Question about Samsung SRS20DTD Side by Side Refrigerator
Door handle to samsung fridge freezer srs 584 nls needs repair
5 Suggested Answers
Anonymous
  • 89 Answers
SOURCE: RS21DCNS silver samsung side by side fridge/freezer
Parts at;
http://www.gofarappliance.com/parts
Please have model # of refrigerator ready...
Brian
Posted on Jul 14, 2008
Anonymous
  • 126 Answers
SOURCE: i need a replacement door
FIRSTLY WHY DO YOU NEED TO REPLACE THE DOOR OF THE APPLIANCE.
MOAHMED
Posted on Sep 19, 2008
DrLindquist
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
douglas smith
  • 1462 Answers
SOURCE: removing doors from a samsung rsg 5 dumh american fridge freezer
doors are removable. wiring to the door is plug and socket
Posted on Oct 15, 2008
PRIMOAPPLIAN
  • 401 Answers
SOURCE: on a samsung french door fridge is there a way to
I THINK THERE IS LITTLE SET-SCREWS IN THE HANDLE LIKE A ALLEN HEAD JUST LOOSEN THEM UP
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Posted on Jan 13, 2010
How to remove the bottom freezer door handle on Samsung French door refrigerator model # RF26XAERS
The screw heads may be inside the door cavity, screwed into the back of the handles.
If this is the case, as with our Fridge-Master fridge/freezer, it is very difficult, needing strip down of door.
Good luck... :)
Jun 06, 2018 | Samsung Refrigerators
How to remove door handle from a Samsung fridge freezer model no srs2028cvw
wonder why the fridge parts cattle dog lists torx screw sets and allen keys
two somethings hold the handles on at each end
Samsung SRS2028CVW Fridge Freezer Spares
Sep 03, 2016 | Samsung Refrigerators
Samsung Fridge Freezer Door Handle Came Off - No screws is it vacuum based.
The screws are in the holes on the side. You will need an Allen wrench to tighten them
Sep 29, 2015 | Samsung RSA1SHPN American Platinum Inox...
Does anyone have an email address for Appliance DIY Repairs, the company that supplies the repair kits for Samsung fridge freezers please?
samsung fridge freezer repairs kits available from this co
check out their youtube channel try their email ...
if you look below the videos you can click links to ebay where you can purchase kits direct , thier customer feed back score is
99.4% .. they are samsung authorized agents ,
they offer advice on fitting and suitability of parts required - very friendly and easy to deal with
models effected by problem
RS21 , RSH1 , SRS 2026, 2028, 2029
symptoms include
noise in fridge ]- stops when door opened
iregular temp in fridge
water dispensor may not work ,
temp display with more than likley be giving a false reading - ie it will say about 3 ,
if you switch appliance off and then switch back on appliance will show true temp ,
hope this helps ...calum">
Feb 25, 2011 | Samsung Refrigerators
My samsung will run fine for about 4 hours and then will get too cold. if i unplug it and then plug it back in it will then work fine for another 4 hours. please advise thank you
samsung fridge freezer srs2028 srs 2029 problems
if you a have samsung model
SRS 2026 2027 2028 OR 2029 , then you probaly need to fit the rs21 repair kit - as the srs models are the earlier version of rs21 - and suffers from the same isssues .
there is an extra component you will need as well as rs21 kit - if you look under most of the videos there is a ebay link which takes you to ebay shop where you can pruchase samsung spares
check this video out on youtube
Feb 14, 2011 | Samsung RB2155 Bottom Freezer Refrigerator
I have a Samsung fridge /freezer that is icing up around the fan in the refrigerator section. Model No SRS 584 DP
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 20, 2010 | Refrigerators
Mod# RFG297AA:Need to remove the freezer section or handle/latch
there are two screws on each side of the bottom freezer unit you need to remove. they can be removed after de-installing the front bin with the two plastic sleeves on the right and left. Then you can remove the bottom drawer door and the bins inside. next, open both top doors and angle the fridge with one door inside the door frame, then "walk" the fridge over the doorstoop, turning towards the inside door as you push. Follow thru with the rest of the unit, then re-attach the bottom drawer.
Apr 08, 2010 | Samsung RF265AA Bottom Freezer French Door...
Door Handle
If you enter the make and model no. then people may be able to direct you to a suitable website. Alternatively enter your make of cabinet and add freezer spares and Google search it. Hope this is of some help.
Sep 09, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
70 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Gerry Harvey
Gerry Harvey
jasbo
jasbo
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
