The temperature setting on the door is as high as it can go at 46 degrees. The freezer section is set to 6.
SOURCE: Amana 8 yr old side-by-side refridgerator/freezer
sound like you said a sealed system problem if compressor is running check the black coil under ref by the fan and see if it is warm if not you have lost freon just trash it then if it is see if fan in freezer is running if so pull back cover in freezer and see if coil starts to freeze if you have a ice block on coil then it is a defrost problem good luck
SOURCE: Amana Refridgerator BR18VW; P1320703W; 1101010605;
Hey as far the Fridge is running it must not be a botheration that there is no other soounds of compressor or freezer control, as it is a feature of Amana Refridgerators..Also try to decrease the Temperature of the Upper portion less than the current temperature..Hope it helps you!..
Please reply back for how things turned on or for further assitance!..Thank you!!..Regards!..
SOURCE: Food and drinks are frozen in refridgerator
you have a bad thermostat,go to sears .com click on parts put your model number in(inside frig.on wall or freezer wall) click on parts and you can get your part-mike
SOURCE: Wide variation in temperature in
Amana refrigerators older than 5 years have both a cold control and freezer control. this may be your problem. But check both the gaskets on the doors and check for heavy dirt on condser coil. Both can cause wild temp problems. Hope this helps
