Replacrd the rear brake pads,now the outside pad is hanging up
The job was not done correctly
Some step that should have been done, wasn't
Can't tell you what, without seeing & taking that side apart
What about parking brake cables all rusted & stuck
What about lack of fluid flushes every 2 years & now have
rusted & frozen calipers
Bad rubber flex hose restricted inside?
Pads installed dry without removing any rust or lubing
anything. That is a given if you paid someone.
SOURCE: rear brake cylinders are stuck, can not push them in
I have a 2004 SAAB 93 and just finished replacing the brake pads and rotors yesterday. On the piston itself you should have two little notches. You can either or a GM rotor reset tool that will push into the two little notches and push against the piston while rotating it clock wise. Or the way that I did it was to take a C clamp and put the caliper back on the car. Clamp it on the back of the caliper to the front of the caliper so it will remain stationary. Then take a pair of needle nose pliers and rotate the two notches clockwise while pushing into the caliper. It will take some strength but you should be able to push them in. Be sure that you spray the boot around the piston when some WD 40 so it does not crack and or break during the process. If you have any additional questions about this feel free to email me.
James
[email protected]
SOURCE: Rear brakes chrysler voyager 05/01
There should only be two bolts on the back of the caliper holding it into the knuckle. Removing those two bolts should free the caliper. In fact I believe they're 12 or 13 millimeter bolts.
SOURCE: how to Remove rear brake drum to replace pads.
hi! the pads will be rutted into the drum, you need to release them first with the cables backed off and the cams wound down, then just tap off the drums!
SOURCE: how to replace rear brake pads on 2005 jeep liberty
put the back of car on jack stands and secure the front tires so it does not roll and then remove the bolts off the back of the caliper there is normally two one at top and one at bottom and spray it with some kind of oil for rust and make sure you have the right size socket before you try to loosen them and once caliper is off and the old pads removed take one of the old pads and squeeze the piston on the caliper back in by using a "C" clamp and also remove some of the brake fluid from the master cylinder before you do this put the new ones back on and check the brake fluid and make sure it is full and then pump the brakes to make sure you have a good pedal also put some "No Squeak" brake stop on the back of the pads so they don't squeak they will have that where you buy the pads from
SOURCE: how do you replace rear rotors and brake pads on 2006 Jetta
There is a special tool you need to do this. It is virtually impossible to do without this tool. I got mine from Harbor Freight for $20. the kit comes in an small orange case and has multiple heads and it pushes and turns at the same time. Do not use a C-clamp, it will damage the piston. This tool still does use some manual labor, but it is worth it when you save a few hundred dollars doing it yourself!
