Question about HP Compaq 2510p Notebook PC
Hp 2510p not charging
Notebook works fine with AC power adaptor. However "Power LED" is never on. I used a docking station for a long time - did this kill my battery?
Posted by Matthew W.... on
  • Matthew W. Cambridge Oct 12, 2012
    Didn't help.
  • Brian Sullivan
    Brian Sullivan Oct 12, 2012
    A bit more detail might help me to try to resolve this. Take the battery out, plug in the charger and see if the laptop works. If it works, the battery may be the problem.Check the AC Adapter Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop. Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity. If that light isn't on, try a different outlet. Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it. If it still does not light up, your adapter could need replacing. Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.Remove the Battery Sometimes it's as simple as a seated battery. Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection. Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement.
Brian Sullivan
  • HP Master
  • 27,725 Answers
If your laptop works fine while plugged in but stops working while unplugged it's likely that either your laptop battery is bad or your laptop is not charging the battery properly.
Below are steps that can be taken to help identify the cause of this issue.
Leave power plugged in
Make sure the computer has been charging from the power plug for at least two hours before attempting to unplug it.
Remove and reconnect battery
In some situations the battery can become loose.
Removing it and then put it back into the laptop.
Third-party utility
Use a third-party battery utility to determine the total capacity of the battery.
For example, BatteryCare is a free software utility capable of doing this.
Replace battery or AC adapter
If your computer is still in warranty we suggest skipping to the next step.
If the above steps have been completed, we suggest replacing the battery in the computer or AC adapter.
In most situations it's a bad battery.
hope this helps
Try removing the battery from the back and then running it directly through the AC adapter. Sometimes the battery and AC adapter have conflicts and it can cause a laptop to become inoperable.
If this doesn't fix the problem in any way, I would recommend trying a new battery or AC adapter.
hope this helps
Posted on Oct 09, 2012
  • rick miller
    rick miller Aug 08, 2014
    Bought a new battery. Same result.
  • Brian Sullivan
    Brian Sullivan Aug 08, 2014
    check or get a new AC adapter make sure its compatible
2 Related Answers
Mohamed Omran
  • 2567 Answers
SOURCE: i can start my hp 6730s the led is flashing orange
In order to decide whether it is the AC adapter or the power input, please refer to the following article:
http://www.fixya.com/support/r6395191-troubleshooting_laptop_power_failures_ac
This article explains in detail how to diagnose the AC adapter issues.
Posted on Dec 09, 2010
techman007
Lavell Turner
  • 1112 Answers
SOURCE: My dv7-1245dx has the same charging problem. Has
Hi:
This is due to a faulty DC to DC converter IC on the laptop mother board, this part is not replaceable, you must replace the mother board as the chip is part of the motherboard.
Posted on Dec 27, 2010
Dell duo station
I had the same issue. I tried opening the dock and could not find anything wrong. It seems the charger was delivering sufficient voltage. So I disconnected power to the charger and reconnected couple of times and it started working again. My charger has a LED light and based on the brightness of the light you can findout if the output voltage is close to 20 volts.
Sep 20, 2012 | Dell Jbl Inspiron Duo 1090 Audio Station...
My dell 620 battery will not charge with the power supply, yet it charges in the docking station. The laptop will run fine with the power supply except that the battery will not charge till I place the...
sounds like the situation is with the AC adapter detection. try to restore your BIOS defaults and update BIOS if applicable. Test another AC adapter. If that fails, most likely, this is with the motherboard. You may either get a new board, or just continue to charge it using the docking station.
Dec 31, 2010 | Dell Latitude D620 Notebook
Ok i got a hp g60 and its weird cause the battery aint charging .. now wat techiesguru was a great success on getting it to come back on.. how ever i had to also unplug the internal battery as well and do...
Whenyou connect the power adapter into the laptop, does the power LED light up? Ifnot then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's power socket.If the power/battery LED light flashes and in a certain position this LED lightstays firm, then the power socket is either faulty or it has a dry solder jointwhere it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Dec 04, 2010 | HP G60-230US Notebook
I have an 8710 workstation and it has worked fine for many months. Recently I've been having problems powering it on. I use a docking station and when I try to power it on in the morning -- the power LED...
Flashing orange light generally indicates battery low charge could be your battery at fault
the next time you try and power on and it doesnt work, take the battery out (unplug AC) and try to run just on AC power
hope helps, let me know if can help further
Nov 04, 2009 | HP Compaq 8510w Notebook
Power jack connection broken on HP Omnibook xe3
I bought a docking station (port replicator) off ebay, and it has worked great. I had a look at the motherboard, and the docking station uses a different connection for power than the damaged AC port. So in summary, yes a docking port should solve your problem.
