Won't power up. red light flashing6times.
If Lamp has not been replaced then replace Lamp . Other wise if Lamp has been replaced problem will be in the power supply board. Look for Lamp on Ebay I found one for $40.00 or Look on- Shopjimmy.com
Posted on Oct 09, 2012
SOURCE: Sony KF-WE50
Hello Failrlane.
You have a bad thermal fuse. You must remove the back cover in order to fix this unit. The thermal fuse can be found near the lamp housing. part number for kit: A-1137-954-A
Best regards
Circuitcity
Posted on Jan 04, 2008
SOURCE: SONY GRAND WEGA KF-50WE610 can't turn on TV screen.
Ths 5 blinks usually indicate an AKB problem. There is a break in the video path. I'll look up your specific model and post the results here. Please update this if you wish to attempt the repair yourself.
Thanks,
Dan
Posted on Mar 19, 2009
SOURCE: Sony KF-50WE610 Tv won't turn on, red light blinks 6 times
3 times means Lamp and 6 means you have lost a voltage. You may have a thermal fuse blown.
This set has a common trouble with overheating caused by the drum fan located on top of the lamp housing clogged up with dust. When the lamp is getting old it runs hotter and that combined with the fan being clogged the thermal fuse blows. You must replace the lamp and thermal fuse. You must also clean out or replace the lamp fan. This drum type fan should be cleaned out every year or two depending on the environment.
Posted on Apr 16, 2009
SOURCE: sony kf-50we610 power led flashes red 5 times
Needs new lamp or the fan is out.
Posted on Jun 02, 2009
SOURCE: I have a sony KF-42WE610. When I go to power it
More than likely it is the G1 board or Thermal Fuse. I replace the thermal fuse and it is still giving me the 6 blinking red lights. Thermal fuse is $40 and cheapest G1 board I have found on-line is $120. I am about to pull the trigger on the G1 board and give it a shot.
Posted on Mar 04, 2010
