SOURCE: mig welder powers up but only clicks when trigger is squeezed
1] Remove the power cable from the power. (socket on the wall) remove the top cover there should be a fuse located on the wiring panel.
2] perform all your house keping- like, all plugs and socket are tight, the correct contact tip with the the right wire size, roller/s are also the correct ones for the wire size and are turning if they are turning but not feeding the wire, then, the rollers need to be tightend , get back to us.
SOURCE: i have a Clarke weld
I do not know of a US source for these Clarke EN130 Wire drive wheel parts. I don't know of any interchangeable subs either. Your welder was made in Italy and the wheel drive is metric.
This is probably your best bet in trying to find any parts for it:
http://www.clarkeinternational.com/shop/search/filter/EN130/page/1
Not sure if you knew this:
Clarke Power Products Files in Toledo
Clarke Power Products Inc., a wholesale distributor of power equipment from Perrysburg, Ohio, filed a Chapter 11 petition on Jan. 8, 2009 in Toledo, saying it owes $7.9 million to the secured creditor Key Bank.
Court papers say assets of $13.8 million are comprised of accounts receivable, inventory and cash. Clarke’s products include air compressors and power tools.
The case is In re Clarke Power Products Inc., 09-30071, U.S. Bankruptcy Court, Northern District of Ohio (Toledo).
Thanks for choosing FixYa.
Kelly
SOURCE: purchased used clarke turbo weld
Hi:
No, there is nothing missing there, the machine is a single face 220Volts.
Regards,
