Heating & Cooling Logo
Alan Carney Posted on Oct 08, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a carrier 92 furnace. electric motor will not kick on...just hums. red light on circuit board flashes...help?
Tried circut breaker, removed panels. looked for reset button....ideas?
ernesto cuadra
Level 3:
Top Expert:
  • Master 12,223 Answers
  • Posted on Oct 09, 2012
ernesto cuadra
Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4081108
Points
34431
See this causes and fix it. God bless you
If the furnace won't run, check the electrical service panel for a blown fuse or tripped breaker. Also make sure the power switch on or near the furnace is turned on. Check the unit for a reset button and try it. Some units have a built-in breaker or fuse panel.
However you can have a missing 1 phase , test with the VOM, for to measure voltage. Or motor need repair for winding trouble,bearing.If you do not have enough experience call some electrician.
God bless you
4 Related Answers
Anonymous
  • 1420 Answers
  • Posted on Sep 04, 2007
SOURCE: Carrier air conditioner
Sounds like you either blew a transformer, have a bad circuit breaker or blew the main fuse in the outside disconnect. If the indoor unit is still blowing air (no matter what temperature) start looking at the power supply to the outdoor unit. From the circuit breaker, the power will go to a small box located within a few feet from the outside unit. This box will have either a lever on the side or you will be able to open the box and pull out the fuses. From this box the power goes to the condensor. The first thing you should do is to turn off the breaker to the outside unit. Flip it back on and if you have a call for cooling, after about 3 minutes the outdoor unit should start. If it does not, shut off power again to the unit by switching off the breaker, go outside and pull out the fuses in the disconnect box. Using a multi meter, check for continuity thru the fuses. If you have continuity, call your technician. If one or both fuses show no sign of continuity, replace the fuse(s). Make sure that the thermostat is working and sending a signal to the indoor air handler. You may be able to check this by turning the fan switch to "Fan" and see if the blower turns on. You may just have a bad thermostst. Caution should be used anytime you are near electrical components. If you do not have the skill-set required to test electrical equipment, leave it to a proffessional.
Anonymous
  • 40 Answers
  • Posted on Jun 23, 2008
SOURCE: I have a Carrier 38tra048340
Blank screen sounds like a fried thermosat. Abrupt outages can affect certain types of thermostats. Make a jumper wire and jump across R and G. See if you get any action from anywhere. If a fan or compressor kicks in you know you have a burned out thermosat...
Anonymous
  • 334 Answers
  • Posted on Jan 19, 2009
SOURCE: weak flame in intertherm furnace
Ok, so we can rule out the ignitor. (standing pilot systems can develop problems that will cause such symptoms.)
Check the gas pressure, make sure you are getting 11 to 14 PSI.
You need that after the regulator all the way to the manifold.
Also check for cracks in the heat exchanger, causing the wind from the blower to distort the flame pattern enough to cause improper contact with the flame sensor.
Make sure the burners and flame channels are clean of rust, and dibri build up, allowing the flame to properly contact the sensors.
jdthefixer
  • 747 Answers
  • Posted on Mar 19, 2009
SOURCE: carrier furnace model # 58PAV090-14 fan runs but
See the link:
http://hvac-talk.com/vbb/showthread.php?t=77420
2answers
FAN NOT BLOWING ON INSIDE UNIT, CARRIER FX4CN042T00AAAA LAST TIME IT WAS SOMETHING ON A CONTROL BOAQRD THAT HAD A RED LIGHT ON IT, QUESTION WHERE IS THAT LOCATED?
If your outdoor unit has a control board/circuit board, it will located at the outdoor units electrical panel where the line voltage electrical whip goes into the unit. Should be 2 screws that hold the panel/cover on. Turn off power, remove panel, and board should be visible.
1helpful
Electric Furnace stopped running
You have one of two problems. Either the capacitor for the motor has failed or the motor has failed. I would turn off the power to the unit and see if you can locate the capacitor and remove it. An ac supply or electrical supply house can match up the capacitor. This is relatively inexpensive. Otherwise you will need a new motor.
Carrier air handler/furnace won't turn on
from what your saying the motor is hot to touch if that is the case the motor is bad need to be replaced.
HKR-10C FURNACE BLOWER WONT KICK ON
if you have change the thermostat it has to have the option for electric heat the thermostat has o turn the fan on in heat mode on air handlers
1helpful
Hello i have Carrier Weathermaker 38tkb air conditioner unit. It's about 6 years old and when i got home today, the unit itself wasn't working. Although the blower fan in the furnace inside was blowing,...
The humming noise and dimming of the lights is an indication something in the outdoor unit is locked up or has failed.
Check the capacitor as it may have gone bad. If the capacitor is good, then you either have a failed motor, a failed compressor, or both.
4helpful
Carrier 38tkb not working, but furnace is blowing
It is probably a capacitor problem. Check inside the outside unit. you will see a round cylinder with three groups of terminals on top. If the top of it is dome shaped it probably needs to be replaced. You can check it if you have a microfared tester. However if it is poofed out it probably is bad. If this is not the problem you will probably have to replace the fan motor.
1helpful
2answers
American Standard blower will not run
Sounds like motor has failed. If the red light is blinking it may be telling you what is wrong by the number of blinks. It maybe locked out for some reason or loose wire. Try turning off breakers to inside unit for 5 mins and try again, this may reset unit. But it sounds like a bad motor or circut board. Try running with stat in on position instead of auto in cooling mode.
2helpful
I have a Carrier 38tra048340 ac 4 ton unit outside, heater in attic. Thermostat is Totaline P374-1100. Power went out than back on after a few hours due to vehicle crashing into power pole. AC was running...
Top Heating & Cooling Experts
Paul Carew
john h
