Question about KitchenAid Artisan Series Tilt-Head Stand Mixer
If you have also tightened up the screw that you can see from the front in the middle where the hinge pivots when head us up then that's where your problem is. That is the head height adjustment and is to set the flat paddle to just clear the bowl when the head is down.
Posted on Aug 05, 2017
SOURCE: the locking pin on the
I had the same issue. I just finished tearing mine apart only to find that the lock just wasn't engaging with a slot in the base of the mixer. Try lifting up the head of the mixer to expose the height adjust screw in the hinge between the base and the head. By tightening mine down a couple of turns, the lock can engage the slot again and the lock works. You may have to do a little tweaking to find the right balance between height adjustment and latch functionality, but at least you won't have to tear your mixer apart like I did!
Posted on Apr 03, 2009
SOURCE: KitchenAid Artisan KSM150BOB Stand Mixer won't start
It could be very easy. It maybe you have a the brush in the
wrong way round or they have simply run out. They are on the sides under the black plastic caps. Although they will fit in the hole any one of 4 ways
round, there is a key on one corner which means it will only go in one
direction. Use a torch to look into the hole before you put it back in.
They shoud look like this : brush
Posted on Jan 24, 2010
SOURCE: Brand New Kitchenaid Artisan Mixer - Mixer head is stuck
Unplug the mixer, turn the whisk the opposite of normal rotation in a quick motion, the remove a per normal.
Posted on Feb 20, 2010
SOURCE: mixer head loose
Referring to the diagram on:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10157992.pdf
Remove the screw, item 22, to remove the trim band around the mixer. This will reveal 4 screws which hold the top cover on. Remove the screws and lift the top off. Find all the screws which hold the gearhead in place and tighten them all. If you want to make the fix a permanent one put some thread-loc compound on each screw and tighten it.
Posted on Mar 30, 2010
SOURCE: I have a KitchenAid Artisan stand mixer (325
the solution to this is to tighten the screw visible through the base that intersects the pin. Turn the machine upside down and using a long flat screwdriver tighten the screw.
Posted on Apr 07, 2010
Jul 10, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Sep 05, 2013 | KitchenAid Kitchen Aid KSM150PSWW -...
Mar 30, 2013 | KitchenAid KITCHEN AID 5 Quart Artisan...
Aug 03, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Apr 10, 2010 | KitchenAid Artisan Series Tilt-Head Stand...
Oct 31, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Oct 03, 2009 | KitchenAid KSM150PS Artisan Series Stand...
May 20, 2009 | KitchenAid KSM150PS Artisan Series Stand...
May 03, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Mar 01, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Jan 23, 2021 | Jenn-Air Attrezzi JSM900 Stand Mixer
395 people viewed this question
