LG CU500 Cellular Phone Logo
A
Anonymous Posted on Oct 08, 2012
Invalid SmartChip - LG CU500 Cellular Phone
Anonymous
Level 1:
New Friend:
  • Contributor 15 Answers
  • Posted on Oct 09, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
15
Questions
0
Helped
1564
Points
29
If your LG CU500 says Invalid Smart Chip,It's locked to some network...You need to Unlock it from service provider lock to use other CHIP(sim card)..find the current network,country it's locked now and get the unlock code from the site
Simpleunlocking.com/lg-cu500/rs16wp9/ for LG CU500 and unlock it easily.
1 Related Answer
Anonymous
  • 125 Answers
  • Posted on Oct 04, 2008
SOURCE: what do i do if invalid smartchip appears?
Your cellphone will only work with Cingular/AT&T smartchip. What kind of smart chip are you trying to use with LG CU400. I believe no other smartchip will do.
1helpful
2answers
At&t lg prime gs390 free unlock codes
Please see below instructions in details on how to unlock code for LG phones, (i have included various model of LG for you to try)
Here are some unlock codes for AT&T LG phone available, menawhile , including the methods of entering the Unlock Code on your LG phones attached to them. Hope this is useful. AT&T cell phone Questions&Answetrs
Model : AT&T LG VU CU915 & CU920
1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2. Enter *#865625# then the 16 digit unlock code 3. Device should say: Network Lock Deactivated 4. Phone may automatically reboot and is now unlocked !
Model :AT&T LG C2000
Insert non-Cingular SIM card Power on the handset - phone will display "phone restricted" Select "Cancel" - phone will display "phone restriction code" Enter the SIM Unlock code. Select "OK" - the handset is now successfully unlocked
Model : LG TU720 - LG CU720 and all LG Shine SERIES
1) Power ON your phone with an accepted SIM card 2) Type *#865625#UNLOCK CODE 3) Press OK 4) Device is now unlocked
Model : LG CE110
1) Put a non AT&T or Cingular SIM in the phone; 2) The phone display: Invalid Smart Chip 3) Power on handset 4) Select "Cancel" - phone displays "phone restriction code" 5) Enter the unlock code (8 digit code*) 6) Select "OK'" - the handset is successfully unlocked
Model : LG CU400
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" 3 - Phone will display "Invalid SmartChip" 4 - Enter 159753#*# 5 - Enter the 8 digit SIM Unlock code 6 - Select "OK" 7 - The handset is now successfully unlocked
Model : LG CU500
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN) 3 - In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5 4 - Enter the 8 digit SIM Unlock code 5 - Select "OK" 6 - The handset is now successfully unlocked
How to Unlock LG CU515:
1-Insert non-Cingular SIM card" 2-Power on the handset - Phone will display "Invalid SmartChip". 3-Enter *#865625# then select option 1 and then again select 1 4-Enter the 16 digit SIM Unlock code 5-Device should say: Network Lock Deactivated 6-The handset is unlocked. 7-How to Enter Unlock Codes on CU575 (Trax) How to Enter Unlock Codes on LG F2250:
1-With allowed sim card in the start menu type: 2945#*3311#. 2-Handset shows saved, then return to startup screen 3-Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK' 4-Enter your unlock code and OK. How to Enter Unlock Codes on LG U8110:
1-With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*# 2-Select 'Sim Unlock' menu # 3-Enter NCK code then validate 4-Your phone is now unlocked. How to Enter Unlock Codes on LG U8210:
1-With a not allowed sim card enter Pin code then validate, type: 277634#*# 2-Shows test menu 3-Choose sim test menu and type: 2945#*#, choose Sim Unlock menu 4-Handset shows 'Enter NCK' 5-Enter code, then hit OK. How to Enter Unlock Codes on LG U81xx:
1-To bring up the unlock menu on the phone with a SIM card, type 2945#*88110# 2-Enter the code 3-In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#. If your cell phone is not listed, please follow instructions for LG C2000 above
If If instruction above does not help you i would strogly suggest to contact your Service Provider to provide some alternatives.
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
lg-phones
I have a lg shine(phone) it say smartchip invalid when i turn it on my ime is 01148700640126508
It's shows Invalid Sim means locked to Network You need to UNLOCK IT,get the Unlock code and Instructions at
http://www.wickedunlock.com/lg-cu720-shine/rs11wp9/ and Unlock it.
Mar 18, 2011 • Cell Phones
2helpful
Smartchip?
Phone is locked to other network.
smartchip=sim card
1helpful
Same problem and i dont get why it doesnt work.
the smartchip is either not in correclty or maybe the phone doesnt read the smartchip
Sony ericsson smartchip
You cannot reactivate a smartchip aka sim card...once it's deactivated for security purposes they are not reactivated. You will need to get a new smartchip
What do i do if invalid smartchip appears?
2answers
3helpful
8answers
Lg tu 500 unlock ?
here is the best solution.
http://secretcodes.synthasite.com/
or
http://www.mobile-unlocking-free.blogspot.com/
Unlock code
hi,
     As ur sayin u have got the phone frm Usa ..so frst of all u need to get the software of this mobile unlocked from any of mobile operator only than it will accept ur local sim card.
thanks,
Gizmo1
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
