Whirlpool LGR8648 Gas Dryer Logo
Posted on Oct 10, 2012
Intermittent ignition source not lighting - Whirlpool LGR8648 Gas Dryer
1helpful
Cambridge Audio Azur 640A on/off problems
Find out what is causing the protection light to turn on. Troubleshot down to the component level.
1960 volvo 960 lights of battery, srs and abs comes on intermittently. is the voltage regulator faulty?
It could be many things, bad regulator, bad diode in the alternator, or even a bad ignition switch or even a bad ground. You will need to do some trouble shooting with a multimeter to find the source of your issues. Good Luck and may the force be with you.
U 1900 code on 2007 Ford 6.0l Diesel 350 Super Duty
U1900 FORD - CAN Communication Bus Fault
Read more: https://www.autocodes.com/u1900_ford.html
Possible causes
Faulty / intermittent ignition switch connections
CAN Bus wiring intermittently open/shorted to power or ground Faulty / intermittent connection at PCM
Faulty electrical connections at ABS Control Module
Faulty electrical connections at the instrument cluster
Poor connections at the trailer brake controller/trailer connector
Tech notes This is typically a false/intermittent code. It can occur if: Someone hooks up a scanner to the OBDII port while the ignition is on or while the engine is idling. A trailer brake system is installed improperly/incorrectly on a truck with ABS (anti-lock brakes).
When is the code detected? When the PCM, Brake Controller and Instrument Cluster are unable to communicate with each other at any time while the ignition switch is turned to the "Run" position, code U1900 sets in memory.
Possible symptoms Engine Light ON (or Service Engine Soon Warning Light) Amber ABS (Anti-lock Brakes) Light ON Wrench Light On
U1900 Ford Description The Anti-ock Brakes System (ABS) module, the Powertrain Control Module (PCM), and the instrument cluster communicate over the Controller Area Network (CAN) Bus. This is a high-speed bus communication system and is not fault tolerant, which means any type of intermittent/loose connection between these 3 controllers will cause communication to stop. When the PCM, ABS module and instrument cluster are unable to communicate with each other at any time while the ignition switch is turned on, code U1900 will set.
What do I need to have done with the backfiring & stoppage?
check wiring to the ignition switch for shorts or loose connections or breaks
the problem is intermittent connection for the coil or ignition source
2answers
Code 65535 what does that mean
How do i remove t-mobile content lock with out credit card or by going to t-mobile shop.
1helpful
My flame keeps going out. i can press the reset button and some times it will work for a week sometimes only 30 seconds. It is an intermittent igniter. The flame seems to "roll back" when it...
Your GMS unit should not be intermittent ignition but direct electronic ignition. In any case the flame should never roll out of the chamber. There can be a few reasons for the roll out but sometimes a good cleaning of the heat exchanger and a combustion analysis can cure that. The intermittent flame issue is probably a dirty flame sensor and can be cleaned with light sand paper or steel wool. Be careful not to touch the igniter only the flame sensor. It is usually on the opposite side of the burners from the ignition source. Hope this helps :)
Switches off intermittently
It sounds like the pilot assembly is going out. Electronic ignition of the ovens are an electric heating element that surrounds the thermistor, which in turn controls the gas valve that supplies the main burner, this heater is also the source of ignition for the gas. If your oven is electric, you may have a bad element, replacement is not too expensive, I advise you have a repairman look at it in either case. Safety first.
5helpful
Yamaha trx850 bike stopped then restarted no problem following week stopped again this time would not restart--no spark at all been in bike shop for 2 weeks they cant find anything wrong
If they find nothing wrong then the problem is obviously intermittent and can be very hard to find. Check the operation of the ignition switch and all kill switches with a volt ohmmeter. Check the wiring harness. Did a wire come unplugged? Are all wires clean and with solid connections? Any abraded or pinched wires? Is the bike in neutral and the neutral light is lit up? If no neutral light, check the neutral switch and neutral wire connection.
The usual source of intermittent loss of spark is the side stand kill switch. It kills the engine so that you don’t start out with the side stand down. Check for a broken wire at the switch or coupler. Get a service manual and check out the electrical section. Some bikes have a diode controller integrated into the turn signal relay. Try moving the kill switch by hand. If that doesn’t work then wire a jumper around the switch to bypass it. If that doesn’t work, check out the relay.The dealer would / should have load tested the various ignition components. I will assume the ignition system is okay. Check the battery and fuses. Install a new set of stock spark plugs.
2answers
INTERMITTENT POWER PROBLEMS
Sounds like you have intermittent contact between the constant 12v and the ACC 12v power inputs. Remove the head unit, and make sure that the connections are properly insulated. (using inline **** connectors preferably)
Top Whirlpool Dryers Experts
Virgil Watts
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
