Question about Microsoft Windows XP Home Edition English for PC
How do I clear Outlook Express error 0x8000ccc08
Error occurs when trying to send messages
5 Related Answers
Anonymous
  • 15 Answers
SOURCE: My Outlook Express Won't work
Sounds like it's self explanatory. Perhaps Hotmail is no longer free for Outlook Express. If you would like to use Outlook Express as your defautl email client and use a POP3 based email account, may I refer you to www.hotpop.com? You can apply for a free POP3 email account which you can set up to run with your Outlook Express. You may also want to check into www.gmail.com. They support web based inboxes as well as POP3 configuration for your Outlook Express.
Posted on Apr 06, 2008
Anonymous
  • 61 Answers
SOURCE: i am not able to sending email from outlook express
Incorrect account settings.Remove your account and create new one in outlook.Check if u have installed any antivirus or firewall program blocking this.
Posted on Nov 01, 2008
Anonymous
  • 55 Answers
SOURCE: message: Outlook Express has encountered an
Most likely there is a email with a virus in one of your outlook express folders. Download a 30 day trial of Kaspersky internet security and run a full scan on your computer.
Alternatively, you could try creating a new Identity in outlook express, only problem is you wont be able to access your old emails. But you can always switch back and forth. To do this Click on File – Identities – Manage Identities. Here you can create a new one and configure your email settings. Though this may work, this may only be a temporary solution.
Hope this helps. Please rate your feedback!
Thanks,
VJ
Posted on Mar 05, 2009
Anonymous
  • 428 Answers
SOURCE: sending mail
Please go to this link and u will be able to solve this. Its a POP3 server error
Click Here
Please rate the answer
Good Luck
Thanks
Posted on Jun 17, 2009
Anonymous
  • 5 Answers
SOURCE: I am trying to export my messages from Outlook
To resolve this issue, try one of the following methods, as appropriate for your situation.
Method 1: Reinstall Outlook temporarily
If you are importing mail from Outlook into Outlook Express, but you have already removed Outlook from your computer, reinstall Outlook, and then try to import the mail again
Method 2: Change your MAPI Settings
Configure Outlook Express to not be the default Simple MAPI client before you import the mail items. To do this, follow these steps:
  1. Restart your computer, and then start Outlook Express.
  2. On the Tools menu, click Options.
  3. On the Connection tab, click Change to open the Internet Properties dialog box.
  4. On the Programs tab, click an e-mail application other than Outlook Express in the E-mail list. Click Apply, and then click OK.
  5. Click OK again to close the Options dialog box.
  6. Exit Outlook Express, and then restart Outlook Express.
    You can now import or export messages.
NOTE: After you complete the import or export process, you can configure Outlook Express to be the default MAPI client. For more information about how to configure Outlook Express to be the default MAPI client, click the following article number to view the article in the Microsoft Knowledge Base:
Set Outlook Express as your default Simple MAPI client Or u can refer from here: http://support.microsoft.com/kb/179637
Posted on Oct 27, 2009
MAPI error message when import or export messages in Outlook Express
·You import mail from Outlook into Outlook Express, but you removed Outlook from your computer before you tried to import the mail into Outlook Express.
·You configure Outlook Express to be the default Simple Messaging application programming interface (MAPI) client.
·You import or export mail from Outlook Express, and you do not have Outlook installed on your computer.
Method 1: If you want to use a special program you can use Outlook Express Fix Toolbox
https://www.fixtoolbox.com/outlookexpressfix.html
1.Restart your computer, and then start Outlook Express.
2.On theToolsmenu, clickOptions.
3.On theConnectiontab, clickChangeto open theInternet Propertiesdialog box.
4.On theProgramstab, click an e-mail application other than Outlook Express in theE-maillist. ClickApply, and then clickOK.
5.ClickOKagain to close theOptionsdialog box.
6.Exit Outlook Express, and then restart Outlook Express.
May 31, 2016 | ErrorExpert
Microsoft Outlook Express error. How to stop it?
'421 4.7.0 Not allowed.' means that your account isn't allowed to send through this particular server. Perhaps you changed your password, or your account expired of something like that.
May 28, 2015 | Microsoft Outlook Express
Can't send emails in Outlook Express
Save yourself alot of headaches and use a web-mail service like Gmail.
Oct 27, 2014 | Microsoft Outlook Express
Unable to send e-mail through OE 6 installed. Getting error message as below: An unknown error has occurred. Account: 'HOME', Server: 'smtp.bsnl.in', Protocol: SMTP, Server Response: '421 Cannot...
You probaly have the SSL box checked in your SMTP settings.
Open Outlook Express.
Click on Tools in the menu, and click on Accounts in the drop-down menu.
Click on Mail.
Double-click mail account.
Click on Advanced.
Outgoing mail (SMTP) should be 25
Box on the left of This server requires secure connection (SSL) should be clear. If not, click on it to clear the check.
Clikc OK button and you should now be able to send emails.
Dec 17, 2010 | Computers & Internet
I dunno but you might be better off just copying the outlook express data files from one computer to the next instead of trying to export.
http://support.microsoft.com/kb/270670
from the horses mouth.
Oct 27, 2009 | Microsoft Windows XP Home Edition
Dear experts,on outlook express,when I hit the forward icon to send an e-mail to someone else and and type something then want to change the font a window pops up and says,An error has occurred in this...
You can use RecoveryFix for Outlook Express recovery software which is capable to recover permanently deleted, highly encrypted and compressed emails of an Outlook Express mailbox. User can easily download the trial version of DBX recovery utility from here http://www.outlookexpressrepair.net/
Oct 03, 2009 | Microsoft Outlook Express
Outlook express is trying to send a message with a lot of photos attached. It is unable to do this. How can I delete this message.
If your Email is trying to send as soon as you start Outlook Express, you might try this:
Open Outlook Express and go to the top menu, click TOOLS then under that menu, OPTIONS. Under the GENERAL tab, uncheck the box for "Send and receive messages at startup", then click OK.
Close Outlook Express and start it up again. Hopefully this will allow you to delete the Email. Good luck!
Sep 15, 2009 | Computers & Internet
Can't delete email in Outlook Express
What OS are you on, XP or vista?
What version of Outlook Express?
Can you still connect to the internet with a browser?
It sounds like you might have a corrupted user profile.
Please work through this article to troubleshoot this error...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 20, 2009 | Computers & Internet
Mail sending problem in outlook express 2003
Tried to take backup of messages was not able to copy the dbx files
- Rename folders.dbx
- Was able to send/receive messages without any error
May not able to retreive some messages in sent items, deleted items folder
>lets create new identiy
http://support.microsoft.com/kb/209169
Dec 06, 2008 | Microsoft Office Outlook 2003 for PC
Outlook express6
if you are trying to send an email from an old isp mail account, using a different isp email connection; you have to change the mail.smtp settings, for the settings you will need to refer to your isp. If you are trying to send an email using a hotmail account, this can no longer be done as hotmail no longer allow the use of outlook express with their accounts
Apr 07, 2007 | Toshiba Satellite M45-S169 Notebook
Microsoft Windows XP Home Edition English for PC Logo
247 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
