Question about Casio Cassiopeia E-125 Pocket PC
Can not see Pac Man game when using Cassiopeia E 125
I have only used this PDA for contacts and appointments for the past several years. While going through some paperwork, I found a CF card with PacMan game on it that was included for the E-125. I loaded it onto the PDA and tried to play it. I can hear the game, but nothing shows up on the screen. When I tap the screen, it pauses the game (that I still cannot see) and then it gives me options to either save the game, end the game or go back to the game. That part I can see. I can access help for the game as well, but can't see anything on the screen. Lots of PacMan noises, but that's it. Everything else on the PDA works fine. This is from the fun pocket PC expansion Pack and includes eBooks and skin covers.
Posted by kizbit123 on
3 Related Answers
Anonymous
  • 3 Answers
SOURCE: Lost data?
leave the backup battery in the PDA and bring it back to life with this how to ;)
http://youtube.com/watch?v=l0TT5CnbwBQ
if that doesn't help you may need to give the battery a little kick-charge for the PDA to recognize it again. the PDA "thinks" there's not battery if the battery voltage is below 2Volt.
to "kick-charge" the battery just get a AC adaptor with at least 5V and 1A (a.k.a. 1000mA) with 2 wires and connect them to the battery pins (with "+" and "-" correct!)
if you have your PDA lying in front of you with the display down and the battery cover opened, the pins of the battery are as following:
left: plus
middle: charging/temperature (not important for hand-charging)
right: minus
connect the wires of the AC adaptor correctly and let it "kick-charge" for about 5minutes (but NEVER let it charge any longer if the battery is getting hot!!!!)
after that, the PDA should recognize the battery again because the voltage is more than 3Volt again.
but don't (!) try to power it up after kick-charging!
the batterys voltage is higher than 3Volt again, but it takes just a few seconds to empty it again if u try that.
it's only for the PDA to "see" the battery again ;)
Posted on Jan 15, 2008
Anonymous
SOURCE: Cassiopeia E-125
I had the same problem with an E125 which I brought off eBay that hadn't been used for several months.
I took out the backup battery and put the main battery in it's holder with a bare wire held onto the negative & positive terminals.
When I turned on the charger, I held the other end of the bare wires onto a partly charged Nokia Battery (Also 3.7V internal). The current from this battery was enough to let the Casio start charging.
After two minutes I disconnected the Nokia battery and gently tugged the bared wires free. The Casio kept on charging happily.
After six hours I disconnected the AC charger, installed a new backup battery CR2032, and everything was go.
Posted on Oct 01, 2008
Anonymous
  • 10 Answers
SOURCE: PDA clock and appointments change at sync by one hour
I am running vista and havent had this problem, as a matter of fact if you have vista you no longer need activesync. Vista comes with a built in software application to sync you PDA, there si no logical solution i can think of that would cause this problem other than your computer may need to be updated, and also vista will update all the drivers for the dell x30 as well, just make sure it is able to do all updates, not just microsoft ones.
hope this works for you!
Posted on Mar 27, 2009
Lost my box with my key and want to load game on new laptop i have my receipt of purchase - would that help
As a ahem.. work around.. you could download and use this as you do own it so using this should be OK.. http://thepiratebay.org/torrent/3695899/PC_Pac_Man_World_3_(c)_Namco_Rip_3_(ToeD) get uutorrent if you don't have it download from www.uTorrent.com. Simply install run accept defaults, and get the torrent by double clicking on the name in PB. 1.: Unrar archive!2.: double click > ToeD.exe < to install the game 3.: Launch Game with > pac-man world 3.exe < (Gamefolder) 4.: enjoy! use trainer if you want!
Feb 06, 2010 | Namco Pac-Man World 3 for Windows
Lost data?
left: plus
right: minus
Dec 05, 2007 | Casio Cassiopeia E-125 Pocket PC
Cassiopeia E-125
Aug 25, 2007 | Casio Cassiopeia E-125 Pocket PC
Need help on connecting E-125
I doubt it... I mean it is unlikely there is any incompatibility there. Go to your device manager and make sure that your USB ports are installed and configured properly for your USB cradel.
Sep 06, 2005 | Casio Cassiopeia E-125 Pocket PC
E-125 Will not power up ??? HELP
i made a video how to fix your dead Casio Cassiopeia PDAs.
AFAIK it works on the following models:
Cassiopeia E-10 (AFAIK)
Cassiopeia E-11 (AFAIK)
Cassiopeia E-15
Cassiopeia E-100
Cassiopeia E-105
Cassiopeia E-115
Cassiopeia E-125
Cassiopeia E-55 (= Japanese Version of E-15)
Cassiopeia E-5xx (Japanese Versions of the E-1xx Series)
Maybe it's also applicable to the EM-500 and EM-505 ...
and read the description pls :)
Microsoft Outlook data won't synch
In ActiveSybch there is an option of setting the priority of either the PC, the PDA or leaving the items unresolved. You can either change this of follow another route. With the device off the cradle delete the partnership WITHOUT deleting the partnership folder. Place the device on the cradle & let AS find the device & setup the partnership. Once setup remove the device & go to options & set all the required options. Replace the device & it should synchronise. If you still have problems please contact me directly through email.
Sep 06, 2005 | Casio Cassiopeia E-105 Pocket PC
E-125 connecting to Siemens ME 45
There are 2 things you could try. If you have a serial data cable for both the devices try using a nul modem (Casio part # SB-91 includes best nul modem ever made ) & select Hayes compatible on serial port on E-125. If you have a built in modem in ME-45 it should work. Similarly you could use MS Outlook as an intermediary for transferring your E-125 telephone numbers to ME-45.
Sep 05, 2005 | Casio Cassiopeia E-125 Pocket PC
Casio pocket pc calendar doesn't show appointments that were syncronized from outlook: If I sync with outlook, the appointments I add on the Casio E-125 show in outlook, but the ones I add in outlook...
The Menu: VIEW - Categories option at the bottom, has all categories checked off. However, the logic dictates that it will only show the categories checked off, and if any appointment (appointments being made in outlook are not categorized) with no category would not show in the pocket pc. The logic written into the software, is, if no categories are checked off, then it will show ALL appointments. It would be nice if there was an option in the category view menu to SHOW ALL, but there isn't. You just have to uncheck all the categories.
Cassiopeia E-125 & Nokia 7650
You will need 2 things. Software to load on your E-125. The included Cd with your Nokia should have it. You will need a special cable to connect Nokia to E-125. I don't know where you will find it easily. There is a firm in Finland which makes all kinds of cables to connect different models of Cassiopeias to different models of mobile phones - essentially Siemens, Nokia & Ericsson. They run about US$ 50/= Last time I saw their listing it was 4 pages long. You might have to do some searching on the net or contact Casio for information. Hope this helps.
Could someone help me please? (Newbie Alert!)
There are several types of processors used - find out which yours has and be sure the software will work on that processor. ARM SH3 Mips are the three as I recall. I have three hand units and two different processors.
Sep 05, 2005 | Casio Cassiopeia E-105 Pocket PC
Casio Cassiopeia E-125 Pocket PC Logo
Top Casio Computers & Internet Experts
k24674
Gene
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
