RELAY CLICKS 3 TIMES. TEN BLINKING RED LIGHT PAUSE'S FOR 4 SECOND'S THEN BLINK'S TEN MORE AND CONTINUS TO DO THE SAME TIL I SWITCH IT OFF.
SOURCE: Panasonic Plasma HDTV 50
Please make sure your connectors are in the proper place.
The HDMI inputs on the rear of the TV are optimized for use with Audio/Video
devices, Blu-ray Disc Player, DVD Recorder, etc.
The front or side HDMI
inputs only are designated for PC. To use the TV as a PC monitor, advise
customers to use only front or side HDMI inputs.
SOURCE: 10 blinking light.
It is called mainboard and is the one where you plug your video (HDMI,component) cables if you want to order a new one you need your product code, it is located in the back of the TV, same place as the serial number.
SOURCE: my tv will not turn on. the red light flashes 10 times then pause
Most likely a bad Y-sustain board.
