I have put the seal in two places but it still leaks. The seal looks okay and the blender is new What do i need to do?
SOURCE: cuisinart sealing gasket
The gasket goes between the cutting assembly and the glass. So you slip it on over the top of the blades and then put the glass jar over top of that. Screw the bottom cap on to tighten everything together.
SOURCE: Lights blink, but Cuisinart Smartpower 7-speed wont turn.
The thermal fuse is blown. You can buy a replacement from RadioShack for $1.69 You have to remove the old one and solder in the new one. If youre "handy" its very easy. Take it to a repair shop, you pay about the same as a new one. Its too bad that most electronics made today are cheaper to throw away and buy a new one rather than fix them when they break.
SOURCE: cuisinart bc56 blender
I cannot find the part of the rotator that goes on the blender. the cuisinart parts only have the one that goes into the jar
SOURCE: leaking cuisinart smart power 7-speed electronic blender
There is probably a hairline fracture or tiny crack in the blade assembly itself - replace the blade assembly - it will automatically come with a gasket, so you will have an extra.
