Patton PQH307UM Electric Utility Heater Logo
Sherran Mills Posted on Oct 08, 2012
I have a PQH307, I have had it for 2 years no problem. I went to plug it in today and the casuntion light came on and it not go off. What would can I do? Thanks Sherran
1helpful
Unit has been un-plugged for about a year, I plugged it in today it started right up and was cooling fine, it made a snap and the blower and compressor both quit running. The inside and door lights are...
Just in case, leave it plugged in for another 60 minutes, its quite possible it went into the defrost cycle, in which case no motors will run. If it continues to remain silent, re post your problem.
Toastess warming tray, not geting hot
time for new one, they are made to brake now days:(
1helpful
Hp desktop wont start
I think you have more than one problem there. Take it to a local PC repair shop and have them check it out. Five years is a good age for a computer though so you may want to think about buying a new one. Best of the Irish Luck to yer.
IBM Thinkpad R51 screen blacked out
try to plug in a extrernal monitor and see if that works if it does your backlight went out
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
SRS light on 1995 Eagle Talon went out but came back on today.
your srs light is indicating a bad connection. Disconnect battery and wait five minutes, then plug and unplug the seat belt wires going to the end that you plug your belt into, This is just one part of the srs, but I have had many that it turned out to be abad connection there, Also if you had a scanner you could find exactly what the trouble was. Generally the code will indicate what is defective. Without a code it's a guessing game.
Downloading to computer
Hmm perhaps the USB Cable has dust in it. Have you tried blowing into the ends to clear any dust?
2answers
No picture on screen
MYGR8-YOU HAVE TO LIST BRAND NAME AND MODEL #. JOE TV
No picture, no status light
This isn't a permanent solution, but it has worked for me. The first time I found out about this solution was when the status light went out on my Tatung. I just left it unplugged and didn't plugged it back in for about a month and a half just to see what it would do. When the status light came back on, I knew if it ever did it again, I could try the same thing. Well, a week ago last Sunday, the status light went out again, so I just kept track of when it went out and when I plugged the power cord back in to see if the status light would come back on. Today when I plugged the power cord in, the status light came back on. That was 9 days. I don't know if it could be less than that because the last time I plugged it back in to see if the status light would come on was around last Friday. So it might have worked sooner. Anyway, this seems to work for me. I don't know what is causing it to lose power in the first place, but at least I know what to do.
Top Patton Heating & Cooling Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Paul Carew
Are you a Patton Heating and Cooling Expert? Answer questions, earn points and help others
