Question about Cub Cadet Street Sign- tractor lawn riding mower parts
My cub cadet z force starter will not turn the engine unless I tap on it with a hammer, I replace the stater and still have to tap it to get it to turn the engine on. Any soultions
Posted by willheard2 on
mike butler
    Brigadier General:
  • 6,468 Answers
Sounds like you have a bad starter solenoid or a bad wire try and jump start it direct to the starter and bypass the cables
Posted on Oct 11, 2012
5 Related Answers
joboo1
Jim London
  • 257 Answers
SOURCE: transmission oil ? for cub cadet tractor
Hi, Cissy, Every Cub Cadet is different, and they keep their manuals to themselves. With your exact model and serial number, you can go to their website and view the manual for your model which should have the type of oil you need. Their website is www.cubcadet.com and go to service. If you have trouble, let me know, but I will need the model and serial. Good Luck, this should Fixya!
Posted on Mar 23, 2009
SOURCE: My cub cadet src 621 has been difficult to start
If its ripping you arm off the timing is off. Check the flywheel key it is more than likely sheared off. Pull the cover and look down on the flywheel and you should see this.Your unit is not clear to me so whatever unit you have check the timing and when its right it will not pull your arm off.Good luck.
Posted on Mar 25, 2009
Ben Dover
  • 1111 Answers
SOURCE: Engine will not start
you have atleast 2 safety switches on there. one under the seat and one one the brake. if either one would fail, the engine will not turn over! i had to replace mine last yr
Posted on Jun 17, 2009
Anonymous
  • 109 Answers
SOURCE: Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Posted on Jun 29, 2009
Anonymous
  • 4 Answers
SOURCE: I have a Cub Cadet lawn tractor that just stop
CHECK THE FUSE
Posted on Jul 02, 2010
I have 1999 cub cadet Z-54 with a kawasaki fd590 water cooled.I have to tap on the starter to get to turn over. the starter and solinoid are new. the old one did the same thing.
It probably needing an additional relay added to the starter circuit. I know some JDs using Kawasaki engines needed this as there was too voltage drop between the ignition switch and the starter relay for the starter to function properly.
Jun 29, 2015 | Cub Cadet Garden
My cub cadet lt1050 lawn tractor mower starts when cold fine, but wont even turn over when hot.
you have bad valves it needs a valve job this is because the hatter it get it looses power and will shut down when to hot
May 25, 2014 | Cub Cadet Lawn Mower PTO Clutch Replaces...
Starter motor hds 2165 cub cadet
One post, take a cheap thin wrench. Heat it, bent 90 d to fit in the space.
Apr 03, 2014 | Cub Cadet Riding Lawn Garden Zero Turn...
Cub cadet lt 1042
Some of those cadets (like those with the Command 20) have a compression release mechanism on the cam which is intended to make that engine crank easier but disengages once the engine fires up. It's a plastic part and is prone to break, resulting in a lot of strain on the starter motor. Interesting design, bad materials. Sometimes the engine will start anyway but this is not a good idea to operate this way. Pull the valve cover. Look at the motion of the exhaust valve when you turn the engine by hand. It will look similar to the motion of the intake valve if this part is broken. If it's working correctly, you should see the exhaust valve open slightly just after the intake valve closes. I'll attach a video to show what it looks like. Replacing the bad cam is a bit of work but not terrible.
Oct 04, 2013 | Cub Cadet Garden
I have a z force s cub cadet. The battery is good. Tested and passed. the engine/started must work hard to turn over, but still won't catch. I will jump the tractor and it will start and run.
You may want to try to find a battery with a stronger amperage rating. Even if the battery passes if it is borderline for starting it new it may not be strong enough even if it's still okay for it's battery type.
Other causes:
A worn starter can cause this issue. If a few of the coils shorted the starter will work but require much more current to do the job
A bad relay/solenoid to the starter that doesn't allow enough current to go through can cause this.
Valves out of adjustment... especially on some Briggs and Stratton engines, it's a known issue that if the valves need adjustment the motor can require a lot of energy to turn over and can cause constant hard starts.
Mar 28, 2013 | Mtd Cub Cadet 48 In 22 HP Kawasaki Engine...
Valve lash on cub cadet 19 hp kolher engine
have you replaced the starter how old is machjne
Feb 18, 2013 | Cub Cadet Garden
Cub Cadet 1641 won't start....
sounds like the battery doesn't have enough power to crank the engine
May 12, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet LT 1045 - Not starting, the engine does not turn.
remove the starter...use jumper cables to "run the starter manually...red to big lug, black to body (anywhere is fine) should torque hard at initial run and continue to run smooth...if it buzzes or vibrates, it's bad...replace...
Apr 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet lt1040. won't start. new battery. making a cliking sound when you try to start it.
I had the same problem the starter was the problem, found the stater will engage by itself not sure why but think it could be the wireing, or a swich. also check the solenoide it could be bad if the starter is bad.
Sep 26, 2009 | Cadet Manufacturing CADET SL Series Small...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
796 people viewed this question
Top Cub Cadet Garden Experts
dannydoesita
Marvin
Marvin
Dennis Key
Dennis Key
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
