Question about Whirlpool LTE5243DQ Combination Washer/Electric Dryer
Thin twin washer basket is VERY off balance and once a cycle runs, there is water filling up under the washer / spin basket.
I recently moved into a condo. It came with 5 appliances, including a Whirlpool Thin Twin washer dryer combo. I ran 1 empty load of laundry with bleach, in hopes of cleaning the machine... and when it got to the spin cycle, it was making a pretty loud banging sound. Once completed, I went to look into the washer itself, when I realized that the washer / spin basket was severely off center. When I went to try & straighten it, I realized that under the washer basket had filled up with water. I was wondering how I should go about trying to remove this water, if there is a risk of the water suddenly flooding my condo... and also, how big of a repair job this is. Is this something that I could take care of myself, or something that will require a professional? Hopefully someone can email me with some advice. Feel free to contact me directly: [email protected] Thanks in advance
    Novelist:
    Champion:
  • 233 Answers
You should be able to put it in spin and remove the water. if it don't you have a problem somewhere. There should be 3 springs hooked to the bottom of the tub to hold it on center if one breaks or comes loose it will be off balance. If you get water in the tub when not useing it and the water is on from the water line the water valve is leaking.If the water don't shut off when filling the water level switch could be bad.or the tube running to it could be stopped up pull the hose off the water level switch and blow through it if it bubbles in the tub it is ok. If can't blow through it it is stopped up.Hope this helps
Posted on Jul 16, 2018
5 Suggested Answers
Anonymous
  • 87 Answers
SOURCE: Whirlpool Thin Twin Stopped Spinning at End of Cycle, H20 Will Not Drain
You have a sock caught in the pump, need to pull off outer case and remove pump and clear it out.
Posted on Jun 08, 2007
IFIXALL
Archie Ferrarini
  • 869 Answers
SOURCE: Whirlpool Thin Twin washer won't start, just makes humming sound
The belt is broken and needs to be checked for any other part that has failed causing the belt to burn.
Posted on May 26, 2008
Anonymous
  • 1122 Answers
SOURCE: Whirlpool Thin Twin YLTE6234DQ2
YOU CAN DO THIS.,POP THE FRONT PANEL OFF,GO TO THE SWITCH PLUG JACK ON RIGHT SIDE UNPLUG JACK,ON THE SWITCH SIDE WIRES CUT THE OUTSIDE WIRES PUT THEM TOGETHER WITH WIRE NUT,LEAVE GREEN WIRE ANONE,PLUG BACK INTO JACK,YOUR DONE,REMEMBER NOW IN THE SPIN CYCLE IT WILL WORK BUT WHEN YOU OPEN THE LIP IT WILL NOT TURN OFF SO KEEP YOUR HANDS OUT OF THERE,THANKS-MIKE
Posted on May 28, 2008
agitateme
Dan Sharpe
  • 88 Answers
SOURCE: Whirlpool Thin Twin washer/dryer
Check the lid switch, the machine will not spin or drain without the lid switch being activated. You should be able to see if the switch actuator is broken or missing, look in the slot where the lid's plunger drops into, if you can see the gray plastic actuator, set the machine in the spin cycle and try to depress the switch with a flat screwdriver, if it runs, the switch is cracked and needs replaced, if the actuator looks fine, and you can hear a distinct "click" when you press down on it, it may be a problem in the timer, but check the lid switch first, that's most likely the problem.
Posted on Sep 18, 2008
Anonymous
SOURCE: Whirlpool dryer does not start and beeps.......
Same problem here, however I can assist the start by rotating the drum while pushing start. May be a capacitor problem???
Posted on Sep 27, 2008
There seems to be water trapped at the top inner drum due to water inlet pouring miss and filling where it shouldnt
The inner basket has a balance ring that is filled with liquid by design. Suspension parts are most likely causing your problem
Oct 09, 2018 | Washing Machines
Started filling, made a loud noise, stopped filling immediately, door wouldn't open. I tried everything to get it to open. Running the spin cycle finally got the door open at the end of the cycle, though...
The washer drain the water if you put on spin. all electronically controlled washer won't unlock the door and or spin if there's water inside the water has to be drained out first.If the basket didn't move(no motor movement) and it finished the cycle, POSSIBLE problem is the motor control board. Motor Control Board 00436461
Nov 22, 2017 | Siemens WFXD5200UC Front Load Washer
Tub does not move during wash cycle;just keeps filling;timer jumps from 25 to 4:then drains;flashes OL(small loads)
First, OL/UL stands for "Overload", so in other words, the washer things the tub is too hard to move because it's overloaded and the motor is struggling or the unit is way out of balance causing the washer to struggle. The most common problem is a nut below the inner tub that needs to "float". Floating is when the tub fills up with water to a certain level the inner basket will rise about 1 inch from the center agitator. What this does is disengage the basket from the motor so that the agitator can rotate independently from the basket. If the basket does not float then when it tries to agitate the whole basket will turn back and forth at the same speed as the agitator and this will cause the OL/UL error code.
Nov 21, 2012 | Maytag Bravos MTW6600T Top Load Washer
My thin twin wont drain. Checked drain pump and it was clear. When i got all the water out it would spin. It will fill, agitate and spin(as long as there is no water)
The basket drive and or clutch need replacing, as long as their isn't the added weight of the water it spins yet add 250 pounds of water weight its slipping
Aug 03, 2011 | Whirlpool LTE6234D Top Load Stacked...
Im able to start a load, water fills, washer agitates and rinses just fine. However, once the spin cycle starts, the washer starts to make an extremely loud noise (similar to when it is off balance) and my...
If you can move your basket up and down your spinal is broke at rear of basket..You would need rear tub and inner basket for that repair......If this helped please vote need more help please ask...
Feb 03, 2011 | Kenmore 24032\24036 Top Load Washer
Is some water in the tub of a top loading washer normal?
It is normal to have residual water in the drain lines and pump following a wash cycle. This is the low point of the drain cycle and gravity will ALWAYS cause some water to be there. As long as the water is not visible in the spin basket, you have nothing to worry about.
Some model washers also have a balance ring around the perimeter on top of the wash tub that is filled with fluid. This acts as a stabilizer to help keep the washer balanced during the spin cycle. If you have any questions, please post back and let me know. I hope this is helpful to you.
Apr 21, 2010 | Whirlpool WTW5200S Top Load Washer
My washer does not spin or move during wash cycle the moter runs but nothing is moving.
Hi, this motor has faulty windings, causing it to lock up and not rotate the drum/basket. replace this motor asap if possible.
May 29, 2009 | Kenmore Washing Machines
Whirlpool Ultimate Care II spin cycle not functioning correctly
It sound like the basket is out of balance. When it spins open the lid and see if the basket is moving side to side and back to back. If so look under the deck and see if there is springs or rubber ties attached to the basket.
Jan 19, 2009 | Whirlpool LSQ9665JT
Water fills the washer during spin cycle
defective timer...a model # should be under the lid...or open dryer door and on front dryer panel right hand corner..onthejob
Jan 16, 2009 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool LTE5243DQ Combination Washer/Electric Dryer Logo
765 people viewed this question
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Ned Halaweh
Ned Halaweh
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
