Question about Vizio L32 32 in. LCD HDTV
Dvd/vcr wont play and what channel too view - Vizio L32 32 in. LCD HDTV
Posted by khlj511 on
wzcintron
    New Friend:
  • 3 Answers
If the dvd/vcr has red/yellow/white cables, select as componet under your input options.(HDMI,TV,Componet,etc)
Posted on Oct 20, 2012
No signal to tv when dvd or vcrs is off
Assume no signal u mean no digital tv ?and what looses time and channel?do u recieve tv broadcasts via a box or is it built in?if u can recieve channels via dvd recorder i would assume where ever it gets them from needs to be connected to tv also.u dont say if its hdmi leads.scart or coax rf type.more info please
May 23, 2016 | JVC DR-MV5S DVD Recorder/VCR
How can I set the channel BACK to CH 3 from CH 4
1) Set your TV to channel 3.
2) Insert a pre-recorded tape into this unit.
3) Press the OUTPUT button on the DVD/VCR so that the VCR OUTPUT light is lit.
• If noise appears on the TV screen, press the VCR/TV button on the remote control.
4) Press the PLAY button once.
5) After a few seconds, press the PLAY button on the DVD/VCR for 3 seconds.
• The RF output channel will change to channel 3 from channel 4 and you will see a playback picture.
• When a picture does not appear on the TV screen, repeat step [4].
6) Press the STOP button to stop playback.
Nov 17, 2007 | Emerson EWD2004
I cannot get the Vcr/ Dvd to play
The TV needs to be on channel 3 not channel 3.1 because is a digital channel and the signal from the VCR is analog. Tune the TV to channel 3 to get the analog video from the VCR.
May 10, 2010 | Toshiba SD-V295
How to get all freeview channels-all i get is the first 5 channels
Go to menu, find "autoprogram" setting and select it. It will scan all available channels
Aug 17, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
How do you hook up the dvd player to the tv with a vcr hooked up to the tv
Leave the cable box powered on but disconnected from the TV or VCR. All other components should be disconnected and unplugged, giving clear and easy access to all connections. If components sit in an entertainment unit, make sure all A/V cables can reach the RF modulator and the cable from the modulator can easily reach the television.
  • Step 2 Hookup the first coaxial cable from cable box output, usually labeled "TV," "TV out" or "Out to TV" to the cable "In" on the VCR. Connect the second coaxial cable from the VCR's out to "TV" to the coaxial input on the RF Modulator.
  • Step 3 Connect the third coax cable from the coaxial cable "Out" jack on the RF Modulator to the coax cable "Input" on the television.
  • Step 4 Take one A/V cable, connect the red (right audio channel,) white (left audio channel) and yellow (video) from DVD player's "Output," to the corresponding DVD "inputs" on the RF Modulator. Place components as desired but still disconnected from power. Plug in all power cables including the RF Modulator's into the surge protected outlet strip.
  • Step 5 Make sure the Channel select switch usually found on the back of the VCR and the Channel select switch on the RF Modulator are both set to Channel 3. This channel is used on the television to view your components.
  • Step 6 Turn on the power strip and turn on the TV. Cable reception should come on as usual. Set the TV to Channel 3 and turn on the VCR. With VCR on test it by playing a video tape. The RF Modulator should sense the signal and automatically switch to "VCR."
  • Step 7 Switch off the VCR and with the television still on channel 3, turn on the DVD player. As the RF Modulator senses the DVD player signal and switches to DVD, its welcome screen should be seen on the television. Play a DVD to test and once you're done with the DVD turn it off and the cable should come back on.
  • Jul 15, 2009 | Televison & Video
    I need playback channel for tv to be ch.4 -
    Solution 1
    How to set the DVD Recorder+VCR’s RF output channel
    Turn off the DVD Recorder+VCR, then press and hold
    CH (v/V) on the front panel for about five
    seconds to change the RF output channel (CH 03 or
    CH 04). “RF 03” or “RF 04” appears on the front panel display.
    Solution 2
    Cable Service With Cable Box
    If a cable box is required in your cable system, follow the
    instructions shown below. This hookup permits both TV and
    DVD Recorder+VCR operation.
    To view or record a CATV channel:
    1 Tune the TV to the correct video input channel.
    2 Set the DVD Recorder+VCR to the output channel of the
    cable box using the CH (v / V) or the 0-9 keys on your DVD
    Recorder+VCR (e.g., CH3).
    3 Select the channel you wish to view on the cable box.
    Please rate this a fixya
    Jan 30, 2009 | GoVideo Go Video DVD/VCR Combo
    Can't get my VCR to work
    It sounds like you need to purchase a converter box from a place like Radio Shack. This box converts the signal so that your televison understands. I think this box is around $20.00. Just call Radio Shack our a place like walmart and tell them what is going on and they will fix you up. Then you can use channels 3 or 4. I hope this helps!
    Dec 31, 2008 | Televison & Video
    Unable to separate VCR playback from Sat. Receiver input,both av2
    try to find a multi-video selector swicth that the best you can do
    Dec 19, 2008 | Dynex DXR24TV 24" TV
    Video channel
    if your DVD player supports a HDMI cable a single cable is enough for both audio and video channel.
    but both your player and TV must support HDMI.
    Aug 12, 2008 | Samsung DVD-V4600 DVD Player/VCR
    Cannotsetorplaydvdorvcrtapes
    Please recheck the model. It looks like it is the DVP33040V/17 model.
    You said you cannot set or play DVD/VCR tapes.
    1. Is this unit hooked up properly to your TV?
    2. Is your TV set to its correct viewing channel?
    This is the tunerless model so the very basic way of connecting this to the TV is using the composite cables (yellow/red/white). Then find the correct viewing channel on the TV. Note:IT IS NOT CHANNEL 3 OR 4. It depends on your TV make. Most of the time it is called AV, VIDEO, INPUT, SOURCE, EXT, AUX, GAME,etc. Most of the time, the TV remote control has a specific button with those labels. You can also check your TV manual how to get the VIDEO channel when using the composite cables.
    Furthermore, if you would do recordings, you will need an extenal tuner (cable box or satellite box) for this unit. You have to connect an external tuner box using another set of composite AV cables - that is:
    AV out from the cable/satellite box to VCR IN on the DVD/VCR.
    May 18, 2008 | Televison & Video
    Vizio L32 32 in. LCD HDTV Logo
    80 people viewed this question
    Top Vizio Televison & Video Experts
    CoppellTVRepair.com
    Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
