash cycle. It should only open during the dry (steam) cycle. I'm trying to see if anyone has had this same problem and what the fix was.
  • LG Master
  • 2,530 Answers
Find a new repair person
Posted on Apr 08, 2017
2 Suggested Answers
Anonymous
  • 37 Answers
SOURCE: LG front load washer leaks from door gasket
This is best left for a proffessional to repair
Affordable Appliance Repair
LAke Forest, CA. 92630
Posted on Aug 22, 2009
Anonymous
SOURCE: Replacing LG Dishwasher door gasket/seal with Part # 3920DD3005A
Problem solved - it was not the gasket - it was the vent tube as defined in one of your on-line reported solutions. Thank you!!!
Posted on Oct 14, 2009
Testimonial: "Contacted numerous resources to try identify LG dishwasher leak problem, including LG. Found solution,vent tube right here on FixYa. Many thanks!!!!"
Pump keeps pumping unless turned off at wall
The reason our Asko D3250 had this problem was because of a leak. The pump hose (approx. 2" black rubber hose - find it here http://www.repairclinic.com/PartDetail/Pump-Hose/8801409/1810263) was split, causing a leak and the blinking heavy wash light. The sensor did its job and picked up the leak.
If you're handy you don't necessarily need to call a repairman in to accomplish the work. You don't need to pull the front of the dishwasher apart. Unplug the power to the dishwasher. Take off the back bottom panel. Next, test where the leak is coming from. Place pans below the holes found on the bottom of the dishwasher. They are visible when removing the back panel and are most likely at the rear of the dishwasher. Plug the power back in then start the dishwasher. If your problem is a leak, you will easily spot it with a flashlight. After ordering and installing your part, make sure to dry all water that has settled in the bottom of the dishwasher. You can easily accomplish this through the back of the dishwasher with the panel removed. If it's still damp the sensor will continue to detect water. Once dry, start the cycle to make sure there are no more leaks before reinstalling the panel.
Jun 10, 2013 | Asko 24 in. D3112 Free-Standing Dishwasher
PUMP WONT SHUT OFF after wash cycle
Apr 08, 2013 | Asko Dishwashers
Asko dishwasher heavy wash light flashing and pump continually drains even with door open
Aug 09, 2012 | Asko 24 in. D3250 Built-in Dishwasher
Dishwasher leaks after it fills up and starts to wash
Make sure the dishwasher is level. If the water is leaking from the door, you should replace the door gasket.
Water under the dishwasher could be from a leaking hose or loose hose connection. Check these by removing the bottom front panel.
The pump seal may need to be replaced. If you are not real handy, call a repairman for this replacement.
Sep 19, 2010 | KitchenAid Dishwashers
My whirlpool dishwasher is leaking water from the bottom of door
Water is being forced out under the bottom door seal. Is the lower spray arm melted on the bottom? Or is there something directing the water flow toward the bottom of the tub instead of up toward the dishes?
Sep 03, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
Whirlpool DU1100XTPS dishwasher leaking from front door panel
Hi karen_kinzer,
I'm Harvey the Master Plumber.
The d/w was a recent purchase?
Then my advise to you is don't worry about it! The unit should be under warranty. It's time to make the call. Let the warranty repairman worry about it. If he can't fix it, he has the authority to condemn it and you'll get a new one. Anyway, this is one problem you should not have to worry about.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 13, 2008 | Dishwashers
Door leak in LG LDF6810ST Built-in Dishwasher
Your drying vent tube is probably leaking inside the door panel.  Remove the outer front panel and on the top left side, there is long white plastic tube connected to the dryer fan assembly.  In that connection is where the problem is.  You will need to disassemble the fan from the door, disconnect the tube from the fan, clean out the water and debris and use silicone when reassembling the tube to the fan.
May 26, 2008 | LG LDF6810ST Stainless Steel Built-in...
Kitchenaid dishwasher leaking from door
Check the screws on the pump cover under the lower spray arm (the spray arm is easy to remove, the screws are torx - maybe a torx 10 or 15, so a regular screwdriver wont work). They come loose on ours every 6-12 months and spray water at the door, causing it to leak all over our wood floor. I routinely tighten those screws now before they come loose enough to cause the problem.
Apr 29, 2008 | KitchenAid 24 in. KUDS25 Built-in...
My dishwasher is leaking at the bottom corners of the door
Mine is doing the same thing and I just bought it three days ago.  I call the store's tech department and they tell me the unit I bought has a service bulletin on regarding leaking at the bottom of the door.  They apparently have a repair kit for the problem.
Oct 11, 2007 | Frigidaire 24 in. FDB1050RE Built-in...
LG LDF7932ST Dishwasher Logo
63 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
