Alpine CDA-9827 CD Player Logo
Question about Alpine CDA-9827 CD Player
My alpine car stereo plays cd's, auxilliary but the AM & FM radio got audio sounds for 5 - 10 minutes. After that it does not work anymore. What's the trouble?
Posted by Roy Matanguihan on
Gobinda Gogoi
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 133 Answers
Its trouble is in inside
Posted on Oct 09, 2012
5 Related Answers
Anonymous
  • 146 Answers
SOURCE: alpine 9881 cd will not play sound
If you had to connect the remote amp turn on lead from the headunit to the factory amp turn on lead you may find your problem there.
On many headunits there are 2 blue remote wires 1 for antenna and one for amp turn on. The antenna remote only supplies power when the radio is playing not when playing CD's. If you hooked the antenna wire to the amp trigger then the amps shut down when you play a cd. If that's not it let me know and I will research further.
Posted on Jan 04, 2008
Anonymous
SOURCE: radio sound but NO cd or ipod sound
its not the radio. you have an amplified system in your vehicle and you hooked up the power antenna (blue wire from the radio) and the amp is only energized during AM/FM playback. disconnect the blue wire and connect the blue/white to the car's harness to energize the amp during ipod and cd playback
Posted on May 26, 2008
Anonymous
  • 43 Answers
SOURCE: radio has sound but not the CD player or iPod
Your amp is not turning on - what you should do is connect the "blue/white - remote turn-on lead" to whatever wire you have the "blue - power antenna" output from the Alpine connected to now. That should solve your problem.
Posted on Mar 08, 2008
Anonymous
  • 143 Answers
SOURCE: alpine cdm-7833 cd car stereo code
I didnt think alpines had codes?
are you sure it has one?
sounds more like a connection problem
Posted on Feb 09, 2008
Anonymous
  • 752 Answers
SOURCE: Alpine CDE-9843
Page 16 of the manual:
http://vault.alpine-usa.com/products/documents/CDE-9841,%2043,%2045%20OM.PDF
Setting Time
1 In the Clock priority mode, press and hold
TITLE for at least 2 seconds while the time is
displayed.
The time indication will blink.
2 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press
4 and 3 (CDE-9841 only) to adjust
the hours while the time indication is blinking.
3 When the hour has been adjusted, press the
Rotary encoder (CDE-9845/CDE-9843 only) or
press MODE (CDE-9841 only).
4 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press
the minutes while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by
pressing the Rotary encoder (CDE-9845/CDE-9843 only)
or press MODE (CDE-9841 only).
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold the Rotary encoder (CDE-9845/
CDE-9843 only) or press and hold MODE (CDE-9841 only) for at
least 2 seconds after setting the “hour.” Minutes will reset to 00. If
the display shows over “30” minutes when you do this, the time
will advance one hour.
Posted on Aug 05, 2008
Is there an adapter I can purchase to be able to play an IPOD with my alpine cde 9841 car cd receiver stereo?
Your headunit doesn't have the option of a plug i Ipod cable, The only way to use it with your stereo is to get an FM Transmitter and you tune into the ipod through the radio.
How do i connect a mp3 player to a jvc kd-g331
if the deck doesnt have an auxilliary input or usb input then the only way to get sounds to it and through it is going to be by using an fm modulator that will broadcast your mp3 tunes through an fm signal that you choose and simply tune you radio to the station that you chose to broadcast through.
Is the CDA-9827 capable of playing songs from an mp3 player (does it have an input option)?
The Alpine CDA-9827 only has an input connector for an external CD Changer.
You could get an FM Transmitter for your MP3 Player, and play your MP3 Player using your FM Radio in your Stereo.
Here is an excellent MP3 Player FM Transmitter:
http://astore.amazon.com/tps03-20/detail/B000E43GOO
Here is a copy of your Owners Manual.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
What happened with this unit, I mean it gives me sound on fm or am, however on cd, usb, aux option does not, even though it displays in the screen it is playing.
It sounds like it could be the sound chip. If your fm/am radio is playing sound then the internal amp is fine however CD/AUX functions use a separate sound chip. Have you wired it to an external amplifier?
Cd problems
you need a FM transmitter in that way you just time you car radio you a empty frequency and you will be able to play your ipod on you car stereo.
here is a link of some examples
CLICK HERE
5helpful
2answers
Alpine cda 9884 has no sound in cd or ipod mode
actually, chrysler/dodge has factory Infinity sound systems installed. The nice part about these systems is that you dont have to bypass the amplifiers in order to put a new radio in, but simply power up the amp by hooking up the amp turn on wire at the harness. The alpine should have 2 blue wires coming off of the back, one that is solid, the other with a white stripe. The one that is solid only has 12v when the fm/am radio is on (used for power antenna) but cuts off when other sources are used (cd,aux,ipod). My guesses are, you have the amp wire on the vehicle harness (blue) tied into this wire, instead of the BLUE/WHITE wire on the alpine which has 12v as long as the radio is on. i hope this solves your problem, 9 times out of 10 on a chrysler this is it.
Auto Tech
DA2 (Supa)
Problems with amp or stereo
check out www.installer.com
this site has your stereo's wire diagram.
The amp wires only go to the rear output (rca jacks on back of cd player)
It wont work right if it is connected to the front outputs on the back of cd player
2answers
Radio sound but NO cd or ipod sound
Radio is screwed.
But try these these steps:
Clean the eye of the head for reading CD. Must open up the radio.
IPod: check for good connections from Ipod to PCB.
1helpful
Cd plays, but no sound
Disconnect the blue wire from the back of the radio and connect the blue/white wire in its place. This should fix your problem.
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Jeffrey Turcotte
Jeffrey Turcotte
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
