Hi, To which network has your HTC TOUCH VIVA has been locked to? You can unlock your HTC TOUCH VIVA safer and easier using unlock code. You can get the unlock code for a HTC TOUCH VIVA from www.onlinegsmunlock.com/htc-touch-viva/rs7wp9/ at affordable cost.
UNLOCKING STEPS FOR HTC TOUCH VIVA
1. Switch ON your HTC Touch Viva with a Not ACCEPTED SIM Card.
2. If your HTC Touch Viva asks for a PIN code, then enter your SIM card PIN and press OK.
3. HTC Touch Viva will ask to enter an "unlock code".
4. Enter Unlock Code we send to you.
5. Your HTC Touch Viva is now unlocked.
Vibre
SOURCE: HTC Touch Viva is not charging
You have to check first the charger you can used multitester in position DC volt to make sure the voltage no problem, if in the plug no voltage maybe the cable damage, or the soldering on pcb circuit bad,you can try with another charger first to make sure where is the problem.
SOURCE: I want to use GPS for HTC touch VIVA
hi
sorry to point out but Viva is a non GPS phone and it does not have anything inside even to use a software to get it activated
cheers
pls rate if this was any help
SOURCE: htc touch viva mobile game file type jad or jar
if you have Java instaled on your phone (most HTC has) then .JAR, but is a small chance to work properly. try to find the game in .CAB format. Also WM devices are not good for games...
SOURCE: how to format htc viva touch
go to settings, then system and then clear storage, it will ask you to enter the number 1234, once done it will restart.
Thx pls vote if satisfied
SOURCE: Is HTC Touch Viva T2223 upgradable to WM 6.5?
yes it is, but you cannot upgrade it to the new upcoming 7.1
