HP Compaq Presario CQ70120US Notebook PC Logo
Anonymous Posted on Oct 09, 2012
Window can't log on?? when notebook on window logo display after few second computer is restart....any solution???
Shekhar Chowdhury
Level 2:
Sergeant:
  • Expert 157 Answers
  • Posted on Oct 09, 2012
Shekhar Chowdhury
Expert
Level 2:
Sergeant:
Answers
157
Questions
Helped
55710
Points
518
This problem can occur due to several reasons. And there are many steps that need to be taken care of. Try this step shut down the computer completely and then look for the F8 key on the keyboard once you locate the key hit the power button and then keep on tapping the F8 key until you see the start up options before booting into windows now try the options safe mode or safe mode with networking.
Now try these steps and see if this works out. and if this solutions help and let you log in computer then go ahead and restore your computer to an earlier time.
Thanks
  • 1 more comment
  • Anonymous Oct 09, 2012
    hi. first of all thanks for repaly...but bro i already check it...but still this problem....computer con't go to safe mode....i try to install window but fail.....so what do says...???
    bro not for gpu fault. ... i think bios problem.....what do u say??? replay soon....
  • Shekhar Chowdhury Oct 10, 2012
    What error it gives when you try to format it. Well i dont think this could be of BIOS it can also be the HDD Problem.
I have Laptop Latitude E5410 and having problem with LOG IN after start up Windows. When i log in with Password it's works and start process and then in few seconds Log off automatically. This happens...
sounds like a virus!
  1. Remove all floppy disks, CDs, and DVDs from your computer, and then restart your computer.Click the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, click the arrow next to the Shut Down button eb058ccf-b21e-4dfe-9bb7-1ad6c83b705c_47.jpg, and then click Restart.
  2. Do one of the following:
    • If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to keep tapping on F8 before the Windows logo appears. If the Windows logo appears, you'll need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
    • If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to start in safe mode, and then press F8.
  3. On the Advanced Boot Options screen, use the arrow keys to highlight the safe mode with networking
  4. download malwarebytes http://www.majorgeeks.com/mg/getmirror/malwarebytes_anti_malware,1.html#.U2QUMfldU41 it a safe place to download it from
  5. install and run
Setup is starting services
First try to check if you can log to your computer via Safe Mode, if you can then there is a few possible things happened to your computer:
1. Corrupted software installation that is messing up with your startup services.
2. Hardware problem (memory or bad sector in the hard disk)
3. Or Operating system or malware.
Anyway for the step to test if you can log in via Safe mode try the steps below:
Reference: Safemode
Open Safe Mode with the F8 key
All Windows versions can be booted into Safe Mode by this method. Note that it is somewhat tricky to time this procedure and it may take several attempts.
1. Turn on or restart your computer.
2. Hold down the F8 key before the Windows logo appears. If the computer makes a complaining noise, tap the F8 key repeatedly instead of holding it down.
3. If a Windows logo or "Windows starting" appears, wait until Windows loads. Then restart the computer and try pressing F8 again.
4. Once you are successful, a menu will appear with a number of boot options. Use an arrow key to navigate to "Safe Mode" and press the Enter key.
Trying to get to Safe Mode by using the F8 key can be frustrating and there is another way that uses the System Configuration Utility (msconfig).
Best Regards,
Art
Hdmi not detected by HP Pavilion dv5-1235dx Entertainment Notebook PC
You may want to check your dispaly properties to make sure that your display is set to HDMI instead of laptop display in the control panel under display properties. On many laptops, this can be done by pressing the "fn" key and a key with a blue symbol of two screens on it. This toggles between your primary display and external ones.
2answers
Dell Latitude D630 freezes
Try a System Restore and select a restore date before your problems started.
To get to the System Restore - Click on Start - All Programs - Accessories - System Tools - System Restore
Computer will not start
had a similar problem over the last couple of weeks which culminated in the Blue Screen of ***** and hard drive FAIL. Cost 120 euros to replace on a Hewlett Packard laptop. Sorry. :(
My emachine ET1831-03 crashed a few months ago. All I can get it to do is display the windows boot manager screen. It says windows failed to start, and gives me status: 0xc000000f NLS data is missing,...
Power off the computer, then restart it. As soon as you see the eMachines logo appear on the monitor screen, press the "left-Alt" and "F10" keys simultaneously. Wait a few seconds for the Windows boot screen to appear, then press the "Enter" key.
Click the "Restore Operating System to Factory Defaults" option after the eRecovery Management window appears. In the Notice window, read the warning that states all information on the drive will be lost, then click the "Next" button.
Click "Next" in the Restore Destination window, then click "OK" in the final confirmation window. The eRecovery Management utility formats your main system drive and reinstalls the original software that shipped with your computer. A progress bar notifies of you of the current progress of the recovery. The recovery utility may prompt you to restart your computer several times during the recovery process. Restart the computer when prompted. The computer reboots automatically after the recovery finishes and launches the Windows First Time Setup. The recovery takes between 10 minutes and one hour depending on which model eMachines computer you own.
Follow the onscreen prompts to customize and personalize the Windows installation on your eMachines computer. Log in to Windows with the username and password you choose during Windows Setup.
I have my monitor connected to my laptop because the laptop screen went out. The monitor has been working fine until the last few days but now when I power on the laptop & monitor, the monitor only...
Please restart the computer and go to safe mode by tapping F8 key once the system is restarting choose Enable VGA Mode (Windows XP)
choose Enable low resolution Video (Windows Vsita / 7).
Change the display settings to slightly lesser than what the monitor can handle and shut down and restart the computer in normal mode.
All of a sudden, the screen display went black. When we restart the computer (Windows XP), we see the initial windows logo but nothing else -- EXCEPT, pressing and holding the screen's "INPUT...
Very doubtful. Either you have a defective or corrupt display driver, or possibly a malware infection. Is that a laptop or notebook computer? If so, is there a VGA port for an external monitor? If do, try using a known good external monitor.
HP Pavilion Notebook Monitor display is green and have not been able to get back to blue . The computer is working but you can not see the icons, text, etc very well.
Try uninstalling the display driver from the Device Manager then restart the Computer. After restarting the Computer, reinstall the display driver.
Perform the steps given below to access the Device Manager:
(i) Please press the Windows logo on the Keyboard and then press the "R" key while holding down the Windows logo key to open the Run dialog box.
(ii) Then, please type "devmgmt.msc" in the Run dialog box and click OK to open the Device Manager window.
(iii) Click on the plus sign next to the "Display Adaptor" category to locate the display adaptor.
(iv) Right click on the display driver then click Uninstall.
You can download the display driver from the support site of the Computer manufacturer.
Notebook Isn't Working
When starting the computer tap the F8 key repeatedly. The Windows Advanced Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again. Ensure that the Safe mode option is selected. Press Enter. The computer then begins to start in Safe mode. When you are finished with all troubleshooting, close all programs and restart the computer as you normally would. Or you could do a system restore to a earlier date when your computer was working fine.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
