My ti 89 stays busy when i try to integrate sin(377*x - 1.231) for x from 0.299 to 3.94 my mode is in radians why wont my ti-89 integrate this
SOURCE: TI-89 problems
what i would do is go to the home screen and hit f6 and hit 'clear a-z' then you're good.
SOURCE: the Ti-89 titanium shows busy symbol all the time
It's frozen. Hold (at the same time) [←] [→] [2nd] then hit [on]. It clears RAM.
SOURCE: ti-89 titanium SIN!!!!!
The answer that you have received in actuality is correct. However, it is in exact form when the answer that you were looking for was an approximation (decimal form) answer. To achieve this all you have to do is hit the alpha button (the yellow button with a diamond in the center) and then enter which will give you your desired answer :-)
SOURCE: TI-89 Titanium Dimension Error
The folder your operating from could cause you problems. To integrate, I usually do that in the main folder, and I make sure I have all my variables deleted before I begin. The owners manual say under Dimension error is because of different sizes of lists, and that would be caused by undeleted variables.
SOURCE: TI-84 Incorrect sin/cos/tan values
What is so surprising? The sine and cosine functions have ranges that span the closed interval [-1,1]. As to the tangent function, its range is the the whole real line.
This being said, you should keep in mind that there are three angle units: the degree, the radian, and the grad.
When you want to calculate the sine, cosine, or tangent of a number, that number is not just a number. It is an angle, and as an angle it has a unit.
For this reason a calculator generally has two angle units defined (degree and radian), and possibly the grad. BEFORE calculating any trigonometric function you must ascertain that the angle is in the correct unit.
Clearly, in the problem you are trying to solve angle values are given in degrees, but your calculator is configured to interpret angles values in radians.
To set the default angle unit to degree press [MODE] , then press down arrow twice to reach the line (radian, degree). Highlight the word degree and press [ENTER] to set the default angle unit to degree.
Unfortunately the TI 8xPLUS family of calculators does not have a status bar on screen to remind you of the modes, and if you do not remember to check the current unit you get errors (at least unexpected results).
However, there is a way to avoid the errors and that is to enter the unit explicitly after the angle value. To do that you press [2nd][APPS] to open the (ANGLE) menu list. Try it.
By selecting the degree symbol and pressing [ENTER}, that symbol echoes on the screen just after the angle value. Closing the right parenthesis of the trigonometric function and pressing [ENTER] will give you the result in the correct unit of your choice. This can be done regardless of the default unit the calculator is configured for.
