How do I upgrade the bios for dv6433cl from within Win7 to access 4 gig memory addresses. ~without~ bricking the machine or having to do a complete re-install & update after the flash? I've read that if you have win7 and try too update from F2E it bricks the bios.
You never flash a BIOS within Windows. That's like running across a busy freeway. There is a chance you might not make it. And, you only flash the BIOS if you truly have a severe problem. You don't.
4GB is unobtainable within a 32bit system. The most Windows will end up utilizing is in the low 3GB's. This has been around for ages, and someone should have fixed it by now.
Ending up with a dead CMOS chip is as bad as it gets. In the end it is up to you whether to flash or not. All I could do was give you some advice.
http://www.techrepublic.com/blog/10things/10-common-mistakes-you-should-avoid-when-flashing-your-bios/357
Thank you for thr advice, I didn't mention I am running 64 bit ultimate, The phoenix bios is what is preventing the 4th gig of memory from being accesible. I'll have too see if I can make a boot cd & run the flash from it. My only concern would be that I have to reinstall the os & driver updates if that is the case.
