Mitel 5220 IP Phone Logo
A
Anonymous Posted on Oct 06, 2012
My Mitel 5224 IP phone is stuck on "waiting for COMMS. . ." screen after reboot
5 Related Answers
Anonymous
  • 378 Answers
  • Posted on Apr 04, 2011
SOURCE: how do i manually configure
Press and hold the up arrow.
Configure Phone - Yes
network parameters - yes
press no until you see "change" and press yes.
You will need to set the following appropriately.
IP address, Subnet address, default gateway, ICP controller address, TFTP address, VLAN ID, VLAN priority, DiffServe Value, DNS address.
Normally it is not necessary to set the phone static except for testing. If your network and DHCP server is set up properly, you are not gaining any benefit for setting it static.
Also, you should find out what the other IP addressess are that are static on the Voice subnet. Along with that, you will need to know the DHCP range. These are needed so you don't assign a duplicate IP address to your network. Assign the phone to the wrong device could do great harm to your network. Assign it to use the same IP address as the phone system and none of your phones will operate.
Use with caution,
Mark
Anonymous
  • 378 Answers
  • Posted on Apr 15, 2011
SOURCE: employee left and didnt leave
You will need to contact your system admin or vendor.
Anonymous
  • 378 Answers
SOURCE: Can i connect a mitel 5224 ip phone to a standard
only with a "Line Interface Module". This is a module that attaches to the back of the phone. Once attached a button will need to be programmed to allow it to work.
The phone will still need to connect to the telephone system - SX200ICP or 3300/MCD.
Anonymous
  • 378 Answers
  • Posted on Apr 18, 2011
SOURCE: How do we reset the
Your system admin or vendor will have to default the password.
Anonymous
  • 378 Answers
  • Posted on May 01, 2011
SOURCE: What is the pinout for the headset port of the
No idea. Contact Plantronics for a headset. This phone will support a variety of headsets. www.plantronics.com.
Mitel 5224 not showing any signs of life
You should have received a power supply with the phone. If it is new, and will not turn on at all, there is a good chance it is not plugged in correctly. You should have two Ethernet cables plugged into the rear of the phone. One for Data, and another for power.
Once on, it will still have to be set up by your IP Service provider.
How do I clear a Mitel 5224 which is displaying locked out
Set type is wrong or the phone is a IP device only
How to set time on a mitel 5224 phone
Need to get access to the phone system to change the time
My screen has gone blank and I can't fix it. Im not sure which keys to pretty or what the "change" key is. I have a Mitel 5224 IP Phone. Please help ASAP!!
With phone idle press the up arrow key. This controls the contrast of the phone. Or try to reset the phone.If that doesn't work get a new phone.
Can i connect a mitel 5224 ip phone to a standard land line connection.
Hi =) I have a mitel 5224 which i connect to my
the stand requires configuration to tell it how to connect to your Wireless router. The default IP address is 192.168.1.20
The firmware should be upgraded to 2.0.3.ap51. This provides for better security and more options.
What is the pinout for the headset port of the mitel 5224 IP phone?
Top Mitel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitel Computer and Internet Expert? Answer questions, earn points and help others
