It was plugged in, but not opened for awhile, think it may have froze up and burnt up compressor. When I found it, the compressor was very hot to the touch and the unit was not cooling. Plugged it back in a few days later, but no cooling and compressor still gets hot. Is it worth fixing?
SOURCE: Magic Chef MCWC30MCG not getting cold?
You need to replace the Ptc unit attached to the compressor. Go to REPAIR CLINIC.COM and order the following part. 1206838 Ptc relay. They also will show you were it is located and how to replace it. Compressor tanks very rarely go bad. It is an $11.00 dollar part
SOURCE: Magic Chef MCBR1000w stopped cooling
If the compressor runs on 120 volts AC, (some are three phase DC, you can use a 3n1 hard start kit, they are very simple to use and cost around $20 dollars, you can purchase them at HVAC supply stores. If the compressor continues to short cycle after installing the hard start kit, then you need the compressor replaced and should check your warranty, this is often an expensive repair.
SOURCE: MCBR240s Magic Chef Fridge does
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
SOURCE: I have a Magic Chef
Quite often when the door gets open for a extended period of time the vents in the ceiling of refrig.compantment where the cold air from the freezer enters the ref.section...by looking up in the rear of the ref.ceiling you should be able to see these vents and see if they are frozen..if they are frozen a hair blow dryer will thaw them
Where here in the east coast are ya im 20 miles north of the epicenter in dumfries va
