Question about RCA 27F534T TV
RCA 27F534T TV Remote Sensor not compatible with RCA DVD remotes
I've owned my 27" RCA TruFlat SDTV (27F534T) for several years now with no problems. I do, however, have a frustration.
I also own an RCA DVD player, and the DVD player's remote interferes with the RCA TV's remote sensor. Shouldn't these two be compatible? Using the right and left arrow buttons on the DVD remote to navigate a DVD menu changes my TV's aspect ratio, pressing up on the DVD remote changes the TV's channel setting, pressing the DVD remote's power button will simultaneously turn the TV off, or on, and pressing the DVD's menu button also brings up the TV's menu.
I thought that perhaps this was a problem with my specific RCA DVD remote, so I tried the remotes of 3 different RCA DVD players with my RCA TV and ALL 3 REMOTES had the same problem. Clearly the TV's sensor has a problem. No other RCA TV in my house (there are 2 others) have this problem. My friend also owns this model TV, my DVD remotes interfere with his 27F534T TV too.
Does anyone have this model RCA TV and an RCA DVD player? Is there any Universal Remote available that will correctly work both the TV and DVD player without interference? Can a repair shop replace the remote sensor with one that's compatible with RCA DVD remotes?
This issue is a minor frustration; I could move the DVD player somewhere else. But I shouldn't have to deal with remote compatibility issues when both products are the same brand.
Posted by marinoda08 on
  • simply_me_49 Mar 24, 2009
    I have an RCA Truflat SDTV but cant fidn the channel to play dvds on..
    does anyone know what channel it is??
5 Related Answers
jerryg50
Jerry Greenberg
  • 1691 Answers
SOURCE: front panel button turn tv on and off
If both the remote and the front panel buttons do not work, I would be thinking that it is a problem with the TV's main uPC area. This type of fault can be involved, and would require factory level service where the fault can be properly analysed.
I can tell you in advance, that this type of fault can be expensive to service.
Jerry G.
Posted on Jul 30, 2008
jason
  • 905 Answers
SOURCE: Why does my RCA TV cycle through channels on its own?
this is the same type of problem happening with other rca models and I know it is the EPROM CHIP but why this is failing is either because of design flaw , dirty enviroment that they were made in , to much voltage or current to the chip or too much of a draw from the chip causing it to fail . Or even a random frequency from the IR sensor or its circut I'm still investigating and testing.
leave the tv unplugged for at least 3 weeks durring this time resolder any solder that don't look good , I did this and it lasted for about 6 months(always plugged in to the wall) before it started doing it again. model # 27v412t
Posted on Oct 06, 2008
Anonymous
  • 76 Answers
SOURCE: can't find aux channel to view vcr/dvd
use vid 1 or vid 2 input on remote should do that if not then use a differ code in your universl for your tv that makes it work or type 00 should get u there another way go to channel 1 and then down arrow it will go into it if not go into your add channel menu and add them then down arrow
Posted on Dec 03, 2008
Robert
  • 176 Answers
SOURCE: My DVD player is hooked up to my RCA truflat but i
There should be a button on the front of the TV that says TV/VIDEO or INPUT. Turn on the DVD player and put a DVD in it and press play. Press the TV/VIDEO button until the picture is present.
Good Luck....
Posted on Jan 19, 2010
Joaquin Hernandez
  • 65 Answers
SOURCE: have an RCA sdtv Truflat, plug it in and i have a
try changing the Eprom Ic
Posted on Feb 16, 2010
Dvd player won't play
It sounds that the laser pickup unit of the DVD player have damaged. Check and replace it.
I have rca tru flat tv w/built in dvd and i have universal remote I cant get the dvd set on the remote also I cant get dvd to rewind or fast forward
Hello
It will be very difficult to get all functions of the RCA device, synchronise with a universal remote control. Just find a code, whic has maximum finctionality. That is all we can do. Just try an other code for RCA TV to universal remote. I hereby send some codes to check. OK
TV: 1144 DVD: 3423, TV: 1146 DVD: 3424
TV:045 DVD:091
I have a (i think 20 inch) rca truflat tv and i can't find the channel for video and dvd. the manue didn't help and i don't have the guide"
Press menu on your remote. Press "4" for channel and "4" for video input source. In this menu, you can toggle between s-video and regular video (yellow plug) input. The disadvantage is, if you're like me and you've got a DVD player and and VCR (or maybe a video game system) all hooked up to the same TV, you've got to go through the menu and switch the inputs to watch something else. I'm happy with my digital audio cable; I'll deal with yellow-plug video.
My RCA TruFlat 27F520T 27" TV started acting up.
The buttons on the tv are the problem. I clipped the prongs on one of mine and fixed it .Just use the remote now
1helpful
I have a RCA 27" flat SDTV purchase in
Ur power inverter board is dead.
U need new one.
My RCA 32 ' SDTV TrueFlat doesn't come on
sounds like you have the parental lock on to lock the buttons on the tv and the remote look in your manual for the tv to see how to fix it and if you dont have it there should be one online
I lost my original remote for rca sdtv 27" and somehow managed to get out of the front input, and can no longer watch my satellite, I read that there was a code that should take me back to it but when I...
www.remote.com not only has factory replacements they have univesals that have been proven to wrok so I would check them out you be glad you did, thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Turning off Closed Captioning
On the 27" TruFlat the closed caption button is hidden within the DVD buttons. You have to press it multiple times to shut off closed caption. It seems to have multiple sources for closed captions. Press the button until no source appears on the screen. ITS CONTROLED AT THE REMOTE CONTROL - NOT ON THE ON-SCREEN TV MENUS. Good Luck
Unlock rca truflat tv with no remote
Buy a universal remote and program it for the TV. That's the only thing that will work.
RCA 27F534T TV Logo
Top RCA Televison & Video Experts
 Francisco Mauricio...
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
