Mitsubishi WS-65515 65" TV Logo
Question about Mitsubishi WS-65515 65" TV
Mitsubishi WS 65515 Reset - Mitsubishi WS-65515 65" TV
1 Related Answer
Anonymous
SOURCE: mitsubishi ws-65515 tv green light blinks constantly after power failure.
I UNPLUG IT AND WAIT A FEW MINUTES...THEN I PLUG IN THE POWER AGAIN AND IT WORKS
Posted on Jan 19, 2009
Ws 65515 blinking green light
How many times the standby light blinks. Count it. It is fault indications. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to the latest updates. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there.
1helpful
HDMI connection pin broken/ No signal HDMI
The HDMI connector is on the HDMI board part# 934C107001 ($92.99 Andrews Electronics)
tip
Mitsubishi Convergence IC Part Number List
As there has been some serious errors made in identifying the IC's for Mitsubishi Convergence, I have posted the complete list for your use.
Mitsubishi Convergence IC Part # List (complete)
Ref # / Part # / Part Name & Description
CHASSIS: VZ7
MODELS: VS-45605 / VS-50605 / VS-50705 / VS-55705 / VS-60705 / VS-70705
IC8C01 267P141030 HIC- STK392-110
IC8C02 267P141030 HIC- STK392-110
CHASSIS: VZ8
MODELS: VS-45607 / VS-50607 / VS-60607 / VS-50707 / VS-55707 / VS-60707 VS-70707
IC8C01 267P141030 HIC - STK392-110
IC8C02 267P141030 HIC - STK392-110
CHASSIS: VZ9
MODELS: VS-45609 / VS-50609 / VS-55609 / VS-60609 / VS-60719 / VS-70709
IC8C00 267P155010 HIC - STK393-110
CHASSIS: VZ6-V15
MODELS: VS-70803 / VS-80803 / WS-65903 / WS-73903
IC8D01 267P120010 IC-H STK392-040
IC8D02 267P120010 IC-H STK392-040
MODELS: VS-50800 / VS-50803 / VS-60803
CHASSIS: V16
MODELS: VS-50805 / VS-60805 / WT-46805 / WS-55805 / WS-55905 / WS-65905 / WS-73905
IC8D01 267P120010 HIC - STK392-040
IC8D02 267P120010 HIC - STK392-040
CHASSIS: V17
MODELS: WT-46807 / WS-55807 / WS-55857 / WS-55907 /WS-65807 / WS-65857 / WS-65907 / WS-73907
IC8C01 267P150010 HIC - STK392-570
IC8C02 267P150010 HIC - STK392-570
MODELS: WS-55908 / WS-65908
CHASSIS: V18
MODELS: WT-46809 / WS-55809 / WS-55819 / WS-65809 / WS-65819
CHASSIS: V19
MODELS: WS–55859 / WS–55909 / WS–65869 / WS-65909 / WS-73909
IC8C01 267P155010 HIC - STK393-110
CHASSIS: V20B
MODELS: VS-A50 / WS-A48 / WS-A55 / WS-A65
CHASSIS: VK20
MODELS: WT-42311 / WT-A42
CHASSIS: V20
MODELS: VS-50111 / VS-60111 / WS-48311 / WS-55311 / WS-55411 / WS-65311 / WS-65411 / WS-73411
CHASSIS: V21
MODELS: WS-48511 / WS-55511 / WS-55711 / WS-65511 / WS-65611 / WS-65711 / WS-65712 / WS-73711 / WS-B55
CHASSIS: K20
MODEL: WT-42313 / WT-42315 / WT-42413
IC8C01 267P173010 HIC - STK394-250
IC8C02 267P173010 HIC - STK394-250
CHASSIS: V22
MODELS: WS-48313 / WS-48413 / WS-55313 / WS-55413 / WS-65313 / WS-65413
CHASSIS: V23
MODELS: WS-48513 / WS-48613 / WS-55513 / WS-55613 / WS-55813 / WS-65513 / WS-65613 / WS-65713 /
WS-65813 / WS-73513 / WS-73713
CHASSIS: V24
MODELS: WS-48315 / WS-55315 / WS-65315
CHASSIS: V25
MODELS: WS-48515 / WS-55515 / WS-55615 / WS-55815 / WS-65515 / WS-65615 /WS-65815 / WS-73615
Green light flashs even after reset button is pushed what should i do
need to replace bad capacitor on dm board witch look like leki a cable box , this is inside the tv 7 bad capacitor 1000uf at 25v original on tv are 1000uf at 16v
Mitsubishi 1080 rear proj. tv
I can help you unlock your Mitsubishi HDTV V-Chip, but you will need an 'original' Mitsubishi remote control for the fix to work.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Focus
Use the Setup menu to select English or Spanish as
the language for the menus and on-screen displays.
Adjust Color Balance Automatically or manually
(PerfectColor TM) using six colors, Magenta, Red, Yellow,
Green, Cyan and Blue. Reset the Color Balance to the
factory default settings. Align the focus (convergence)
of the TV's projected light beams or reset the focus to
the factory default settings.
Mitsubishi ws-65515 tv green light blinks constantly after power failure.
2helpful
2answers
Mitsubishi cs 27401
I CAN NOT PROGRAM MY MITSUBISHI TV MODEL CS 27401. I HAVE THE REMOTE BUY IT HAS TOO MANY CODES THAT I CAN NOT HANDLE.
THANKS,
CLAYTON77
Top Mitsubishi Televison & Video Experts
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
