Question about Ricoh Aficio IS420 Flatbed Scanner
Software Problem My scanner is working properly, however the program I use with it is inot. One of the executable files is corrupted. I am using Image Search for Windows and the ISW32.exe file is corrupted. If anyone has this program I could use a copy of this file to get my program working properly again. It should be in the ISW folder and may be either isw32.exe or isw32old.exe. I know this is a very old document management program but it works really well for the application we are using it for. Any help will be greatly appreciated.
Posted by stanley_denn on
2 Related Answers
Anonymous
  • 9 Answers
SOURCE: Adobe interface issues
We have also seen that Adobe Acrobat doesn't produce very clear scans (with a range of scanners). Adobe gives very good pdf file size but it downsamples images.
Posted on Oct 23, 2007
Stephen baynes
  • 394 Answers
SOURCE: I am trying to hook
Hi, I am steve, lets get you some help.
Your scanner only supports TWAIN and ISIS. Whilst you can use the scanner from Windows without any problem you can only control it from an application that supports TWAIN or ISIS.
As you have already discovered your application wants to use WIA - you cannot do this automatically. You may want to check whether your application supports either a TWAIN or an ISIS interface (I would expect it to). This is a long running issue with scanner devices.
You could use the Ricoh software and any TWAIN/ISIS enabled software to import the scans then upload the captured file into the application.
Sorry it can't be simpler than that.
Posted on Jan 17, 2011
How to fix and repair a not valid win32 application?
Often this error message will be similar to the below error message.
C:\Program Files\myprogram\program.exe is not a valid Win32 application.
Cause
This issue can be caused by any of the below possibilities.
File is corrupt, bad, or missing.
File is not designed for your version of Windows.
File is a virus, worm, or other malware file.
Hardware incompatibility.
Answer
If the file or program you're attempting to run is corrupt or missing, Windows will be unable to execute the file properly and sometimes generate this error message.
Download files
If you downloaded this file and verified it is complete and compatible with your version of Windows, delete the file and try downloading and running it again. It's possible during the download that the file became corrupted.
Finally, if the second download does not work, try downloading the file from a different webpage. It is possible that the person or company maintaining the website mistakenly uploaded a corrupt version of the file you're attempting download.
Installing a program from a CD or other disk
If you're attempting to install a program and are getting this error, verify that the CD is clean. If the CD is dirty or bad, you could get this error during the install or after the program has been installed because it was not copied properly onto the computer.
Running a program from the computer
If you're running the program from a shortcut on the computer, verify that the program is still on the computer. In some cases if the program is no longer installed on the computer you may get this error.
If the hard disk drive is corrupted or bad it can also cause working programs to fail either because not all the data can be read from the hard disk drive or because the program has become corrupted while on the drive. Run scandisk and defrag on the hard disk drive to check for any potential errors.
Long file name issue
Make sure the program or file you're attempting to run does not contain the same name as the long file name directory it is contained in. For example, executing a file named "program" in the "program files" directory can cause errors in some versions of Windows.
Additionally, if you're attempting to install a program and after the install the program does not work, you may also want to try installing the program in a different directory.
Bad file
Any file can be changed or renamed to be a .exe file. If you're downloading the file, make sure the file is supposed to be a .exe file and that it's not being changed. If you're attempting to create a .exe, file make sure you're compiling the file for Windows and never just rename a file to a .exe file. For example, renaming a .bat file to a .exe file will not make the file an executable file. For a file to become an executable file it needs to either be compiled or converted through a software program designed to convert the file.
If you're trying to run a program that is not designed for your version of Windows you may get this error. Although many older programs designed to work in older versions of Windows will work with new versions of Windows, unfortunately, not all programs will work.
If the program is an older MS-DOS program or early Windows program you may get this error.
If the program is designed for a 64-bit version of Windows and you're running it in a 32-bit version of Windows, it will not work and generate this error.
Getting old MS-DOS games to run in Windows.
This error can be generated by a file that is a virus, worm, Trojan, or other malware file. Often, this will be caused because the virus scanner installed in the computer will not allow the file to be installed or run. Try scanning the file to verify it is not a virus or infected.
If the file has been checked and is clean, it is still possible that the virus protection program or another program installed on the computer is causing issues during the install or execution of the program. Boot the computer into Safe Mode and try running the program; booting the computer into Safe Mode will make sure nothing is running in the background that could be causing this issue.
