Freezers Logo
Stacy S Posted on Oct 07, 2012
I have an amana upright deep freezer- AFU2067BW- never used- when I plugged it in it froze water for a couple of days and then it went back to being water.. It isn't staying cold, seems like the f
3 Related Answers
Anonymous
  • 1314 Answers
  • Posted on Jan 18, 2008
SOURCE: amana self defrosting upright freezer - drain plug
The subject is a Eureka Model 350 hand held steamer that can be found at Lowes and other places for around $49.95. With this steamer you can thaw out an evaporator as quick as if you were using a heat gun or hair dryer but without the slightest concern about melting plastic or wiring. By using steam instead of pouring water (yes many still do) there is little to clean up. With the many attachments it comes with there are other uses (i.e. cleaning, thawing drains, thawing IDI fill tubes, etc.). The steam also makes the replacement IDI fill tube (rubber end) more pliable and easier to complete the installation when used at the end.
This unit has a trigger and can be used to blow out a stopped up drain on a refrigerator by letting the pressure build up a little then blow through the drain with one of the attachments. As for thawing out evaporators it had a fine jet tip for actually CUTTING through solid ice.
Another great use for this tool is refrigerator door gaskets. The hot steam works faster than a heat gun with out the worry.
Note: Do not aim steam directly onto the plastic freezer liner. The rapid temperature change could damage the liner.
Anonymous
  • 43501 Answers
  • Posted on Aug 20, 2010
SOURCE: Amana Freezer DeepFreeze AFU2067BW 19.6 Cu. Ft. ice in bottom
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
muntejaya
Muntejaya Ginting
  • 10422 Answers
  • Posted on Dec 15, 2010
SOURCE: Amana upright deep freeze model AFU1505BW K3: We
Please check your compressor and capacitor for malfunction. Check also the current draw and compare to your manual. If you got lower ( very low ) current draw reading , you problem with compressor. It may run out of refrigerant and need to top up.Also check your thermostat setting adjust to medium or a little bit colder.
My deep freezer when plugged in will not run and i also get no light this was after i had wash it with water what can i do David Burke
check your electrical outlet the freezer plugs into using a lamp
if it won't turn on check and, reset the house circuit breaker.
The freezer is defrosting
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
2helpful
heatman101
Water/Ice pooling in bottom of freezer
check out the drainage hole if it is properly closed.
How to disable deep freeze? plz give me solution.
If there are two compressors on your unit, disconnect the freezer compressor. If only one compressor, nothing can be done as the fridge and freezer piping are in series. Assuming you have an upright fridge.
Upright Deep Freeze Stopped Working
the compressor relay is gone For a few dollors you can still save it.
Amana upright freezer leaks water on floor instead of in drip pan under it.
check the flor of the freezer if it is caked with ice your defrost drain is clogged
if not
take off the back panal
under the machine follow the drain tube
to the drain pan clean out your duck bill and make sure the tube is in the pan
2helpful
New freezer. 15 days old. mildew smell in the
There is a curing process for the foam used to insulate these. It can give off a pungent odor until it is fully cured. Only experienced it a couple times in the last 20 years. eric
Amana self defrosting upright freezer - drain plug
Top Amana Freezers Experts
ADMIN Andrew
ADMIN Andrew
goneforever.
Are you an Amana Freezer Expert? Answer questions, earn points and help others
