Question about Insignia 32" 720p Flat-Panel LCD HDTV
Both my dvd players only play black and white on new lcd hd tv
I bought a new 46" samsung 630 high def lcd tv. Both of my old dvd players that work in color on our other tv's, will only work in black and white on the new tv. We have not had a cable service plugged in yet, but we have plugged in a camera to the tv and viewed photo's in color. There is also a color test in the tv menu that worked out fine.
Posted by jeffmyron on
5 Related Answers
crispin melchor
  • 231 Answers
SOURCE: Pink and Green on Non HD Stations
what is model of unit?
Posted on Nov 30, 2007
Anonymous
SOURCE: Full screen view
in order to get the full HD experience you should be using HDMI cables. if you're using the white/red/yellow cables then your HD channels will not broadcast in full HD and you'll be stuck with the annoying black things around your screen
Posted on May 27, 2008
lukster
Luther Stephens
  • 217 Answers
SOURCE: HDMI INPUT FOR NON HIGH DEF CHANNELS WILL NOT DISPLAY FULL SCREEN
if you have a cable box then it is probably the resolution settings in the cable box, what type of cable box do you have
Posted on Jul 20, 2008
Anonymous
  • 56 Answers
SOURCE: Samsung 40'' tv can't get High Def when i connect to my cable plus
make sure your cable box is hd compatible, also depending on the cable box you may have to go through your settings and change the resolution and also change your settings through the menu's on the tv itself. what type of cable box do you have? is it a satellite box? which provider?
Posted on Apr 05, 2009
Anonymous
  • 9 Answers
SOURCE: black and white grainy output to new samsung lcd
Your DVD player is using a PAL or NTSC variant which is not supported by your display. Somewhere hidden in the depths of the options in the DVD player should be an option to change the composite output type.
Posted on Jul 07, 2009
How to set up to using hdmi
#1 your tv would need to be hdmi compatable (have the appropriate plug on the back where all the inputs are located). For example I have a 60" Lcd HDTV and an xbox360 I attached the standard a/v (audio/video) red,white,yellow wires to tv and turned on the game console went into system settings and turned on the hd setting to 1080i for hi def resolution. Another alternative would be to connect console to your dvd player (most new dvd players will up convert signal from 480i or 720i to 1080i hd) and attach your hdmi cable between the dvd player and the tv to support the hd interface. Something I highly recommend is the jvc th c50 home theater surround sound when I play call of duty it has enough to knock stuff of our bookshelves and ******** the neighbors. Happy gaming
Dec 09, 2010 | Video Game Consoles & Games
Plasma tv showing "Mode not supported" message
YOU HDMI SWITCHER IS DEFECT OR YOUR TV IS NOT COMPATIBLE
Apr 24, 2010 | Samsung PN58B860 58 in. HDTV Plasma TV
New lcd tv and dvd player is playing movies in black & white
1. Verify connections are color coded.
2. If they are correct, take out movie, press Play/Stop at same time on the front of the unit (not remote) to reset any settings that may have been changed.
Jul 04, 2009 | Coby DVD-536
Xbox
well then your tv is going out and you need a new tv
Nov 03, 2008 | Microsoft Xbox 360 Console
I purchased a new Zenith Tv and have hooked up my dvd player which is about four years old (Toshiba). The connections are all right but when I put in any disk (I have tried many) it registers no disk so...
try to use player on old tv again does it still work 4 yrs old dvd player is to old for new days dvs on new tv u def wann upgrade to 108p upscaling player samsung makes with hdmi cable to new tv flat screen or reg coneection will look 10 times better also older toshibia cant play read new dvds its terrible
Oct 07, 2008 | Televison & Video
Samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Apr 10, 2008 | Samsung LN-T4665F 46 in. LCD Television
Dvd player, hd dvd movies
If this is just a regular DVD player, then no. You need an HD DVD player to play HD DVD discs. Now the HD DVD players should play regular DVD discs.
Feb 12, 2008 | LG DR787T DVD Recorder
P3 not playing high def dvd
make sure your tv input is on the right selection
Dec 10, 2007 | Sony PlayStation® 3 (60 GB) Console
Hi-def dvd
This is not a High Definition DVD player, it does upscale a regular DVD to HD resolution, but that's just an electronic trick.
Also, Toshiba has abandoned the HD-DVD standard (did you find the discs on sale?), you'd need to find a BluRay player (like the Playstation 3) to play high definition DVD's.
Dec 05, 2007 | Samsung HT-Q100 System
Hdmi Issue
Most new HDMI DVD players use High-bandwidth Digital Content Protection (HDCP)on the HDMI output.If you try to play this on an older TV that is not compliant with these new standards it will not work.This standard came out late in 2004 that is why your older player still works. There is also a service bulletin from JVC about upgrading the software on your TV for HDMI compatiblity issues.If you want a pdf file of the bulletin I can send it to you.
Sep 11, 2007 | JVC HD-56G886 56" Rear Projection HDTV
Insignia 32" 720p Flat-Panel LCD HDTV Logo
732 people viewed this question
Top Insignia Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