If you're getting this error during the installation of a program it's also possible that the CD-ROM drive or the drive you're installing the program from is not compatible with Windows or has drivers that are not compatible with Windows.
Download the latest drivers for your CD drive or other drive through our drivers page.
Source : ( http://www.computerhope.com/issues/ch000726.htm)
May 30, 2011 | Microsoft Computers & Internet
Not a valid Win32 application
Answer:File is corrupt, bad, or missing
Download files
If you're attempting to install a program and are getting this error, verify that the CD is clean. If the CD is dirty or bad, you could get this error during the install and/or get this error after the program has been installed because it was not copied properly onto the computer.
  • Additional information about cleaning a CD can be found on our cleaning page.
Bad file
  • If the program is an older MS-DOS program or early Windows program you may get this error.
  • If the program is designed for a 64-bit version of Windows and you're running it in a 32-bit version of Windows, it will not work and generate this error.
If you're attempting to run an older computer game in a new version of Windows, see document CH000587 for additional suggestions about getting older games to work in Windows.
This error can be generated by a file that is a virus, worm, trojan, or other type of malware file. Often, this will be caused because the virus scanner installed in the computer will not allow the file to be installed or run. Try scanning the file to verify it is not a virus and/or infected.
If the file has been checked and is clean, it is still possible that the virus protection program and/or another program installed on the computer is causing issues during the install or execution of the program. Boot the computer into Safe Mode and try running the program; booting the computer into Safe Mode will make sure nothing is running in the background that could be causing this issue. Additional information about Safe Mode can be found on document CHSAFE.
May 30, 2010 | Rosetta Stone Spanish (Latin American) -...
I have installed scanner and disc but cannot find how to use it.I found the test box and that works but now how do I scan?thanks
Canon and other Scanners have both hardware and software buttons to scan documents and photographs.
Scanning with a computer is done with a destination in mind. So the buttons and the software are associated with destinations.
Typical destinations are File, email, Application, and print.
In a simple scan process for copy or print, the item is placed face down on the scanner, then the print button is pressed on the front of the scanner.
The software for the scanner pops up on the screen and the scanner moves the imaging light across the scanner under the glass, reading the item on the scanner. The software sends the image to the default printer and it prints a copy.
You will need to setup your preferences in the software so that a photograph is scanned properly and a newspaper article is scanned to come out clear black and white.
Documents are best saved as PDF files and photographs as TIFF files.
The software will have an expert mode where you can change all the settings and a beginner mode where you let the software decide.
Canon has a great document for your scanner. If it is not on the disk, here is the link. It is called CanoScan 4200F Scanning Guide. I think it will help you to use the scanner for any task.
Apr 24, 2010 | Canon CanoScan 4200F Flatbed Scanner
Cannot run application (*.exe)
what is the application?
It sounds like you are trying to run a Win 16 (Windows 3.x) program
Jul 26, 2009 | Dell Inspiron 1420 Notebook
Error Message 'F:\ setup.exe is not a valid win32 application'
  1. File is corrupt, bad, or missing.
  2. File is not designed for your version of Windows.
  3. File is a virus, worm, or other malware file.
  4. Hardware incompatibility.
Answer: File is corrupt, bad, or missing
Download files
Bad file
Mar 18, 2009 | Computers & Internet
SCANNER PROBLEMS
it's either a corrupted scanning program or a corrupted scanning system file. I would suggest that you try to uninstall then reinstall the scanning program that you're using or maybe just scan using resident programs like microsoft paint for windows systems or image capture for mac systems. If it works on these resident programs (PAINT and IMAGE CAPTURE) then we know that the software that came with your unit may be corrupted. Uninstall it including its registry entries then reinstall it (just the scan program).
Sep 06, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Is their any other way besides new software installation
Looks like you have a corrupted dll file. Go to install/remove programs and uninstall it then reinstall the program
make sure the scanner is not plugged in until you finish the reinstall and rebooted.
good luck
smeags.
Feb 19, 2008 | Canon CanoScan 3000ex Flatbed Scanner
Problems with my BRAND NEW MicroTek ScanMaker i800
welll what are ya using for the software what program
Aug 10, 2007 | Microtek ScanMaker i800 Film Scanner
Ricoh Aficio IS420 Flatbed Scanner Logo
48 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
