Nokia N73 Cellular Phone Logo
Question about Nokia N73 Cellular Phone
If i set a memory card password in my nokia 3600 slide and then insert the same memory card in another mobile once it will ask for password(say nokia N73), will it ask for password again if i insert
Actually i had set a memory card password in my old mobile, now i am using the same memory card in my N73. At first time i had put the password & using the memory card. But now i have forgot the password . So please tell me if i take out the memory card and again insert after some time, will it ask for password again?
Posted by sanjanasi45 on
Gobinda Gogoi
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 133 Answers
Is it
Posted on Oct 08, 2012
Micromax master resetting code all
1.NormalReset - Dial *#7780#
If you dial this code in Nokia handset, it will restore system setting without missing phone memory data (videos, photos, songs).
2. .Deep Reset - Dial *#7370#
When this code isdialed in Nokia handset, it will wholly clean internal phone memory. Entire phone settings and profiles will be deleted, but there is no effect on memory card data.
Remarks -
For Nokia Symbian 60 V1 supported mobile handset (7650, 3650, 3600, 3620, 3660, N-Gage)
you can dial *#7780#*#7370#
Latest S60 mobile handsets, you can dial Deep Reset through another way.
*.Switch off mobile handset first.
*.Press calling key (green), 3 and * keys or (Green calling button + 3 + *)at same time and grip them down.
*.You find a message about format mobile and then release these keys.
*. Password of Reset factory setting code will be either 1234 or 12345.
Nokia X3-02 mobile Restorefactory -
*.Go to Nokia menu lists, browse these options one by one-
*.Menu --settings-- Menu--- Restore Factory Setting
*.Insert phone code 12345and wait few moments to complete restore process.
Nokia 5230, 5800, 5233 and similar mobile handset Restore factory settings, how ?
*.Browse phone menu lists,
*.Then, go to
Menu - Settings - Phone -- Phone mgmt Factory settings
*.Insert security code -12345
*.Without data lost of internal memory, Nokia handset returns in original modes.
Hard reset of Latest Nokiahandset through another code -
*.Switch off mobile handset.
*.press and holdGreen (calling) +Red (End call button) + Camerakeys at the same time along with switch on power of mobile handset.
*.Then mobile asks to insert phone security lock code , so insert12345.
Samsung Restore factory code
*.*2767*3855#
*.*7465625*638*00000000*00000000#
*.#7465625*638*00000000#
or
*.Remove SIM card from mobile handset
*.Once off and on handset
*.Type *2767*2878# to perform internal memory reset
*.Insert SIM card again in mobile.
Samsung Androidsupport handset restore factory code -
Type*#*#7780#*#* - To Factory Restore.
Micromax Restore factory code for all version with Android -
You can use any following below code one by one to perform restore factory of Micromax mobile:
*.1122
*.0000
*.1234
=*symphony> 1122
=*nokia >5071 or 0000
=*micromax> 1234
=*tecno > 1234 or 0000
=*samsung> 1234
=*apale i phone >5869
BACK2HOME
Information from:
http://peperonity.com/sites/a--a.secret.mobile.codes/47096442
Terry
UNlock nokia phone model3600 slide?
Hi, You can unlock a Nokia 3600 SLIDE safer and easier using unlock code. You can get the unlock code for a Nokia 3600 Slide from www.unlock-zone.com/nokia-3600-slide/rs16wp9/ at low cost.
UNLOCKING STEPS FOR A NOKIA 3600 SLIDE
1 - Switch on your Nokia 3600 SLIDE without any sim card.
2 - Don't bother as to what is displayed on your Nokia 3600 SLIDE.
3 - Compose #pw+CODE+1#.
4 - The Nokia 3600 SLIDE would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 3600 SLIDE mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 3600 SLIDE
27helpful
2answers
My hand set is nokia 2690. Once i set password on
Hello Mukerjee,
To unlock the memory card password of Nokia 2690 Cell Phone.
Download FE Explorer from the link http://fexplorer.en.softonic.com/download/25347
Insert card into your phone but don't access it through phone.
Run FExplorer and Open the path C:\system.
You will find a file called mmcstore ,rename the file mmcstore.txt
Copy that file(mmcstore.txt) to your pc and open that file in notepad.
You will find your password in that file to unlock memory card password of Nokia 2690 Cell Phone.
Also visit :
http://www.mobiclue.com/recover-memory-card-password-from.html
1helpful
Locage Code de restriction nokia 3600 slide imie 359306/02/513989/8
Each Nokia 3600 SLIDE mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia 3600 SLIDE mobile phone at www.mobileunlocksolutions.com.
8helpful
How to unlock memory card password of nokia 3600slide
Sir, I have Nokia 3600 Slide problem occured since last month is it's not swith on/off from the operating button by pluging the chager then it's on the key pad is not working when i press 5 the 8 also come along network problem same sim putting in another mobile gettting network full all the time light blinking that's why charging is weak. Please Sir help in this matter or the confidence of NOKIA will be loosed. I Send Mobile to Nokia Care center they are asking more then it's cost on 20 TH April 2011 help me to sort the problem please response Yes/No .............. Waiting
1helpful
How to unlock memory card nokia 3600??
hello there!
What do you mean by "unlocking memory card"? did you create any password on it? If you want, you may try to format your memory card and create a new profile.
Thanks,
fossildude
I have nokia 5310 mobile in my mobile my volume slider button is not working so i can't increase my volume the audio is so tiny.
i have nokia 5310 mobile xpress music, once i remove the memory card and inserted, now it's asking password but i din't remember of setting password for memory card, pls help me on urgent basis or re-direct to correct party to liaise with..
Regards, Asha
20helpful
2answers
I forgot my memory card password(MicroSD 512 mb Nokia 3110c)
i have nokia 3110 classic mobile. the memory card is nokia. i set password for my memcard. i had a software problem with my phone. so i gave for installing sw for my phn. after installing the software, when i opened my mem card it asked password. but i forgot the password. so i wnt to format it. but for formatting also it asks password. pl solve my problem
2answers
I need to know how to lock my memory card of nokia 6300 mobile
hi,
go to setting.....look for the memory icon of your card...select...it will ask you to put password lock....after activate...
P.s don't forget your password..
please don't forget to rank our answers.
thanks,
Top Nokia Cell Phones Experts
Kolbrun...
Marvin
Marvin
matt
matt
