To start what operating system are you running? Dell's website has manyy troubleshooting and restore proceedures but you need to know your operating system(XP,Vista, or Windows7). Laptops with newer versions such as vista or windows7 automatcily back up your data to a second partition in the hard drive. There should be a complete copy of your original configuration from the factory which is used to reinstall the operating system and then alowwing restore of data from the same secondary partition so you will not lose you data. I can help you with this but I need whioch operating system your runing. In case your wondering Dell and other maufatcurers stopping sending operating systems discs with the ;laptops when you buy then, instead as mentioned before they install the oprating system on a seperate partition in your hard drive. they did this to stop the bootleggin of the operating discs. You can also contact Dell and give them the information from the servie tag on the bottom of your computer. The service tag # is like a serial number and contains the configuration of the laptop. You can purchase a copy of this disc from Dell for no cost if laptop is under warranty or for a small charge of about $30 if out of warranty, but if reinstaling from the disc all old data will be lost unless you can copy it before reinstallin the operating system.
SOURCE: Rebooting my Dell Inspiron 6000 Laptop
i want toreformate my dell inspiron 1501 i don't know how to do that even i have all the cds with me but i knw how to go ahead is somebody can help me plz
SOURCE: dell inspiron 9400 dvd/cd rom not recongized.
I'm a Help Desk Support/PC Tech (and the ONLY one for my company) so I live and breathe all kinds of issues...it's my bread & butter. I recently had a co-worker bring a laptop to me for the same reason...not to say that you're having the same problem but with what information you did provide, it does sound quite the same. The DVD wasn't listed in Device Manager nor My Computer and it wouldn't play any discs. The operating system installed on his laptop was Windows XP but the fix is the same for both XP and Vista.
I finally came to the conclusion that the cause of this problem was due to corrupt registry entries, possibly left by CD burning software. He had installed iTunes for his iPhone and the previous user had also installed a CD burning program. And, there's no telling what else had been done to the system. Sometimes removing an installed CD burning program can cause these corrupt registry entries to interfere with the functionality of your DVD/CD drive. If this is the problem, the fix is as simple as making as checking the registry to see if the entries are there and making as much as a couple of changes in the registry and viola! It works again.
ALWAYS CREATE A FULL BACKUP WHEN MAKING ANY CHANGES TO YOUR SYSTEM. When modifying the registry, you can also create a backup of the registry only and restore it from the backup if any issues occur.
Try this for Vista:
1. Click Start then click All Programs
2. Click Accessories then click Run
3. Type regedit into the text box then click OK
4. In the navigation pane,on the left, locate HKEY_LOCAL_MACHINE then click the folder to open it and find the SYSTEM folder. Click the SYSTEM folder then go to the folder named CurrentControlSet and click it. Drill down to the folder named Class then click it. Within the Class folder, you will see several folders named with a series of alphanumeric characters enclosed in {} brackets. Find the one labeled {4D36E965-E325-11CE-BFC1-08002BE10318} and click it.
5. If I'm correct about your problem, in the right pane of the window, you will see UpperFilters (if not, your issue is caused by something else and you can exit the registry). If you do see UpperFilters listed in the right pane then click it.
You may see an UpperFilters.bak registry entry. You do not have to remove it. Click UpperFilters only. If you do not see UpperFilters but do see LowerFilters, you still may have to remove that entry for this fix to be successful.
6. On the Edit menu, click Delete. You can also right-click UpperFilters then click Delete. Confirm the deletion.
7. Now for the LowerFilters, in the right pane, click LowerFilters (again if you DO NOT see this entry nor did you find the UpperFilters entry in the registry, you will need to move onto troubleshoot further).
8. On the Edit menu, click Delete. You can also right-click LowerFilters and click Delete. Confirm the deletion.
9. Now you're finished. Exit the Registry Editor and restart the computer.
After you restart your computer, the first thing that you should do is open My Computer to see if the drive is now listed. If you did find the Upper and LowerFilter entries in your registry and removed them, your drive should appear now.
I am assuming that your drive is still operable and is installed correctly. When I fixed this same issue on my co-workers laptop, the DVD ROM was recognized and working after the reboot. Also, because these registry issues are one of the most likely causes, it doesn't hurt to go into the registry just to see if those entries are there. If they are present, this is most likely the cause and the only solution that I know of.
Try these steps if you haven't already and post the results...
SOURCE: my dell inspiron 1720 laptop webcam doesn't work for most program
you can have the webcam workin for only ne application at a point in time also check to see that you have activated the webcam access on the other applications and this time try with the windows firewall and other firewalls deactivated
my system is Vista with service pack 2 but problem was there with service pack 1
Computer working well it is just the waiting on the 30 second delay i am trying to avoid