If you can get a docking station for it you may be able to solve it that way.
Apr 15, 2009 | HP OmniBook XE3 Notebook
D630 docked , ext mouse & kybd not responding
If the docking station has power:
Make sure power is off for both the laptop and the docking station. Plug your keyboard and mouse into the docking station. Dock the D630 to the docking station and then power on docking station. This should then turn on your D630. Your D630 should detect the keyboard and mouse.
If the docking station has no power:
Verify that the power cord, AC adaptor, etc. is plugged in. If the items listed seem to be in order,
there may be a problem with the power going into the docking station. (AC adaptor?)
support.dell.com will have the specific details for your D630 and your docking station, et al.
Please let me know if you have success in this.
Binary Bob
Nov 27, 2008 | Dell Latitude D600 Notebook
HP Pavillion dv6000 -when I plug in AC adaptor, it won't charge
Hi ja525,
If you have tested the power adaptor with a multi-meter to confirm it is OK or the other adaptor is also OK assuming that it is the correct voltage and at least the same current rating. Then the fault is most likely the power connector in the laptop.
To confirm this, power up as normal with the power adaptor connected and switched on, when the blue LED dims wriggle the power connector where it connects into the laptop and if the LED comes on or blinks, that means that you have a faulty power connector, it couls be a dry solder joint at the power connector.
It is possible that the power adaptor is shutting down (thermal overload) due to insufficient current capacity, Check the Amp rating of the laptop, it is usually on the lable on the botom of the laptop and check it against the power adaptor, the adaptor should be equal too or greater that the laptop's current rating.
To fix a faulty connector, you can dismantle the laptop and with a fine tip temperature controlled soldering iron, resolder the power connector and hopefully this will fix your prolem.
Nov 18, 2008 | HP Pavilion dv6000z Notebook
Docking station fror compaq Evo n610c
docking station for my old compaq armada did not "charge seperately" but did supply power to the pc through docking connector and not through the normal ac input, cant say if they have their own power transformers or not, till i go home and take my old docking station apart. Will the computer not power up when plugged in, it normally will run off ac power even when battery is dead or removed.
May 06, 2008 | Compaq Evo N610C Notebook
DEAD PRESARIO 1925 NOTEBOOK
Try this, with laptop removed from docking unit:
1. Press and hold the laptop power button down, for 10 seconds.
2. Now remove the battery
3. Repeat step one above
4. Let the laptop sit for 10 minutes.
5. Reinstall the battery
6. Make sure docking station is unplugged, and insert laptop into docking station.
7. Plug in power supply (to dock)
8. Start the laptop.
9. IF IT STARTS, let it run a while to see if the battery is charging
10. Remove it from the dock and repeat steps 1-5 above and then go directly to 8 (start without connecting dock).
CONCLUSIONS: If the laptop started in the dock on step 9 but not 10 (only on battery), your battery or power regulator circuit may be damaged. However, if it starts in step 10 but not step 9, your docking station -or its AC power supply may be damaged Let me know how this comes out, please.
Jan 15, 2008 | Computers & Internet
Cannot power on...
How to correct iPAQ 5450, 5455, 5550, 5555 battery charging problems / dead unit syndrome.
The iPAQ 54xx or 55xx will not power on if the batteries charge is lower than 3.2 Volts, if your battery charge falls below the 3.2 volts level your unit will not turn on, you need to plug the iPAQ into a cradle or AC charge adaptor. Note the charging light on the iPAQ will not flash at all (normally flashes orange) until the battery charge has reached a minimum charge level of 3.2 volts. You then need to perform a normal reset, then the unit should switch on normally.
HP Procedure is as follows:
To charge and reset the iPAQ Pocket PC h5400:
i) Connect the iPAQ Pocket PC h5400 to an A/C power supply.
ii) Charge the battery to the minimum level of 3.2 Volts. This will take 5 to 30 minutes depending on the current charge level.
iii) Perform a normal reset.
iv) Power on the iPAQ Pocket PC h5400
It is recommended that you keep the iPAQ Pocket PC connected to the Universal Cradle or Cable when it is not in use.
Apr 30, 2007 | HP iPAQ HX4700 Pocket PC
HP Compaq 2510p Notebook PC Logo
531 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
