I hve alredy forget pass word
These are some defaults for different models.
admin admin
admin sky
user user
There are more listed with model numbers to choose from. Read the Blog.
http://www.sauditechview.com/en/stc-afaq-dsl-shamil-modem-passwords.html
SOURCE: Hello , I am having STC
Hello ,
I am having STC afaq shamel internet modem , model 007 .
Can anyone please tell me what is the default password of WIFI of that modem. I restored the default settings of this modem and now i cannot place the security in my WIFI.
Can anyone please help me on that ??
SOURCE: I was having afaq shamel
I assume your modem is using a special firmware provided by your previous ISP that does not enable you to login through other subscriptions. Perhaps you could try installing an official firmware version provided by your modem's manufacturer?
SOURCE: I have afaq shamel dsl
open your browser to 192.168.1.1
the user name is "Afaq_shamel"
the password is "Stccpe_2007" (depending on your model, 2007 could be 2008, 2009 etc.) note that username/password are case sensitive!
once logged in, on the left select basic > LAN
under WLAN at the bottom enable "Security" field and set your password then click submit
of course you could always call STC (907) for further assistance
good luck
SOURCE: i want to change the
You should not have to restart your modem after changing the password. Once you change that password you might be promt to enter your new password in to establish an internet connection following the password change. The preferred method to to access your modem is through your computer with the modems IP address.By default most of the afaq shamels passwords are as follows:
Default IP: 192.168.1.1
Username: Afaq_shamel
Password: stccpe_2007
Type in that IP address in any internet browser (Fire Fox, IE, etc) You should be prompt to enter in a user name and password. If the one mentioned above does not work try:
Username: admin
Password: password
I hope that this helps you along the way. let me know if there is anything else I can do to assist you.
Thank you
how i will make new password
