Question about Motorola Mag One BPR40 Two Way Radio
How do you program the programmable buttons on a bpr 40
Posted by Bill Harris on
Mot-Dealer
  • 35 Answers
You will need programming cable and programming software
Posted on Jun 11, 2014
1 Related Answer
eradiostore
eradiostore
  • 1658 Answers
SOURCE: We purchasedn 3 bpr 40
Your new radio is likely not programmed the same as the others. A continual tone indicates a channel which is not programmed (doesn't have a frequency installed).
The other thing which can cause a tone, is a low or uncharged battery. You might try switching one of the known good batteries to the new radio to see if it will work. If you still have the same continual tone with a known good battery installed, you have a programming issue. If the battery swap solves the problem, then you need to investigate why your battery isn't charged up.
Either way, contact the dealer where you purchased the BPR40, they should provide programming free, or a warranty replacement battery for free. If you ordered online or by mail, and you just received the radio within the week, you should request they provide return shipping for you.
Best regards.
Posted on Sep 14, 2011
Washing Machine AEG Lavamat L64850 - cant change the washing time?
Not all of the options on the AEG Lavamat L64850 are available with every cycle. The Time-savings option isn't compatible with the 40-60 Mix program. See ManualsLib, https://www.manualslib.com/manual/555025/Aeg-Lavamat-L64850l-7kg.html?page=16#manual , for the various washing programmes and the available options.
You can get the full manual for your washer at AEG, https://www.aeg.co.uk/support/download-manuals/ . There are several models listed. The direct link to the manual for the L64850L/91452556002 is currently http://www.electrolux-ui.com/DocumentDownLoad.aspx?DocURL=2013\132\950431EN.pdf .
I hope this helps.
Jun 14, 2018 | AEG Washing Machines
Forgot how to programme radio stations on Philips Micro System MC-222
Tuning to radio stations
  1. 1 Select TUNER source. ? TUNER is displayed briefly.
  2. 2 Press BAND once or more to select your
    waveband.
  1. 3 Press down on TUNING a? or a? and release button.
    ? The radio automatically tunes to a station with sufficient reception. Display indication during automatic tuning: SEARCH.? If a FM station is received in stereo, STEREO is shown.
  2. 4 Repeat step 3 if necessary until you find the desired station.
To tune to a weak station, press TUNING briefly and repeatedly until you have found optimal reception.
Programming radio stations
You can store up to a total of 40 radio stations in the memory.
Automatic programming
Automatic programming will start with a chosen preset number. From this preset number upwards, former programmed radio stations will be overridden.The system will only programme stations which are not in the memory already.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to select the preset number where programming should start.
Note:
- If no preset number is selected, default is preset (1) and all your presets will be overridden.
Press PROGRAM for more than 2 seconds to activate programming.? AUTO is displayed and available stations are programmed in order of waveband reception strength: FM followed by MW and LW.The last preset automatically stored will then be played.
Manual programming
Tune to your desired station (see "Tuning to radio stations").
Press PROGRAM to activate programming. ? PROGRAM flashes in the display.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to allocate a number from 1 to 40 to this station.
Press PROGRAM again to confirm the setting. ? PROGRAM disappears, the preset number and the frequency of the preset station are shown.
Repeat the above four steps to store other stations.
Jun 19, 2016 | Philips Audio Players & Recorders
Is motorola cls-1110 compatible with bpr40 radios
yes, with conditions. The CLS comes preprogrammed with frequencies and tone codes. The BPR requires software and cables. It is not a preprogrammed business radio, but a fully programmable business radio. If your BPR radios are first: UHF, then they can be programmed to match the CLS. Do note, a few of the CLS frequencies are approved by the FCC for low power only, meaning a maximum of 2 watt power output. Find a dealer willing to do the programming for you if you do not understand. Our shop does it often.
Mar 14, 2015 | Motorola CLS 1110 (1 Channel) 2-Way Radio
How do I set to scan BPR 40
This is only done through use of the programming software and cable. Your radio would need to be reprogrammed.
Feb 07, 2014 | Motorola HT1000, MTS2000, MTX8000/9000...
What do the buttons on the bpr 40 do?
Both buttons have a short and a long press function. The button right below the PTT button is typically programmed to short press Monitor, long press Sticky Monitor. The bottom button comes from the factory on scan/nuisance channel delete. The buttons can be custom programmed when the dealer is programming the radio, so these are just a general guess based on the factory default setting. Other options include repeater talkaround, high/low power, volume set, and maybe tight loose squelch.
Best regards.
Oct 07, 2012 | Motorola Mag One BPR40 Two Way Radio
My bpr 40 all time have a green light on in a scan mode how i can block the scan mode
In order for your radio to scan, it would need one of the side buttons programmed to scan. Usually the top side button is programmed for monitor/sticky monitor, and the bottom button can be programmed to any of a number of features, one of them being scan. These buttons have both a long press selection and a short press selection. All this being said, it is possible the bottom button is programmed for scan. Try pressing it a short press and/or a long press and see if it shuts off your scan. To remove scan completely from your radio it would need ot be reprogrammed by an authorized Motorola dealer.
Best regards.
Jun 17, 2012 | Motorola Mag One BPR40 Two Way Radio
We purchasedn 3 bpr 40 and we justed ordered another, when we turn the bpr on to the channel of the 3 others that are in use, we just get a low continual tone, i tried a radio check on channel 1 with no...
Best regards.
Sep 14, 2011 | Motorola Mag One BPR40 Two Way Radio
How do you program a mute button for the speaker phone? It doen't have an actual mute button. Been doing some online phone meetings and the instuctor keep saying mute the phone.
It depends on what the phone is plugged into. The SP-308 and 616-ex don't have programmable buttons. The 616-Flex and higher, up to the 96ex do. In a Flex, it's based on *40 under a flex button.
Carl
Aug 08, 2011 | Vodavi Enhanced Starplus SP-61612 Corded...
Need a free download of an operating manual fo the motorola bpr 40
I need a service manual of motorola T 5417 A ,. I hope you can help me . Thanks a lot
Nov 07, 2009 | Motorola Radio Communications
Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Jan 24, 2008 | Zanussi ZWF1430W Front Load Washer
Motorola Mag One BPR40 Two Way Radio Logo
371 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Jane
Level 1 Expert
Muntejaya Ginting
Muntejaya Ginting
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
