plug where Check for loose power where power cord connects.
A computer repair shop can replace the power on/off button and he power plug input jack if required. Make sure the laptop power charger has the correct voltage for the computer if it is universal power supply/charger.
did you hold the start/resume button for at least 3 seconds if this works the dishwasher will start ok but if there is a fault it will fail again best you contact your nearest service agent good luck
remove battery plug in power...see what happens ...nothing happens press and hold power button until you hear response(shut down)press power as usual to boot.if it doesnt work first time try a few times more remember to keep power button pressed to shut down.
my AKAI tv is locked. All i see is a blus screen with a little red lock on the bottom left corner! the only button that works on the tv OR remote is the power button on the remote. PLEASE HELP i have tried pushing every button but nothing happens
I noticed that the lens was sticking out on center. After pushing it a little, it clicked and then everything worked fine again. I hope that's what happens for your camera, too.
It's a small world. I have an Ixus V2 on the bench with exactly the same problem.
The sliding button on the camera mates with a switch soldered to a flat ribbon cable inside the camera. There are two small teeth which move the internal switch left ot right. What's happened is one of those plastic teeth has snapped off the external part and now it can't push the switch anywhere. If you pulled the camera apart you could push the switch into either record or review but that's it. It will stay in either of those positions. Which is a bummer. The only way to fix it is to buy the complete flat cable ribbon with switch attached and boy it's a long cable.
Except for sending it away for repairs (expensive) buy a damaged one on Ebay and do a transplant. Just make sure it's suffering the same fault.
