Question about Maytag Refrigerators
The plastic peg that attaches the deli drawer lid to the refrigerator wall broke off. I can see no way to fix it. The peg seems to be part of the fridge wall. It goes into a hole in the lid. Designers should had made it the other way around, so that if the peg breaks off, a new lid will fix the problem. I don't know what to do.
Vernon Taylor
  • Maytag Master
  • 6,673 Answers
There are many specialist adhesives available today so broken plastic is no longer the problem it once was.
The main problem is such things as industrial strength superglue for plastics or ultraviolet curing plastics adhesive are fairly expensive and mostly not available from the average hardware store.
Trade outlets and suppliers to the plastic door and window trade or an internet search.
Posted on Nov 10, 2017
3 Related Answers
Anonymous
  • 52 Answers
SOURCE: The deli drawer popped out and when I tried to put
If that piece broke, you may need to replace that part, I wouldn't recommend any gluing.
Posted on Feb 04, 2010
allbrands
Victoria Gadawski
  • 600 Answers
SOURCE: the prong that holds the deli drawer lid broke
Hello, Thank You for using FixYa. I will be helping you today.It has to be replaced..You have to call maytag to have a factory tech come out to replace it and it will be covered under warranty.
Thank You and please rate my answer if it was helpful..
Posted on Jun 17, 2011
Marc Taylor
  • 150 Answers
SOURCE: deli drawer hinge broke
Try searching w/ Google on the brand and model no.
Here's one possibility: Parts
Posted on Sep 01, 2012
Will the deli drawer work properly without the glass door/lid? The pin broke off the right side and can't be fixed ... plastic broke off the actual drawer roller on the right. Cheap plastic ... disapp
Call in a repair man, it shouldn't cost that much. Yes, your food will be effected without that plastic door, as the drawer has controls and cold settings just for deli items. You need a special glue for cold. I'd call in a repair man, or order a new drawer replacement from the manufacturer.
Dec 01, 2014 | Maytag Refrigerators
Frigidaire French door model 28 cubic ft - deli drawer freezes cold cuts and cheeses. Model FGHN2866PF1
Hello friend, thanks for your inquiry!
I understand that you have a Frigidaire refrigerator, FGHN2866PF1, and your deli drawer is freezing items. You may want to turn down the temperature within your deli drawer, when adjusting the temperature could take 24 hours for your refrigerator to stabilize. If that does not resolve your issue I would suggest removing the drawer and checking over to make sure there are no cracks where too much air may be coming in. If there is too much weight in the deli drawer that could cause the drawer to sag, which may release cold air into the deli drawer. I hope this information has been helpfu. -Matt
Oct 10, 2014 | Frigidaire Refrigerators
Deli drawer hinge broke
Sep 01, 2012 | Whirlpool GI6FDRXXY
Kenmore Refrigerator 596.73503200 deli drawer cover hinge pin on right side broke off. Part #?
I would direct you to this link to find the part number you're looking for. I do not have one of these units to look at so am unsure which specific piece you'll need to replace.
Model 59673503200 KENMORE ELITE KENMORE REFRIGERATOR Parts
Nov 03, 2017 | Refrigerators
The prong that holds the deli drawer lid broke off. Can that be fixed or replaced. Its only 6mos. old
Jun 17, 2011 | Maytag MFF2558VEM Bottom Freezer French...
I purchased whirlpool GX5FHTXVA and there is a divider piece of plastic taped to the bottom of deli drawer, I have no idea where it goes. It is not in the manuel.
The wider end of the piece can be hooked anywhere on the back of the deli drawer. Keep the piece bent when you install it or it will scratch the glass on the front of the drawer. Also, make sure the tip of the smaller end is touching the bottom of the drawer before straightening the divider._1165.jpg
Apr 17, 2011 | Whirlpool GX5FHTXVA Bottom Freezer French...
Broken chef pantry drawer peg
Hi -
And I broke off the peg on the right side and have the same question. Any luck/answers?
Jul 20, 2010 | Amana ARB8057CSL Bottom Freezer...
Refrigerators Logo
78 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
