Question about Ray-Ban RB 3403 Sunglasses
Broke one lens
I have sun glasses RB 3403 004/82, but I broke one lens. Can I ordered only lens if possible?
Posted by Alen Imamovic on
Jerry Kramer
  • 3,904 Answers
I believe that you can send these right back to RayBan and they will fix or replace these. Don't send them in without checking first but it is worth checking into.
Posted on Oct 08, 2012
My plastic circlip broke due to becoming brittle. Is it possible to order a new one?
Its better if all is too old to replace the whole thing if its was not expensive , but as it was standing in the sun maybe the dealer can help
Apr 15, 2016 | Dryers
How to fix a broken window pane in old windows that dont come out
INTRODUCTION
Remove the Broken Glass
Put on some heavy gloves that will protect you from the sharp edges of the broken glass.
Carefully remove the glass from the window. Some will pull out very easily, but others will take some persuading. Use a heat gun to soften up the old glazing compound, and those last pieces will come out with no trouble.
STEP 1
Clean the Window Frame
Once the broken glass is removed, prepare to re-glaze it. Use a small wire brush to clean off all the residue on the window frame. If the window is old, apply a bead of linseed oil with a brush. That will condition the wood to bond with the glazing compound.
You'll probably have to warm up the glazing compound by kneading it until you can make a pencil-thin bead out of it. It takes a little practice to get the consistency just right, so don't worry if it's not perfect the first try.
STEP 2
Measure, Then Order the Glass
Measure the area to be glazed, write down those measurements and take them to the hardware store. When you order the glass, you need to be as precise as possible with the dimensions.
At the hardware store, pick up a package of push points -- little triangles that will hold the pane in the frame. You'll just push those points right into the sides of the muntin bars. For a small pane of glass, use two points on each side of the glass around all four edges of the pane.
Apply the Putty
Hold the putty knife at an angle and smooth a bead of putty out in one motion to get an even line. Once it's dry, you can paint it.
To keep that glass crystal clear, don't clean it when the sun is shining on the window. The sun will cause the cleaner to dry too quickly, leaving streaks.
Mar 23, 2016 | Audio Players & Recorders
I heard that its not enough to wear dark glasses to protect your eyes from the sun. You need special lenses. Is that true?
yes you need to get polarized lenses not just dark glasses if you want to protect your eyes from UV rays. This is also true for children as the harmful impact of UV rays builds up over a lifetime and is not just something that affects adults.
Feb 13, 2013 | Health & Beauty
I am looking for a screen lens for a samsung solid b2100, because mine is broken.
hi i broke mine the other day had it 2 years , could not find one anywhere , so i used some plastic glass cut around the old one and it fits perfect ! due an up grade soon will last till then
Mar 15, 2012 | Samsung Solid B2100 Cell Phone
Pro and cons of wide teleconverter lens
Great question! The Pros: -Gives you a wider angle of view on your built-in lens -Gives you the potential to have a shallower depth of field when you zoom in on an object. This is a lens effect which makes objects behind the subject appear less in focus than the subject in the foreground - can be a positive if you're trying to have a more cinematic-like effect
The Cons: -Apparent lens distortion around the frame edges. You'll notice a "bowing" effect happen. -Increased ability to have dust and scratches on your lens. Make sure both the front and rear element are clean! -Possible increase in light glare. If the sun is in the background, expect to see more lens-flare effects due to the lack of a lens shade, and the increased number of glass elements that the light needs to pass through.
Personally, I like having the wide angle adapter in my pro-sumer video camera kit because it gives me another option when I'm in close-quarters. If you can avoid lens flare, it will be great addition to your camera.
Feb 20, 2011 | Sony Mavica Wide Conversion Lens 0.7x...
I have a eft lenses broken for my RB 4061 ray ban glasses.can I get it replaced?What is the price?
those are some nice glasses,but you can get them replaced if you send them to ban.it will cost around 20 dollars.or you could go to the place that you bought them and if you still have the loose lens they can fix it for around 15 dollars.
Dec 31, 2010 | Clothing Accessories
Left side broke
hi
The question you have asked is not clear and specific, but let me try to help you. The left side of your sunglasses is broken it may be your lens or frame,
The solution is if your sun glasses have warranty or guarantee please approach the showroom where you brought shades or you can approach some other dealer showroom they may not have your brand but they will repair it for a charge.
If you are satisfied with my answer please vote three thumbs up ..Thank you
Dec 02, 2010 | Guess Clothing Accessories
A plate broke in the dishwasher and glass fell into the food grinder area. I need to remove the glass. I have one of the KUD10 models of dishwashers.
In order to remove the glass you will need to lift the top of the grinder off. To do that is a rather complicated procedure however and I would recomend that you have a repair service come to remove the glass. Attempting to do it yourself could damage the inside of the grinder and possibly make your dishwasher not work at all.
Dec 12, 2009 | KitchenAid Dishwashers
I dropped my cellphone
yes you can have the other lens replaced just take the phone to a mobile repair center.
Sep 17, 2007 | Motorola Mobility RAZR V3
Ray-Ban RB 3403 Sunglasses Logo
599 people viewed this question
Top Ray-Ban Clothing Accessories Experts
Andrew Taylor
Andrew Taylor
legerdress
legerdress
How To Fix...
How To Fix...
Level 1 Expert
Are you a Ray-Ban Clothing Accessory Expert? Answer questions, earn points and help others
